Torches - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 21st, 2007, 09:39 PM   #1
Tombs
Default Torches
How hard is it to learn to use acetalyne torch for cutting and welding?
Tombs is offline   Reply With Quote
Old February 21st, 2007, 09:51 PM   #2
One Arm Steve
I was born in the desert
One Arm Steve's Avatar
Search around here: http://www.weldingweb.com/
One Arm Steve is offline   Reply With Quote
Old February 21st, 2007, 10:06 PM   #3
Toivo
Feel lucky?
Toivo's Avatar
You'd be surprised. It's not complicated, just requires lots of skill. LOTS of skill. Mig Welding is much easier.
Old February 21st, 2007, 11:11 PM   #4
Cutting = easy
Welding with a torhc = takes some practice
I'd buy a wire-feed welder before a set of torches, myself.
Old February 22nd, 2007, 10:45 AM   #5
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Cutting = easy
X2
Old February 22nd, 2007, 09:40 PM   #6
Tombs
Thanks, I looked at it and it looks good.
The reason I ask about this is, I was given a set of torches which this person said she paid like 300 and some dollars for and wanted to know if I wanted them. Well, Yahhh.
I had a mig welder at one point but, could never get anything going with it. Had it like two years and never did learn to use it. It did'nt have gas though, I dont know if that makes a differance or not.
Old February 22nd, 2007, 09:49 PM   #7
Toivo
Feel lucky?
Toivo's Avatar
Makes a big differce, and even more so if you were welding with flux core and didnt have the polarity set right.
Pretty much what we are sayin is, gas welding sux. torching rox.
Old February 22nd, 2007, 09:54 PM   #8
Slayer63
Upstanding Member
Slayer63's Avatar
gas welding isint hard at all, you need to practice at it and its harder with filler but after a while it will get easyer.
Slayer63 is offline   Reply With Quote
Old February 22nd, 2007, 10:42 PM   #9
ITs a matter of money impact.
If you went out and bought a decent torch, tanks, and cart, you are out $300-$400 or so?
For the same cash you can get a wire feed welder running flux core(which is the best setup for most 4x4 related work, anyway) and a MAPP gas torch for heating duties.
Yeah, you aren't cutting with the torch, but you can cut with grinders practically as well.
You'll get much better weld quality, and use in general out of a wire feed welder. I know how to weld OK with a torch, but I haven't even bothered since I learned MIG 13 years ago.
Old February 23rd, 2007, 01:20 AM   #10
nightcrawler
My Tails a Waggin
nightcrawler's Avatar
Cutting easy, welding not too hard but mostly replaced by MIG. If you need a hand I could stop by one day. There are safety issues with torches, not to scare you, but basic saftey rules must be followed.
nightcrawler is offline   Reply With Quote
Old February 23rd, 2007, 05:04 AM   #11
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
before I used a mig for the first time I did all my welding with a torch. if you get good you can weld the thinnest shit out there. I raised the floors and subframed a Maverick and hung quarters on it with a torch back in the day. by the way the best wire to use is old coat hangers. very tough stuff. I used about 200-300 on the Maverick. by the way for cutting its hard to beat a torch. if you learn good you can use it as easy as any plasma cutter.
Yetti
Old February 23rd, 2007, 10:06 AM   #12
Slayer63
Upstanding Member
Slayer63's Avatar
i really like welding with torches and living out here, if i bust something out in a feild i can just drag the tanks out there. i have to disagree on the quality issue. i can make a really nice weld with a torch and have better penetration then witha mig.
yeah ive got a couple boxes full of boxes full of coat hangers for gas welding.
Old February 23rd, 2007, 12:32 PM   #13
Kawierider
Kawierider's Avatar
I love cutting with an oxy-torch setup......smooth as butter....well, butter with lots of spark and burning metal.
Old February 23rd, 2007, 12:35 PM   #14
For people who take the time to learn it, yeah, you can get good results.
But I'm going to assume most people won't learn to torch weld properly. And its a much faster learning curve on a MIG, IMO.
Yeah, portability is a concern, if you need that. Again, 99% of people here don't.
Old February 23rd, 2007, 02:03 PM   #15
gotsand?
sie sehen mich rollin ...
gotsand?'s Avatar
Location: New Era, MI --- "We passed BFE 35 minutes ago."
Send a message via Yahoo to gotsand?
not to hijack here, but is there any advantages to using propane over acetylene (sp)???
oh and I am referring to cutting, not welding
I just bought a used set for 200 w/ tanks, and it has propane....thanks!
gotsand? is offline   Reply With Quote
Old February 23rd, 2007, 04:15 PM   #16
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
propane is a MAPP gas......it works essentially the same.
Old February 23rd, 2007, 06:24 PM   #17
Mmm, not quite. MAPP is methyl acetylene propadiene, burns a good 30-40% hotter than propane.
I've never used propane as a cutting fuel.
Old February 23rd, 2007, 06:48 PM   #18
Yetti
Yetti's Avatar
we use mapp as torchs at work. its ok, but you have to keep your regulators set right. to many people don't know how to use it and mess with the regulators. also the tips are different then regular torch tips. they have double the holes to work right. I use both at work and the regular ones still work just lots slower at heating stuff up.
Yetti
Old February 23rd, 2007, 09:17 PM   #19
I used to use them, when I did plumbing/sprinkler systems.
Old February 23rd, 2007, 11:06 PM   #20
sglide
co captain of cubes pants
sglide's Avatar
ok here goes
if you are planning on a welding for a living than you should learn oxyfuel first.
it teaches you more about a weld puddle than any other form.
as far as a better weld profile with oxxy or better pen. this is false.
welding with oxxyfuel is welding with un fluxed metal unless you are brazing (brazing is not weldind) and unfluxed metal is weaker.
mig has not replaced oxxyfuel for ultra thin mat. tig has.
cutting with propain sucks, scrap yards use it cuz its cheaper than acc. but it dosnt cut very clean and takes alot longer (dosnt burn as hot as acc.)
sglide is offline   Reply With Quote
Page generated in 0.49893 seconds with 83 queries
