removing the proportioning valve - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 21st, 2007, 09:50 AM   #1
warhof
pope approved
warhof's Avatar
Default removing the proportioning valve
I want to clean up the frame on my 86 runner, wondering if anyone know the correct way to reroute brake lines once the rear o.e. valve is removed? I would just leave it, but it is in the way of some gussets I want to weld in.
warhof is offline   Reply With Quote
Old February 21st, 2007, 11:35 PM   #2
ron86toy
R&V Ranger
ron86toy's Avatar
Send a message via Yahoo to ron86toy
I would leave it in...mount to your new gussets.Is your frame rotting thet you are putting gussets in?If it is just cut out the bad and put new plate in then remount.
I took off my load proportioning valve and put an axle T in its place.Not sure if you have one of those.....think the were only on sr5 models
ron86toy is offline   Reply With Quote
Old February 22nd, 2007, 11:20 AM   #3
warhof
pope approved
warhof's Avatar
what about a wilwood proportioning valve? If I set it to what a nominal load would be, it should be no different than having it?
Old February 22nd, 2007, 04:19 PM   #4
ron86toy
R&V Ranger
ron86toy's Avatar
that would also work....I would not take it out and not run one....I took out the load p. valve because it was producing air in the line
Old March 12th, 2007, 03:29 PM   #5
Mud'N'Truck
I'll Finsh One, One Day
Mud'N'Truck's Avatar
I put a summit proportioning valve on mine ( same as wilwood). Worked good once you get it tuned in right. Nice being able to adjust it. Only problem i had was the nob seized up so i ended up turning the nob off. My advice is to keep the nob well lubed.
Heres a link with a guy that did it to a 4runner.
http://home.4x4wire.com/erik/4runner/brakes/
Check that everything works together first, i didnot witch lead to alot of trips to napa. I also did the chevy master cylinder and used a dual diafram booster out of a 94 4x4 toyota truck. All made a preatty big difference. Any ?'s about the swap just ask.
Old March 14th, 2007, 10:12 PM   #6
7mRunner
Love/Hate Turbo 4Runner$
7mRunner's Avatar
I say, remove it - hook it up to a gauged fluid pump, with a different gauge check the output pressure full open / full closed / static.....
then you can make an adapter and base the adapter on your desired flow pressure.
7mRunner is offline   Reply With Quote
Page generated in 0.24749 seconds with 41 queries
