which one would you lock? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 18th, 2006, 07:03 PM   #1
Cube
Captain of my pants
Cube's Avatar
Default which one would you lock?
currently I have limited slip in the front(true trak ) and detriot truetrack in the rear. I am going to buy one locker now, hehe just cause I am poor so should I lock the front or rear? I was thinking rear and put the detriot true track on the front.
Cube is offline   Reply With Quote
Old January 18th, 2006, 07:14 PM   #2
brimy311
Smells like a Fork Liftis
brimy311's Avatar
yep, probably swap the rear to the front and lock the rear.
JcrOffroad.com
Like us on Faceook!
Old January 18th, 2006, 08:25 PM   #3
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
This has been argued whether locking just the front or just the rear works best. I say lock the rear, but locking the front will probably give you better traction for hill climbing and such.
Old January 18th, 2006, 08:42 PM   #4
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Why not just save the $$$ and do both at the same time? IMO I'd lock the rear and leave the front alone (then sell the truetrack for $ for another locker), you'll save time and money by not having to set-up one axle twice if you don't switch the two around.
Old January 19th, 2006, 01:07 PM   #5
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
A Trutrac is a Tractech limited slip differential. Why would you need to move the rear to the front if you already have one there?
Jeeperz Creeperz, Inc.
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
www.jeeperz-creeperz.com
Old January 19th, 2006, 02:00 PM   #6
sodapop
Support the Sport!
sodapop's Avatar
I'd lock the rear first, in fact I that's what I did
Old January 19th, 2006, 03:12 PM   #7
Mclovin
"The Situation"
Mclovin's Avatar
Old January 20th, 2006, 07:50 AM   #8
PavementPounder
PavementPounder's Avatar
You don't drive it around, so lock the front and Lincoln the rear.
Old January 20th, 2006, 01:24 PM   #9
Hacksaw
WWSD - What would stan do
Hacksaw's Avatar
x1908257190347509147869018376
Old January 20th, 2006, 01:37 PM   #10
Yes, lock the front with a lunchbox locker, weld the rear, sell your limited slips, might not even cost anything after selling parts.
Your driving characteristics with the spool aren't going to be worst than with a rear locker, and tire wear won't be much different. A locker is locked when you are on the gas anyway, so most turns you aren't costing, you are hitting the gas to move, so you are locked around curves usually anyway.
Old January 20th, 2006, 04:58 PM   #11
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
OK this might sound stupid, but wouldn't it be a PITA to Lincoln lock a Detroit Truetrac? Pull it out, crack open the carrier, weld it together, bolt it back together, and reinstall it (plus you messing up a perfectly good Truetac). Or buy a used open carrier, weld it, set it all up and install it.
IMO Lock the rear now and sell the Truetrac for $$$$ towards a front locker. When you get more cash then lock the front. Seems like it would be cheaper, easier to just set-up the axle once and be done with it. Verses have to do it a couple of times.
Old January 21st, 2006, 08:22 PM   #12
Tonka
Tonka's Avatar
locking the rear is better on hills due to the weight transfer to the rear.
note that this does not include pulling yourself over ledges. then the weight, and traction up front helps get the front over, and then pull the back over.
there's alot more that goes into it( Weight distribution, antisquat, weight transfer, etc.) but in general, locking the rear will have more benefit in more situations in a swb jeep.
Old January 21st, 2006, 09:00 PM   #13
Hacksaw
Hacksaw's Avatar
I have had 2 CJ's
one was welded in the rear only and one was locked in the front only
Before I got the rear end of the CJ welded that had the front locker in it, I like it alot better then just having the rear welded
so what I'm saying is that I liked having just the front locked as opposed to having just the rear locked.
After I finally welded the rear of the CJ with the locker in the front though, it was a whole new world.
Old March 7th, 2006, 07:36 PM   #14
UPNORTH
NO ORV STICKER NEEDED
UPNORTH's Avatar
Location: ONLY SOS PLATE NEEDED ON STATE TRAILS PER LAW!!
Originally Posted by HackSaw
I have had 2 CJ's
This is the only right statement of all the above and I have been there and done that so I have proof just like just stated.
UPNORTH is offline   Reply With Quote
Old March 7th, 2006, 07:55 PM   #15
user name
keep your stick onthe ice
user name's Avatar
After putting the locker in the front of my truck i started breaking axle joint like made eventually leading to the entire knuckle breaking off. I think lockers engage and disengage to harshly for the front and would lock the rear and get the tightest limited slip i could for the front asit would be much softer engaging on a wheel that might be cranked all the way to one side under power.
Old March 7th, 2006, 08:20 PM   #16
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
Cube....for rocks.....lock both or for everything else I think locked rear/tight limited slip front will get you just as deep into the muck before you have to winch yourself out anyway. :gman:
Old March 7th, 2006, 08:22 PM   #17
DuffMan
Your Message Here
DuffMan's Avatar
I have a TruTrac in the front, and as long as you have both front wheels in contact with the ground it's virtually as good as a locker, with few of the downsides. The TruTrac is a gear-driven LSD, unlike the clutch pack LSD in the Dana TracLoc.
It's a better-behaved alternative to locking the front and prevents losing turning radius. As my mechanic said "unless you're rock-crawling in Moab" the Tru-Trac front/Detroit Locker rear will do virtually everything in the midwest.
It's gotten me through stuff Rubis and other locked vehicles couldn't.
And I get some of the "cool, chick-attracting locker sound" when making tight turns on dry pavement. :tonka:
Old March 16th, 2006, 10:20 PM   #18
greenjeep
greenjeep's Avatar
With a trail rig I would weld a open carrier for the rear and get a lunch box locker for the front. People most likely have some open diffs just laying around you could get for next to nothing. sell your diffs to buy the front locker.
greenjeep is offline   Reply With Quote
Page generated in 0.33660 seconds with 77 queries
