TBI to Carb swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 21st, 2007, 07:03 PM   #1
nivek82z28
Default TBI to Carb swap
I have a 1990 Chevy Z71 with Throttle Body Injection. I have been thinking about putting a carburator on it so I can eliminate all the sensors and PCM controls. I have basically everything I need for the carb swap (800cfm double pumper, Edelbrock Performer RPM intake, HO 305 heads, HEI distributor). I plan on putting in mechanical gauges and re-wire everything. I currently have the body off of the frame of the truck and I will soon be building it from the ground up come spring.
I was wondering if anyone has suggestions for or against this swap?
Thanks
nivek82z28 is offline   Reply With Quote
Old February 21st, 2007, 07:13 PM   #2
Motor Slut
I put the Ick in Dick.
Motor Slut's Avatar
800 cfm? That's a bit high for a 350.
Old February 21st, 2007, 07:18 PM   #3
greenjeep
greenjeep's Avatar
I can get rid of all that nasty fuel injection computer, wiring, sensors, and crap for you.
greenjeep is offline   Reply With Quote
Old February 21st, 2007, 07:38 PM   #4
shredder70
Chillin with the top off.
shredder70's Avatar
800 cfm is way to big with stock heads. 600-650 will do just fine unless you have like 300 cc runners in your intake..:tonka:
shredder70 is offline   Reply With Quote
Old February 21st, 2007, 07:47 PM   #5
nivek82z28
I realize the 800 is too large of a carb for the setup, but I know it works. It will be a temp. until I get my 600 holley pieced together.
By the way, does anyone know if those TBI engines have a lobe on the cam for a mechincal fuel pump? Thanks.
Old February 21st, 2007, 07:53 PM   #6
nivek82z28
If I go ahead with the swap, I will probably post a bunch of stuff for sale in a few months.
Old February 21st, 2007, 10:41 PM   #7
greenjeep
greenjeep's Avatar
I know my 94 350 suburban doesn't have the outside provisions for a mech fuel pump. Its cast there, but not machined out.
I would just get a regulator and use the stock pump.
Page generated in 0.28882 seconds with 44 queries
