Toyota truggy (updated fuel injection) - Page 8 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 17th, 2007, 10:24 PM   #141
Mud'N'Truck
I'll Finsh One, One Day
Mud'N'Truck's Avatar
Figured i update this
Been working on it all day today. Got my new headers on and are going to work great. No problems clearing the plugs like the last set. Now i just have to redo some of the exhaust.
Also got my new intake gaskets on. Alot nicer then the last set.
Got my alternator wires fixed from when they melted down when my alternator melted down. Got a 95amp alternator. Now i just need to get a new battery. Old one is shot. Tested it at work and got nothing.
Started swapping out my old broken power steering hose for my new one but it is a little different then the old one so im just need to figure out the best may to rought it away from the headers with the least amount of stress on the hose so it dont break again.
I just need to redo the exhaust, make my new plug wires, time the motor, put the front right birfield and seal in, put my front drive shaft in, run breather for the trans, get a belt for the power steering pump, and a few other things to do before its ready for mounds Thursday. Alot work little time.
Think that covers it all for now.
Old November 18th, 2007, 04:00 PM   #142
jared
Can't Worry About It
jared's Avatar
so is it gonna be reliable?
jared is offline   Reply With Quote
Old November 18th, 2007, 04:29 PM   #143
thormxboy420
FOUNDRY RATT
thormxboy420's Avatar
Send a message via AIM to thormxboy420
damn, i hope every thing goes good for you man, my buddy did a 350 swap in his 84 yota 5 years back and he loves it. great work by the way
thormxboy420 is offline   Reply With Quote
Old November 19th, 2007, 09:38 AM   #144
Mud'N'Truck
I plan on it jared. Built every thing with the intent of being every being able to run it donw the road and wheel it. Nothing to wild like a big cam, etc. You know how i wheel jared "Make it or break it" so ive been trying to make every thing relieable.
The few times ive driven it ive loved it. Tons of power and thats when i was still having problems with it not running right. Thanks, been trying to do every thing right and the way i whated it from the start.
Old November 20th, 2007, 06:45 AM   #145
bajatoy53
Raisin
bajatoy53's Avatar
It's still a beater, only with a heart transplant!
bajatoy53 is offline   Reply With Quote
Old January 14th, 2008, 01:00 PM   #146
Mud'N'Truck
Default Time For a New Update
What i though was a over pressuriving cooling system from bad head gaskets ended up being a the heater core inlet hose at the fire wall leaking bad. Thing is that you cant see the leak because it is behind the gromet at the fire wall. Only way i found it was when i set and held the engine at a higher rpm and waited for a leak. Sure not it wasnt coming from the intake gaskets being bad it was the heater core hose shooting it onto the back of the intake. So i just put new head gaskets and intake gaskets etc on to find out it was just somthing stupid. At least now i have a real nice set fel pro gaskets on there now. So for now i just turn off the heat and it doesnt leak.
Now i just need to get a different set of valve cover gaskets and it good to go hopfully. There leaking right down on to the exhaust so every time i stop some were it starts smoking bad.
Just need to time it in now and thinking i need to put a warmer therastat in cuz it doesnt even get warm enough going down the road to turn the fans on.
Been fun driving it today. No getting traction with the roads being wet, just starts spinning. Need to stop doing burn outs with the 37's luckly most of them have been when its wet out though
O yea and stupid thing i went to time it today and grabbed hold of the disturbotor to clock it and sure not i toached the coil wire and got zipped in one arm and out the other. Couldnt feel my arms for a good min or two.
If i get a chance i might try and get some videos up. And some pictures of the new V8 chevota emblems i had made today.
Old January 14th, 2008, 01:07 PM   #147
Mud'N'Truck
Got on excel and made a full list of parts that i have gotten for my truck. Put the part then how much then part # then were i got it.
Found out ive spent way to much $ in this swap
Heres my current parts list for just the motor and trans.
Motor / Trans
Block- .040 over sbc 350 (357)
Procomp heads, roller rockers
Arp head bolts
Fel-pro head gaskets
Fel-pro intake gaskets
Fel-pro Water Neck Gasket
Fel-pro Water Pump Gasket
Fel-pro oil pan gasket
Summit copper collector gaskets
Moly rings
Sealed Pro flat top pistons
Steel freeze plugs
Mr. Gasket rear main, valve cover Gaskets
Advanced Adapters Radiator
Cal Custom Chrome Valve Covers
Cal Custom Chrome Valve Cover Breather
Edelbrock Performer Intake
16LB Round Radiator Cap Blue
Exhaust Bends 2 1/2"
Exhaust Bends 3"
Exhaust pipe 3" 4'
2.5" to 3" reducer
Super 40 Flowmaster
Summit 168 SFI tooth flex plate
Arp fuel pump push rod
Summit 14x4 Air filter
Summit Mechanical Fuel Pump 110gph
Summit Distributor Hold-Down Clamps
Summit Adjustable, Single Feed Fuel Line & Gauge
Summit Timing Chrome timing cover
Summit Chrome Timing Tab
Summit Chrome Dipstick
Summit Gear to Gear timing set
Sanderson Cermic coated Shorty Headers
Summit Cam and lifters
Hydraulic Flat Tappet, Duration 272/282, Lift .442/.465
Hose sleeving kit
Chrome motor bolt kit
B&M mega shifter
Lokar Throttle Cable
Flex-a-lite Adjustable Electric Fan Controllers
Summit Electric Fan 10in 755cfm
Perma-Cool 10in 2100 cfm
Nylon fan mount kit
Taylor Fire Sleeve Boot Protectors
Billet Specialties Air Conditioning and Alternator Bracket Kit
Summit Timing Tape
Straight, Male -12 AN to Male 3/ 4 in. NPT
90 Degree, -12 AN Hose Barb to Female -12 AN
Straight, -8 AN Hose Barb to Female -8 AN
90 Degree, -8 AN Hose Barb to Female -8 AN
Straight, Male -8 AN to Male 3/ 8 in. NPT
Summit Polished Aluminum Water Neck
Summit 1/2" Phenolic Carburetor Spacer
Summit Water Pump, Short, High-Volume
Summit 160 Thermostat
Mr. Gasket Water Pump Pulley Shims
Summit Water Pump Pulley, V-Belt, 1-Groove, Aluminum
Summit Crankshaft Pulley, V-Belt, 2-Groove, 6.6 in Aluminum
ACCEL U-Groove Spark Plug, Shorty
Arp flex plate bolts
Arp oil pump shaft
B&M TV/Kickdown Cable
Painless Performance 700R4 Converter Lock-Up Kit
Summit Racing Billet Distributor Magnetic Pickup, Vacuum Advance
Summit Ignition Coil, High Output, E-Core, Epoxy, Black, 51,000 V
Summit Ignition Box, Rev Limiter, Digital, Capacitive Discharge
Taylor 8mm wire set
Summit Adjustable Throttle Cable Bracket
Trans-Dapt Performance Flexible Braided Stainless Trans Dipstick
Bosch Starter
95amp Alternator
700r4-bigger servo, boost valves, more clutches in the packs,
reworked valve body and stronger guts
Trans filter
Trans work- New input shaft, install output shaft
Torque converter 2300-2500 stall
Transfer case adapter + output shaft
Power Steering pump mounting kit
Motor and trans cost for all the things above
$6,446.27
Old March 16th, 2008, 01:14 PM   #148
Mud'N'Truck
Default Updates as of 3-16
Broke somthing in the front axle at the dog party and bent my tie rod in half so it was time to start tearing things apart. Descided to just pull the whole front end out.
So i got the front out and all tore apart and found that my driver side birfield blew up.
So now my plan is to truss the axle from end to end, put a inspection hole for the ring and pinion, and add front diff armor. Cut off all the tabs yesterday that i didnt need. Now i just need to get my parts. For now im leaving the shafts out till i can afford some longfields. Not putting stock ones back in ill just break them again.
And to fix the steering im switching to cross over steering. Getting the steering box off my cousin and then getting a kit for the rest.
Heres a few pictures ive put on the computer. I have more just havnt put them on the computer yet.
O yea and i almost forgot. Im getting my old rear springs back and im going to make a custom leaf back for the front. Going to use the rear main leaf and combine it with my front sky jacker lift leafs. Hoping to get bout 3 more inchs of height out of the front. Bring it back up to level or maybe a little more so it will settle level.
Old March 16th, 2008, 01:31 PM   #149
xj97sport
atv rider
xj97sport's Avatar
first time reading this .... damn thats bad f ing ass dude cudos to you
Old March 16th, 2008, 01:40 PM   #150
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
How about some longfields?
JcrOffroad
Zoom Zoom!
Old March 16th, 2008, 01:46 PM   #151
ddeadserious
ddeadserious's Avatar
ddeadserious is offline   Reply With Quote
Old March 16th, 2008, 01:52 PM   #152
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Originally Posted by ddeadserious View Post
Sorry I suck at reading
JcrOffroad
Zoom Zoom!
Old March 16th, 2008, 02:44 PM   #153
Mud'N'Truck
Alright heres a few pictures of way i pulled it all apart.
Before:
Current:
Thanks on the complments. Hoping to finsh cleaning up the axle today and may be get my springs taken apart.
Old March 16th, 2008, 10:20 PM   #154
Mud'N'Truck
Heres the housing after a couple more hours of grinding and smoothing things out i didnt like. Got it sprayed with primer. Now pretty much just waiting for my shipping quote to order my parts to finsh it.
Old March 17th, 2008, 07:19 AM   #155
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Sorry I suck at Penis
I know, that's why I really like you.
@clarkstoncracker
Old March 18th, 2008, 01:53 PM   #156
DiRtyJeepinGirl
I'll Be Your Dirty Girl
DiRtyJeepinGirl's Avatar
Send a message via AIM to DiRtyJeepinGirl
Badass truck!
DiRtyJeepinGirl is offline   Reply With Quote
Old March 18th, 2008, 05:39 PM   #157
Mud'N'Truck
Originally Posted by DiRtyJeepinGirl View Post
Badass truck!
Thanks, so when we going wheeling together:tonka:
If i ever get mine working for more then a day at a time
Old March 18th, 2008, 09:01 PM   #158
Pre4runner
Bike Dude
Pre4runner's Avatar
Looking good. i'm about to do the same thing on mine.... tear the front end out, something is loose.
Yea so when thats all together we need to wheel again!
Old March 18th, 2008, 09:37 PM   #159
Mud'N'Truck
For sure man. It was fun last time. Im hoping to have it ready to go by opening weekend of silver lake. Going to try and go friday to monday first weekend of april. Only be 2wd though. Cant afford longfields right now, just have a sweet empty housing
Old March 18th, 2008, 10:04 PM   #160
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
silver lake isn't fun with just 2wheel. I had to do that with my jeep after my build. It was better than not taking it thats for sure.... i just like messing around on the hills doing slow climbs.
Some idiots in one of the rental jeeps though they were better than me since they could get up a hill and i couldn't. I guess they failed to relize I had only 2wheel in the soft sand.
We'll have to get a mounds run together this summer though for sure.
Page generated in 0.54332 seconds with 84 queries
