Ring and Pinion - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 22nd, 2007, 04:32 AM   #1
Ringhale
Ringhale's Avatar
Send a message via AIM to Ringhale
Default Ring and Pinion
Okay I need a new ring and pinion and iam going thru PORC to get them, but should i get thick or standard gears. They are going into a Dana 44 4.56 gears with a detroit locker..the ride is a 00 TJ sport with a rubicon 6" long arm suspen and 37" tires if any of that matters..thanks for any input
Ringhale is offline   Reply With Quote
Old February 22nd, 2007, 06:29 AM   #2
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
The TJ uses a thick ring gear set
There really should be no other option once you tell them what you have
Old February 22nd, 2007, 09:28 AM   #3
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
It depends on which locker you buy. Just tell them what you need they will do the rest.
Old February 22nd, 2007, 10:19 AM   #4
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Only the Rubicon models use the thick ring gear set. Since he's going to a Detroit, he can use whichever he wants. It's only when you're keeping the factory air lockers that you have to use a thick ring gear (available only in a few gear ratios).
Jeeperz Creeperz, Inc.
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
www.jeeperz-creeperz.com
Old February 22nd, 2007, 10:25 AM   #5
BMFmike
meh.
BMFmike's Avatar
I think he read the original post, and then said that under the guys circumstances...
Old February 22nd, 2007, 10:26 AM   #6
Jeeperz Creeperz
GL 4x4 Vendors
Personally, I'd go with the standard gears and the Detroit for 3.92+ gears. if you ever want to change gear ratios or use it in another axle it will probably be more compatible since there aren't that many thick gear ratios available.
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
Old February 22nd, 2007, 10:27 AM   #7
Jeeperz Creeperz
GL 4x4 Vendors
Yes, he's right that once he tells them he has a Rubicon they know what he'll need, but since he's losing the factory air locker the point is moot.
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
Old February 22nd, 2007, 10:36 AM   #8
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
He doesn't have a Rubicon tho'...its '00 Sport.
Old February 22nd, 2007, 10:49 AM   #9
Jeeperz Creeperz
GL 4x4 Vendors
Crap! And I read it twice!
Then I stand by my first statement!
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
Old February 22nd, 2007, 11:21 AM   #10
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Old February 22nd, 2007, 11:25 AM   #11
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
Perhaps I misunder stand? I thought the TJ set was a thick set....as opposed to 95 and earlier ZJ, and any D30 before the TJ
Old February 22nd, 2007, 01:43 PM   #12
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
Nope rubi D44's use the thick gear. Standard Tj D44's use the thin gear unless you want a thick gear then run a 3.73 and down case and run the rubi option gears.
Old February 22nd, 2007, 07:41 PM   #13
Jeeperz Creeperz
GL 4x4 Vendors
The 1997-2006 TJ (non-Rubicon) all use a standard "thin" gear. The Rubicon uses a thick 4.10 gear and the 3.73 and down case (instead of 3.92 and up with a thin gear like the regular D44's do).
All Dana 30 TJ (non-Rubicon) gears are the same (if that makes sense)
1996 was a changeover year for the ZJ only.
XJ gears are available in high or low pinion versions.
YJ gears are available in high pinion only.
WJ, TJ, and 1996.5-1998 ZJ gears are all the same
1993-1996.5 ZJ gears are all the same
XJ high pinion will fit YJ high pinion
I'm going to stop at that before I confuse myself
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
Page generated in 0.56442 seconds with 62 queries
