lock right install help please - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 18th, 2007, 06:35 PM   #1
General
General's Avatar
Default lock right install help please
I have 1989 Jeep Cherokee with a dana 30 vac disconect and can't get the c clip for my inner shaft in. When the locker is insalled the cross shaft is in the way. I have 4.10 gears and becuase of the thickness of those gears I can't insert or remove the cross pin with the ring gear installed. Thus making it difficult to install the c clip. Now I know you can eliminate the vac disconect but I rather not do this at this point. Has anyone gone through this before? My directions are not very clear on how this would be done. Please help. Thanks
General is offline   Reply With Quote
Old February 19th, 2007, 08:56 AM   #2
nobodies installed a loc rite in a frt dana 30?
Old February 19th, 2007, 09:15 AM   #3
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Leave the clip out.
Old February 19th, 2007, 09:27 AM   #4
PavementPounder
PavementPounder's Avatar
I'd go to a solid shaft and ditch the disco.
Old February 19th, 2007, 11:33 AM   #5
his jeep is in my garage, he just bought the posi lock cable to replace the vacumn lines. So i'm sure he doesn't want to switch to a solid right shaft. Are the loc rights designed not to be used with the 2-peice shafts?
Old February 19th, 2007, 11:44 AM   #6
junk90xj
ALLPRO AUTO
junk90xj's Avatar
Originally Posted by Jeeperz Creeperz View Post
Leave the clip out.
x2
http://www.apalansing.com/
Old February 19th, 2007, 11:50 AM   #7
FrankNBrew
Me balls are huge
FrankNBrew's Avatar
I've never done one of these before, but I do recall reading somewhere where the ring gear needed a very slight amount of one of the teeth ground off, just enough to clearance the center pin. Might be worth a search.
FrankNBrew is offline   Reply With Quote
Old February 19th, 2007, 12:16 PM   #8
Toivo
Feel lucky?
Toivo's Avatar
You may need a new cross shaft with specific D30's. Can't recall what ones. Call lock rite, they will help.
Old February 19th, 2007, 12:51 PM   #9
nick_n_ii
nick_n_ii's Avatar
Send a message via Yahoo to nick_n_ii
I put one in my buddy's witha solid shaft no prob, Mine has the cable disconect with a lock-right but was installed when I bought it.. Sorry cann't be of more help, just know it can work with the 2 pcs axle..
nick_n_ii is offline   Reply With Quote
Old February 19th, 2007, 05:34 PM   #10
Jeeperz Creeperz
GL 4x4 Vendors
Originally Posted by junk90xj View Post
x2
It's funny :tonka: what do we know? :chiefwoohaw:
Old February 19th, 2007, 05:43 PM   #11
General
General's Avatar
Leave the clip out.
Sounds good to me just didn't know if the clip was needed. Thanks for your help.
Old February 19th, 2007, 05:47 PM   #12
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
Leave the clip out.
X3
Old February 19th, 2007, 05:47 PM   #13
Jeeperz Creeperz
GL 4x4 Vendors
If you really think about it, where is the shaft going to go? If it moves it's either going to hit the cross shaft in the diff or hit the outer axle shaft.
Plus (little known fact) they redesigned the Lock-Right and they don't have the recessed slot to install the c-clips.
Old February 19th, 2007, 05:48 PM   #14
Jeeperz Creeperz
GL 4x4 Vendors
Originally Posted by Cooter View Post
X3
Yeah, yours works GREAT! CLICK! CLICK! CLICK!
I could barely hear it over my ticking motor!
Old February 19th, 2007, 09:00 PM   #15
General
General's Avatar
You would think they would include this in the directions for the locker. I knew it wouldn't go anywhere I just didn't want to damage the locker.
Old February 19th, 2007, 09:33 PM   #16
nobody contradicted what was suggested, we didn't know so we asked
now if it was a D35 TTB i would know all the answers
Old February 20th, 2007, 12:04 PM   #17
Cooter
Cooter's Avatar
Yeah, but I used a one piece shaft in mine. :miff:
Page generated in 0.37343 seconds with 74 queries
