Toyota truggy (updated fuel injection) - Page 9 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 19th, 2008, 02:17 AM   #161
incogrhino
i pull out
incogrhino's Avatar
I got spare stock birfs if needed... just throwing that out there.
incogrhino is offline   Reply With Quote
Old March 19th, 2008, 04:25 PM   #162
Mud'N'Truck
I'll Finsh One, One Day
Mud'N'Truck's Avatar
Unless you want to hook me up, not really interested. Latly ive been breaking the stock ones to easly to spend any money on them. But just curious how much would you want for them?
Plato i know were your coming from. Theres alot of things i cant do there with out 4wd but i normally spend alot of time in 2wd any way though. I tend to try and prerun alot so ill still have alot of fun in 2wd hopfully
But yea we all need to do a big trip this summer
Old March 20th, 2008, 11:28 AM   #163
incogrhino
i pull out
incogrhino's Avatar
Don't know, just trying to help another birf brother out.
Old March 23rd, 2008, 11:10 PM   #164
Mud'N'Truck
This is what my new spring set up is
85 rear main
85 rear 2nd leaf mil rapped
6in front 2nd leaf
85 rear 3rd leaf
6in front 3rd leaf
6in front 4th leaf
Bottom
Heres about the difference with the new rear center pins over stock location centering pins.
Before
After
Looks like im going to have to trim the front bumper lower tub. Dont having to worry bout the tire rubbing on the back of the fenders any more It will sit up bout another 3in or so when its actully all together. Still on jack stands there and no axle
Cousin is shipping me out my ifs box tomorrow so hopfully that will be here soon. Got the old one out today. Also should be getting all my trusses and cross over steering soon. Having my brother make me knuckle trusses and shock mounts tuesday hopfully.
So now im pretty much just waiting on parts again
Need it done by the 2nd to put it on the trailer for silver lake
Always pushin it to the last minute
Old April 26th, 2008, 07:26 PM   #165
Mud'N'Truck
Got my new front springs on the front a little while back. Super soft. Flexs real sweet. Now i just have to put chevy leaves in the back so it flexs at all for corners and not just the front.
Just need to get my front driveshaft the right lenght. Retubed it but right before i left 4 silver lake but ended up being to long. It bottoms out when the front compress's. Going to get a long travel kit when i have the money to order it.
Also just ordered a few things from summit.
Auto meter trans temp gauge, and vacuum gauge
10x11x1.5 trans cooler
Poly motor mounts
And some new intake gaskets. Front and back were leaking oil. Didnt use enough sealer i guess
Old April 26th, 2008, 08:17 PM   #166
Mud'N'Truck
My adapter came loose at silver lake. Fixed it in the parking lot that night
Flex shot with the new springs up front. There quite a bit more left, shocks are to short
Pic with small tires with the new springs. You can see the amount moved forward by looking at the angle of the shocks
Axle after all the new armor
Old April 26th, 2008, 09:40 PM   #167
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
next time take the pics in the day....I's cant sees shit! :tonka:
Old April 26th, 2008, 10:17 PM   #168
Mud'N'Truck
Thats when i got it together and thought to get the carmra so deal with it:tonka:j/k
Ill get some better pictures later. Just thats what i had on my camra now so i figured id put them up
Old April 27th, 2008, 05:34 PM   #169
1badzuk
1badzuk's Avatar
looks sweet
1badzuk is offline   Reply With Quote
Old May 4th, 2008, 08:45 PM   #170
Mud'N'Truck
Alright got some day time shots today. Thats about as much as i can get out of the front right now with the brake lines and shocks that are on there.
Now i just need to do somthing about the back. Need to find me some 63in chevy springs
Old May 4th, 2008, 09:03 PM   #171
Mclovin
"The Situation"
Mclovin's Avatar
nice...
gona have it at the mounds for the opener ?
Old May 4th, 2008, 10:23 PM   #172
Mud'N'Truck
Idk. What day is opener.
I got a bunch of new stuff for summit the other day that i have to still put on and i need to redo my front driveshaft. When i moved the front axle forward my [ ] d-shaft was to short so i retubed the old stock one the night before i left for silver lake and didnt check it. Ended up being to long and bottoms out over bumps. So i need to cut that down.
And all my new stuff is poly motor mounts, auto meter vacuum gauge and elec trans temp gauge, big trans cooler and new intake gaskets there leakin in the back in the valley. Then a few other smaller things. So need to swap out motor mounts and im making a new center dash to mount the gauges. Then i have to drop the pan and notch it for my clearnce with my d-shaft and make a port for the sending unit for the trans. O and my trans cooler wont fit any were on the rad so i have to redo my fan set up and cut some of the front cab support out to fit it.
Few things, nothing to big just need to do it
Old May 4th, 2008, 11:08 PM   #173
Mclovin
"The Situation"
Mclovin's Avatar
may 17th
Old May 4th, 2008, 11:09 PM   #174
Mclovin
"The Situation"
Mclovin's Avatar
make sure to take pics when u notch that pan.. ive gota do mine more and i duno how far i can go... you got a 700R4 right ?
Old May 4th, 2008, 11:48 PM   #175
Mud'N'Truck
Yea. As far as i know there is a fair share of room on that back corner ( i have passanger side drop) I ended up denting it in to clear temparly put going to do it nicely when i have the pan off. Thinkin that i just take some 3in exhaust tube and use that for the notch in the pan.
O and ill see what i can do fbout being ready for the 17 and if i can get any of my friends to go ( trailer my truck lol)
Old May 5th, 2008, 08:24 PM   #176
Mclovin
"The Situation"
Mclovin's Avatar
Oh i have to notche the trans ittself ! i have pass drop too.. but an almost flat d300 Flat is good Fornt shaft clearance is not.. im just gona hog it good and smother the pan in RTV
Old May 8th, 2008, 07:28 PM   #177
KjMolt
USMC- 0311 Rifleman
KjMolt's Avatar
Very nice rig! looks like everything is going well! keep it up!
KjMolt is offline   Reply With Quote
Old May 8th, 2008, 11:04 PM   #178
Mud'N'Truck
Thanks
Tomorrow if im not to tried after work im going to start taking the front fans and etc off to figure out how im going to mount my trans cooler and remount the fans. Went and got all the hardware to put a drain plug on my trans pan and to put in my trans temp gauge sending unit. Probly do all that saturday afternoon and sunday. Fixing the nebiorbers truck saturday morning so i have to leave the garage open till thats done.
But yea its been workin pretty desent latly. Put a few miles on it today. Went to parts store and hardware then came home then went to the blue sky car show and meet stevelknevil (spelled wrong) there then came home then right back out to my cousins. Seems to be working good right now. Just trying to not burn my tires off. Been leaving to many black marks:tonka:
Old July 19th, 2008, 08:45 PM   #179
Mud'N'Truck
Default Time to update some
Descided to finally get some nice gauges just wasnt sure how to mount them. Ended up ordering a dash pod for a dodge ram and removed some and added some to make it work. Put a trans temp, water temp and oil pressure gauge in it. Got all electric sending units, didnt like my mec. old ones so it gave me a reason to get some nice ones.
Also put my new trans cooler on. Dont have any pic's of that yet. Also switched all my fittings on the motor to AN' fittings.
Now i just need to put my new poly motor mounts on, swap out my to 10in fans for the 16in i got and put my vaccum gauge on.
Now ive also deside that im going to just put dana 60s in my truck. Not going to mess with the toyota axles any more. Exspecly since i plan on building the motor more So all the above work with the axle was for nothing, o well
O and heres the picture and video i said id make from the start of the motor swap.
Old July 19th, 2008, 09:22 PM   #180
Mud'N'Truck
YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
Page generated in 0.50642 seconds with 84 queries
