spark problem on 1989 jimmy - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 22nd, 2007, 07:16 PM   #1
drew15
Send a message via MSN to drew15
Default spark problem on 1989 jimmy
i have a 1989 gmc jimmy 4x4 4.3L i had it running and then i went to go move it so i can work on the body and i could not get it started. it is turning out and getting gas but i dont think it is getting spark and i dont know y. can some one help me plezzzzz. o i will sell the hole truck for 900 obo body work all done inside mint and u get two sets of rim.
drew15 is offline   Reply With Quote
Old February 23rd, 2007, 03:48 PM   #2
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
did you check the coil... or even the ecm fuse?
Old February 25th, 2007, 02:21 PM   #3
drew15
yes i did and i looked at all of the fuses and they r all good i have not clue
later drew
Old February 25th, 2007, 02:52 PM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
pull the distributor cap and see if the thing still spins. you may have thrown a timing chain if it doesn't. if its spinning fine then pull the rotor and see if it has any burn holes on the bottom. they are well known for torching through the plastic and the spark just skips to the shaft for ground.
Yetti
Page generated in 0.14908 seconds with 36 queries
