1979 Ford Super Stock Pulling Truck Turn Key! New price! $14,000!!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 16th, 2007, 07:28 PM   #1
MISHOWJEEPER
NSFW
MISHOWJEEPER's Avatar
Exclamation 1979 Ford Super Stock Pulling Truck Turn Key! New price! $14,000!!!
Look At This! 1979 Ford F350 Extremely Modified Ttpa 4x4 Pulling Truck! This Truck Is Turnkey, Ready To Compete And Win! The Shopping List For The Motor Includes A New Svo Block, Eagle Crank And Rods, 14:1 Compression, Victor Single Plane Intake, This Is A Full Roller Motor, Including Cam Bearings. I Don't Have The Complete List Of Parts In Front Of Me, It Will Be Added Soon, But There Was No Expense Spared On This Motor, You Can Turn Over 8,000 Rpm's With Ease, Ttpa Rules Restrict It To 750 Cfm, And Even With That Restriction We're At About 900 Horse! The Whole Truck Is Fabricated To Win And Not Break, Dana 70 Spooled In The Rear 5.13 Gears Front And Back, Dana 60 Front, Detroit Locked, Built C6 With A 6,000 Stall Converter That'll Break Your Neck! Np205 Transfer Case, Electric Water Pump, Electric/hydraulic Pump For Steering, You Can Hang 2,000 Extra Pounds Of Weight On The Front Of This Thing And Still Steer It With One Finger! No Joke! Full Safety Measures That Meet All Ttpa Rules, Trans Shield, Engine Block Shield, Full Driveshaft Cages, 360 Degree U-joint Enclosures, Mooneyes Fuel Cell, Kill Switch,
Many, Many More Details Available, This Is Just What I Could Pull Off The Top Of My Head At The Moment, The Engine Is Completely Fresh, Less Than One Season On It Since Built, Forgot To Mention Belt Drive Timing, Fuel Line Cooling Reservoir, Aluminum Thunder Jet Heads, You Could Pass A Grade A Egg Through The Ports In These Things! The Body Of This Truck Is Not Perfect, But Looks Perfect To Spectators 20 Feet Away!
Again This Is A Turnkey Ready To Run Truck, Comes With All Five Batteries! Trailer Available, Hell, Dd F250 Available As Well To Pull It To The Track With! Want The Entire Setup? Why Not?
Pulling Truck Going For $16,000 Obo Located In Lapeer Mi, Pm Me About The Trailer And Daily Driver 96 F250 Extended 4x4 With A 460 If Interested. Hell Of A Toy, Been Doing This For Decades, And It's Time For Sports Cars! 1996 F250 tow rig has been sold
More Pics And Info Coming Soon If There's A Demand For It!
1979 Ford Truck F250 4 Wheel Drive S/S Pulling Truck
Vehicle Description
1979 Ford F250 4 W.D. 460 V8 .Super Stock Pulling Truck. 5800 lb. & 6200 lb. Classes. Over 800 HP. ENGINE IS CAPABLE OF TURNING 8,000 RPM. Set up to Thumb Tractor Pulling Association Inc. Rules for 2007. Competition Ready. Not Street Legal. I will do my best to describe this truck, please email any further questions. PLEASE VISIT THIS WEB SITE FOR FULL LIST OF RULES. http://www.ttpa.org/
ENGINE: STARTING OFF WITH A BRAND NEW FORD 460 SPECIAL VEHICLE OPERATIONS (SVO) 4 BOLT MAIN BLOCK. STANDARD BORE OF 4.360. NEVER OVERBORED
EAGLE CRANKSHAFT 3.850 STROKE BRAND NEW NEVER TURNED STOCK JOURNAL DIAMETERS. EAGLE H-BEAM RODS
J E PISTONS 14:1 COMPRESSION RATIO
ROTATING ASSEMBLY BALANCED AND BLUEPRINTED
BLUE THUNDER ALUMINUM CYLINDER HEADS PORTS MATCHED TO INTAKE MANIFOLD
STAINLESS STEEL VALVES, 2.25" INTAKE VALVES, 1.88" EXHAUST VALVES. FLOW NUMBERS FOR HEADS AVAILABLE, PLEASE EMAIL FOR FURTHER INFO ON HEADS.
COMP CAMS HARDWARE WITH TITANIUM RETAINERS
ISKI FULL ROLLER ROCKERS
COMP CAMS ROLLER CAM AND ROLLER LIFTERS. PLEASE EMAIL FOR CAM SPECS
JOMAR RACING ROCKER ARM STUD GIRDLE
DANNY BEE RACING PRODUCTS CAMSHAFT BELT DRIVE SYSTEM
FLUIDAMPER CRANKSHAFT DAMPENER
ELELBROCK VICTOR SINGLE PLANE ALUMINUM INTAKE MANIFOLD
HOLLEY H.P. 750 CARB. 4150 HP SERIES
HOLLEY ELELECTRIC FUEL PUMP
ALL AEROQUIP STAINLESS STEEL BRAIDED FUEL LINES
MALLORY FUEL RETURN LOG
K & N AIR FILTER SYSTEM
THUMB TRUCK PULLING ASSOCIATION RULES RESTRICT ALL SUPER STOCK TRUCKS TO A 750 CFM CARBURETOR. THIS ENGINE COMBINATION COULD MAKE SUBSTANTIALLY MORE HORSEPOWER WITH LARGER CFM CARB OR MORE THAN ONE CARB.
MEZIERE ELECTRIC WATER PUMP.
FLEX-A-LITE ELECTRIC COOLING FAN.
HOWE ALUMINUM RADIATOR.
IGNITION: MSD BILLET DISTRIBUTOR, MSD 6AL IGNITION BOX, MSD 8MM SPARKPLUG WIRES, MSD BLASTER II COIL.
EXHAUST: HEDMAN HEADERS THROUGH THE HOOD WITH THERMO-TEC HEADER WRAP.
J.S.B. ELECTRIC/HYDRAULIC PUMP FOR POWER STEERING.
MOONEYES ALUMINUM DRAGSTER FUEL TANK
MOROSO SUPER COOL CAN FOR FUEL DELIVERY SYSTEM
CRANKCASE EVACUATION SYSTEM TO MAINTAIN NEGATIVE PRESSURE IN THE CRANKCASE THROUGHOUT THE RPM RANGE
TRANSMISSION:
FORD C6 MODIFIED WITH MORE CLUTCH DISCS PER PACK, B & M SHIFT KIT COAN 10" TORQUE CONVERTER 4500 RPM STALL SPEED. B & M PRO RATCHET SHIFTER. NP205 GEAR TO GEAR TRANSFER CASE
AXLES: DANA 60 REAR WITH SPOOL AND OVERSIZED 1.5" 35 SPLINE AXLESHAFTS CUSTOM DISC BRAKES ON REAR AXLE PLUS CUSTOM AXLE TRUSS
DANA 60 FRONT AXLE WITH DETROIT LOCKER DISC BRAKES, RICHMOND 4.56 GEARS IN BOTH AXLES
SAFETY:
S.F.I. APPROVED FLEXPLATE SHIELD BY T.S.I.
S.F.I. APPROVED TRANSMISSION SHIELD ALSO BY T.S.I.
S.F.I. APPROVED TRANSMISSION BLANKET ALSO BY T.S.I.
DRIVER AND PASSENGER KIRKEY ALUMINUM RACING SEATS WITH COVERS. TWO SEATS REQUIRED BY PULLING ASSOCIATION
DRIVERS FIVE POINT RACING HARNESS BY T.S.I.
GUAGES: ALL AUTOMETER GUAGES
5" MEMORY TACH, MECHANICAL OIL PRESSURE, MECHANICAL WATER TEMP, VOLTMETER, MECHANICAL TRANS TEMP, FUEL PRESSURE
WEIGHT BAR IN FRONT HAS REMOVEABLE LEAD WEIGHTS FOR 5800 LB. SUPER STOCK AND 6200 LB. SUPER STOCK WEIGHT CLASSES
WHEELS AND TIRES: GOODYEAR TERRA TIRES 31x15.50x15 4 PLY IN THE FRONT AND 8 PLY IN THE REAR ON 15x15 STEEL WHEELS. THIS IS THE LARGEST TIRE ALLOWED BY TTPA RULES.
THIS TRUCK HAS FIVE BATTERIES. FOUR IN THE WEIGHT BAR, AND ONE IN THE ENGINE COMPARTMENT. THE TRUCK IS SPECIALLY WIRED TO BE CHARGED BY YOUR TOW VEHICLE AS YOU'RE DRIVING TO A PULL.
ID:	6976   Click image for larger version
ID:	6979   Click image for larger version
ID:	6983   Click image for larger version
ID:	6984   Click image for larger version
ID:	6986   Click image for larger version
ID:	6987   Click image for larger version
MISHOWJEEPER is offline   Reply With Quote
Old February 17th, 2007, 10:44 AM   #2
MISHOWJEEPER
NSFW
New Pics!
Old February 17th, 2007, 11:54 PM   #3
Big Daddy Rubicon
There watching me! (.)(.)
Big Daddy Rubicon's Avatar
Very cool toy! Good luck
[QUOTE=a.j. hall;1528363]
[/QUOTE]
Old February 19th, 2007, 05:57 AM   #4
MISHOWJEEPER
NSFW
bump!
Old March 9th, 2007, 01:07 PM   #5
MISHOWJEEPER
NSFW
Bump for way more info. This is a dream shopping list!
Old March 10th, 2007, 09:52 AM   #6
MISHOWJEEPER
NSFW
Everybody scared of 900 horses?
Old March 10th, 2007, 11:30 AM   #7
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
yes, and i have no money bump for ya though.
I'm the man in White.
Old March 10th, 2007, 11:39 AM   #8
MISHOWJEEPER
NSFW
Thanks Skooter. extra bump!
Old April 15th, 2007, 09:27 AM   #9
wildthing
truck puller
bump
wildthing is offline   Reply With Quote
Old May 4th, 2007, 04:08 PM   #10
MISHOWJEEPER
NSFW
Pulling season's here!
Old May 7th, 2007, 02:22 PM   #11
MISHOWJEEPER
NSFW
Bump for new price!
Old March 25th, 2010, 02:00 PM   #12
MISHOWJEEPER
NSFW
ttt
Old March 26th, 2010, 11:18 AM   #13
bigpapa
bigpapa's Avatar
pics of tow truck n trailer n price for whole dam thing
bigpapa is offline   Reply With Quote
Old March 26th, 2010, 11:25 AM   #14
MISHOWJEEPER
NSFW
Sorry I didn't update, the tow truck has been sold, pulling truck is on the trailer in the seventh picture, let me know if you want better pics of the trailer.
Old April 30th, 2010, 10:22 AM   #15
danimal
IS IT JEEPIN TIME
danimal's Avatar
pm sent
danimal is offline   Reply With Quote
Old April 30th, 2010, 10:26 AM   #16
MISHOWJEEPER
NSFW
pm returned
Old May 6th, 2010, 11:38 PM   #17
projecttk
projecttk's Avatar
this puppy bin sold yet?
what sports cars are you looking at buying or getting into?
projecttk is offline   Reply With Quote
Old May 17th, 2010, 06:13 PM   #18
MISHOWJEEPER
NSFW
Looking for a 67 or 68 Firebird convertible, original 400 car
Old June 11th, 2010, 10:09 PM   #19
Gen.SterlingPrice
800hp and only a 60 out back?
Gen.SterlingPrice is offline   Reply With Quote
Old June 11th, 2010, 10:45 PM   #20
94rangeron35s
bought a Jeep
94rangeron35s's Avatar
looks like it has a 70 out back if i read it right.
Wish i had the money for this thing would love to uncork that much hp..
bump for a bad a$$ truck..
Page generated in 0.49739 seconds with 84 queries
