rear discs on a chevy - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 21st, 2007, 02:08 PM   #1
fukkinrizzo
Chrome Trucker Chicks Rul
fukkinrizzo's Avatar
Exclamation rear discs on a chevy
I have a friend who put rear dics on his truck but is not getting enough pressure to the back discs. when driving he can lock up the front but not the rear.
all calipers are the same and he has a 1ton hydroboost
he used a 1/2 ton proportoning valve and went straight to the master cylinder. Neither worked.
If he jacks up the rear tires the brakes will stop them, but they won't lock up when driving like the front ones do.
any ideas?
fukkinrizzo is offline   Reply With Quote
Old February 22nd, 2007, 03:26 PM   #2
ccatlett1984
CUCV's are COOL!!
Send a message via AIM to ccatlett1984
hey rizzo, whats up. I am betting that the prop. valve is restricting the flow too much. with the rear discs he might be able to get away with running without a prop valve to the rear, full pressure wont cause the braking issues with discs as it will with the drum brakes. if needed you can get an adjustable prop. valve and use it. I will be doing the adjustable valve on my truck, so I can adjust the braking when i am towing or heavily loaded.
ccatlett1984 is offline   Reply With Quote
Old February 22nd, 2007, 03:35 PM   #3
ccatlett1984
CUCV's are COOL!!
where is your buddy at?
Old February 22nd, 2007, 04:42 PM   #4
fukkinrizzo
Hi Chris.
He is on the north side of PH. Others have told me that a reg. master cyl pushes less fluid to the rear because the drum brakes use less. He is looking for a Master cyl for 4 wheel disc brakes
Old February 22nd, 2007, 04:46 PM   #5
EL BURRO
33's is how I roll
EL BURRO's Avatar
hey are the soft lines kinked in any way?
just a thought...
EL BURRO is offline   Reply With Quote
Old February 22nd, 2007, 05:00 PM   #6
fukkinrizzo
I don't think so cause he just put the whole thing on, but I will mention that to make sure.
Old February 22nd, 2007, 05:17 PM   #7
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
Make sure the calipers have the bleeder at the top. I used a larger bore MC for a chevy along with the same size ports for the front and rear. I used a 2# residual brake valve from jegs it was like $30 "the red one". With all the trucks out with rear discs I think you could get one at a junkyard for less than $50. Back when I did mine they were over $100 at the junk yard.
Old March 4th, 2007, 10:34 AM   #8
hlfbrd71
hlfbrd71's Avatar
back brakes no matter if disc or drums are there to help slow it down not lock up the brakes.thats what i was always told.
hlfbrd71 is offline   Reply With Quote
Old March 5th, 2007, 01:29 AM   #9
ccatlett1984
CUCV's are COOL!!
this is true, but he is having issues getting any pressure to the rear brakes.
Old March 5th, 2007, 12:20 PM   #10
offrdf150
wheeler
offrdf150's Avatar
sounds like the poportioning valve most rear conversions give to much brake to the rear and either need an adjustable paportioning valve o use stockcalipers in the rear and the heavy duities up front.
offrdf150 is offline   Reply With Quote
Page generated in 0.22941 seconds with 53 queries
