91 front waggy 44 to become a tj front 44 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 12th, 2007, 11:00 AM   #1
nate4d
Gnarley Davidson
nate4d's Avatar
Send a message via AIM to nate4d
Default 91 front waggy 44 to become a tj front 44
im getting a front Dana 44 out of a '91 Waggy, 6 on 5.5, Driver Drop, 2.73 gears, open diff.. im looking to make it a bolt in for my 02 tj with a 4.0 i want to change the bolt pattern to 5x5.5 and i was looking for some help with a list of what i will need to buy. i want to wind up with a front 44 tj axle with a super 44 kit that has 5x5.5. anyone have a nice list of what i need and or where to get it? its a big project just getting some ideas of what to get. thanx a lot.
nate4d is offline   Reply With Quote
Old February 12th, 2007, 11:22 AM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Ain't happen to make it 5x4.5 bolt pattern. Change the rear to 5x5.5 to match Ford/Dodge hubs. If you really badly want 5x4.5 buy a rubi front.
Old February 12th, 2007, 11:26 AM   #3
PavementPounder
PavementPounder's Avatar
I agree. This comes up frequently and people go crazy thinking about ways to do it just to keep the 5x4.5 because they like their wheels or something. Personally, I would do just jump to 8-lug or do them as a 6-lug set.
Read this recent one for some info on the 5x5.5:
http://www.greatlakes4x4.com/showthread.php?t=35855
Old February 12th, 2007, 11:46 AM   #4
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Get wheel spacers or alloy shafts (best option) to convert your rear to 5 on 5.5
JcrOffroad
Zoom Zoom!
Old February 12th, 2007, 12:08 PM   #5
sodapop
Support the Sport!
sodapop's Avatar
I tried to find away and it just wasn't happening. Like monkeyevil said, I ended up going the adapter route in the rear. And for my gratuitous plug, I've got a rear waggy 44 that I'm wanting to sell if you're interested pm me. It's stock but has been stripped of brackets and cleaned decently.
Also just as some general info on making the front fit and usable. your going to need the following:
1. new gears ($115 - 150)
2. Install Kit ($75 -100)
3. new carrier for the gears (series 4 3.92 and numerically higher) - ($50 -70 on ebay)
4. may as well get new seals while you're in there ($21.99 x2 - Spicer 620257)
5. ball joints are a good idea. (about a $100 for good budget, about $160 for moog)
6. Lockouts if you're not going to run the slugs ($55 for MM, $90ish for Warn Premium)
7. Misc. brake parts (pads, rotor turning at a minimum, maybe new rotors and new calipers)
8. Misc. assembly parts (Gear lube, Brake fluid, Grinding wheels, welding etc)
if you want High steer and Crossover..
9. New flat top knuckles ($150 - 350: depends on if they are milled and drilled etc)
10. high steer arms ($100 - 200 depending on quality)
11. New drag link (depends on what you're gonna use)
12. New tie rod (depends on what you're gonna use)
I'm sure there are more parts that I'm forgetting but that's a good start. I figure that I'll have somewhere around $1100 into mine, it's going to be high/crossover steer but I'm not putting a locker in it. . .
Old February 12th, 2007, 12:12 PM   #6
Toivo
Feel lucky?
Toivo's Avatar
Won't be bolt in. Need to buy at least $300 (from my personal research) worth of bracketry (or make them) and be a good welder, other wise it will cost more to have someone weld them in for you. Not a good first time fab project, if you don't know how to do it, pay someone who does. The same goes for setting up the gears, axleshafts, etc.
Old February 12th, 2007, 03:13 PM   #7
Blackjackbender
I told you need to convert the waggy axle to 5x5.5 in the front and then get a super44 kit in the rear and set it up 5x5.5 or go for keep your regular 44 when you set it up for a 44 and get the axle shafts redrilled for 5x5.5.
Old February 12th, 2007, 05:10 PM   #8
sodapop
Support the Sport!
sodapop's Avatar
I'm not sure about a TJ 44 rear but I know there wasn't enough material in the flange of my 8.8 to redrill to 5x5.5.
Old February 12th, 2007, 05:29 PM   #9
Blackjackbender
I know superior rear 44 axles come with both drilling options so you should be able to redrill it to 5x5.5 but I believe he is going a super 44 rear so for sure he can run 5x5.5 in the rear.
Old February 12th, 2007, 05:57 PM   #10
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Or save some cash and just get alloy shafts with the correct pattern.
JcrOffroad
Zoom Zoom!
Old February 22nd, 2007, 03:53 PM   #11
nate4d
Gnarley Davidson
nate4d's Avatar
any have any experience with welding the brackets on for a tj front axle conversion? just looking for the best way to make sure we are centered before welding. we figure measure from center point and match measurements with a d30. any tips? thanx
Old February 22nd, 2007, 05:35 PM   #12
Jeepaholic
Jeepaholic's Avatar
TIP: Don't mess it up :tonka:
It isn't that bad. Measure twice weld once!
Page generated in 0.23453 seconds with 59 queries
