What motor in a 68 Wagoneer - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 18th, 2006, 10:27 PM   #1
Mclovin
"The Situation"
Mclovin's Avatar
Default What motor in a 68 Wagoneer
I got this crazy ambition to get my waggy running and wheel it.. but i dont know what motor is in it... ive been told Buick 350 ive been told AMC 360..
I doesnt say anywhere on it, but i has a dist. in FRONT angled towards drivers side... its has a 2 barrel rochester carb.. thats the only thing i can think of that set it apart from others, ANyone know what engines came in these ?? I could prob get the vin this weekend if its still on there.. I will also snap good pictures then..
I doubt these pics will help, but tell what angles will help and i will try to take them this weekend...
Old January 19th, 2006, 12:14 AM   #2
boggin-machine
boggin-machine's Avatar
looks like a 350 to be but im a dumb ass so i have no idea. but all of my 350s have looked like that
Old January 19th, 2006, 12:15 AM   #3
boggin-machine
does the manifold have the firing order as part of the caster in the front. do you know the firing order?? i think you could tell bt looking at the exhaust ports also.
Old January 19th, 2006, 12:45 AM   #4
PavementPounder
PavementPounder's Avatar
That's the Dauntless II Buick 350. See below minus the vehicle.
Old January 19th, 2006, 01:15 AM   #5
Mclovin
"The Situation"
Mclovin's Avatar
yep that looks like mine ! Thanks PP
Know of anyone who has one in running descent running condition that i could buy/ cheap ?
Im goin to post in the wanted adds too..
Old January 19th, 2006, 03:17 PM   #6
shawn
Resident HVAC/R Jambi
shawn's Avatar
Wow, does that look similar to a AMC 360!
Old January 20th, 2006, 06:27 AM   #7
PavementPounder
Yeah, except for where it says Dauntless on the air cleaner.
:tonka:
Old January 20th, 2006, 02:50 PM   #8
Mclovin
"The Situation"
Mclovin's Avatar
Got any idea what other motors will bolt up in place of that ?? without special adapters
Old January 20th, 2006, 03:41 PM   #9
How about a Buick 455?
Old January 20th, 2006, 03:46 PM   #10
cracker$
cheese
cracker$'s Avatar
Not positive but probably one of these...
Station Wagons/Panels and Wagoneers, Cherokees
Engine Manufacturer Year
230 OHC, I-6 Kaiser 1962-65 (early)
232 OHV, I-6 AMC 1965 (late)-71 (early)
258 OHV, I-6 AMC 1971 (late)-87
304 V8 AMC 1971-72
327 V8 Kaiser 1965-68
350 V8* Buick 1969-71
360 V8 AMC 1971-92
401 V8 AMC 1974-78
http://www.ifsja.org/tech/figures/db.shtml
cracker$ is offline   Reply With Quote
Old January 20th, 2006, 05:42 PM   #11
Mclovin
"The Situation"
Mclovin's Avatar
Thanks for the info i know i have a dauntless II buick 350 with a GM Th400 Trans and a Dana 20 Transfer case
Will any B.O.P. (buick , olds, pontiac) bellhousing engine bolt up in place of that ?
Old January 20th, 2006, 07:30 PM   #12
cracker$
cheese
cracker$'s Avatar
I believe Buick, Olds, and Pontiac bell mounts are the same. Chevy engines are different. I personally like the Olds the best out of all others.
Sweet Olds website (Good info on cyl. head porting)...
www.mondellotwister.com
Old January 21st, 2006, 06:39 PM   #13
PavementPounder
The BOPC motors will fit the bell, but the crank input spline counts may not be the same. The motor mounts will also be different.
Either fix your motor, or do the REALLY easy thing and buy the exact same one that happens to be available RIGHT NOW. Then you'll have spare parts galore with two complete motors. You will spendmore trying to drop in a different engine than buying the same one that will drop in.
Old January 22nd, 2006, 01:49 AM   #14
Mclovin
"The Situation"
Mclovin's Avatar
If i had the money i would buy YER MOMS motor in a sec. but i dont. i found agasket kit for 70 bux from MR. Gasket, so i might tear the engine down and see what it needs. i can do machinin work for free at school (deck the block and heads get some decen compresion), and i can get engine parts rather cheap through dad's friends... We'll see
Old January 22nd, 2006, 09:11 AM   #15
cracker$
cheese
cracker$'s Avatar
Not that I don't want to get rid of my engine but, I think a rebuild sounds like a good idea since you have access to the equipment. Although it might cost you even more cash if you need to replace cranks, rods, etc.
Hows about $400 for engine, trans., & t-case ? I know you only want the engine but I can't use the other stuff, and maybe you can sell it and re-coup some of the $400. Either way, the engines got a place to stay for a while, so it's not going anywhere (unless I go through with the project it was originally intended for).
Old March 23rd, 2006, 01:35 AM   #16
Mclovin
"The Situation"
Mclovin's Avatar
Sorry to resurect an old post, but does anyone know if the Dauntless motor is different than a standard Buick small block ?? im lookin at engine rebuilding kits..
Old March 23rd, 2006, 01:37 AM   #17
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
I'm pretty sure the Dauntless was a V6, somewhere around 3.5L?.. ish?
Old March 23rd, 2006, 01:42 AM   #18
Mclovin
"The Situation"
Mclovin's Avatar
nope this has been confirmed Dauntless II buick 350.. there was a Dauntless V-6 also.. im prob gona tear the motor apart next time i go home wetheri can find a kit or not.. but if its just rings and bearings i fgiure i should be able to get it running again without tooooo much $$ invested..
Old March 23rd, 2006, 01:46 AM   #19
Captain Ledd
Ranger Addiction?
Bah.. Shows what I know lol
I remember saying that before... good luck with the build.
Old March 23rd, 2006, 07:04 AM   #20
PavementPounder
Look it up as a 1969.
It was a 225. :miff:
Page generated in 0.43115 seconds with 83 queries
