ok what did i do - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 19th, 2006, 08:50 PM   #1
farm_boy
hicktown
farm_boy's Avatar
Default ok what did i do
so my engina overhates if i am at an iddle and theres no fuild in the overflow
but when i move the tmep goes down
farm_boy is offline   Reply With Quote
Old January 19th, 2006, 08:55 PM   #2
Mclovin
"The Situation"
Mclovin's Avatar
well put some fluid in the over flow make sure the radiator is topped off. lastly make sure both fan shrouds are in place, and that your fan clutch is working..
Old January 19th, 2006, 09:21 PM   #3
One Arm Steve
I was born in the desert
One Arm Steve's Avatar
Replace the thermostat and top off the coolant
One Arm Steve is offline   Reply With Quote
Old January 23rd, 2006, 08:04 AM   #4
FrankNBrew
Me balls are huge
FrankNBrew's Avatar
Try using some lube.
Seriously, sounds like the electric fan isn't working. Probably need to replace the temp switch for the fan, not to be confused with the sensor for the gauge or the sensor for the ECM.
FrankNBrew is offline   Reply With Quote
Old January 26th, 2006, 08:40 PM   #5
SS
Bananarama!
SS's Avatar
In chat he said he was sunk in some mud
He also said there was a hole in the radiator (and yes I asked multiple times to make sure)
My guess is there is barely any coolant in the system thanks to that hole
-Jer
Old January 27th, 2006, 11:28 PM   #6
Mclovin
"The Situation"
Mclovin's Avatar
After Reading what SS said. Id almost say replaced the whole cooling system.. running the engine for any period of time with Fry the water pump, it relys on the coolant to lubricate the bearings internally. without that, it's more than likely fucked.
Page generated in 0.17970 seconds with 41 queries
