Toyota truggy (updated fuel injection) - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 17th, 2007, 11:02 PM   #21
Mud'N'Truck
I'll Finsh One, One Day
Mud'N'Truck's Avatar
Thanks. Looks good from a distance. Last mounds trip played it toll on the body. Put about 6 good dents in the bed and back half of the cab. Huge strachs were the dents are. Both fenders are smached in on the bottom from jumping it and the tires hitting it. Paint lasted about 3 months before all that. Not to be a downer just telling it like it is.
Old July 18th, 2007, 10:20 PM   #22
Mud'N'Truck
Finely started putting the 350 in.
Got the old motor, trans, case, and almost every thing out in about 2 days. Engine bay preped and painted the next day. And started mocking the motor in by the 4th day. Lots of hours.
Very tight fit. Ended up making my own mounts and not using the ones i bought. Over all im going to have about 1/4in to 3/8in clearlance between the raditor and water pump.
Had to bet dents in the headers to clear my spark plugs and wires. But they clear the frame and motor mounts with no problems. Just have to make the rest of the exhaust.
Couldnt use my nice AN fittings on my fuel pump because it would hit the frame. Had to get a regular fitting from the local parts store.
Hood just clears the air filter. Didnt at first but i redid the mounts, after all that it clears. Also didnt clear the raditor before redoing the mounts.
Turning out real nice. Pain in the butt, but its turning out real nice.
Still have to go have the output shaft in my trans. Also have to finsh welding the motor mounts in. Then put the trans and case in. Getting close to finshing.
Old July 18th, 2007, 10:50 PM   #23
Mclovin
"The Situation"
Mclovin's Avatar
Ready for Sat ?
Old July 18th, 2007, 10:54 PM   #24
Mud'N'Truck
No, slowed the pace down when i found out that the group of friends going with me couldnt come.
Old July 18th, 2007, 11:01 PM   #25
Mclovin
"The Situation"
Mclovin's Avatar
so now you're not going ?? WTF ! i busted my ass to get my shit ready !
Old July 18th, 2007, 11:31 PM   #26
Mud'N'Truck
Yea me to. Its not my fault. I could have had it done but every one i was going with has had somthing happen. Thats means no one will trailer my truck up. Going make sure every thing is done and broke in the right way now, instead of huring. So now im not as worried about getting it done so fast. Hench being in here on the computer instead of out working on it.
Old July 19th, 2007, 12:19 AM   #27
nick_n_ii
nick_n_ii's Avatar
Send a message via Yahoo to nick_n_ii
Dude that is alot of motor for that truck and it looks soooo sweet
nick_n_ii is offline   Reply With Quote
Old July 19th, 2007, 01:42 AM   #28
Mud'N'Truck
Thanks. Going to be alot more fun then the 4cly was. :tonka:
Heres all the spec's on the motor.
PARTS LIST:
.040 over 350 (357)
Flat top pistons
.442 lift summit cam and lifters
Edelbrock Performer Intake
Cal Custom Chrome Valve Covers
ARP fuel pump push rod
14x4 summit racing air filter
110 gph Summit Mechanical Fuel pump
Fuel filter & presure Gauge ( screws in right on the carb, all in one)
Chrome timing cover and pointer
Summit gear driven timing set
Ceramic Coated hugger headers
Pro comp alumin heads, 64cc, angle plugs, pushrod gide plates
Pro comp roller rockers , locking rocker bolts
Arp head bolts
750 edelbrock carb
Chrome bolt dress up set
High volume oil pump
Built 700r4 trans-Bigger servos, bigger clutch plates, bigger gears
Accel shorty plugs .750 in. Reach
ARP flex plate bolts
ARP oil pump driveshaft
B&M kick down cable
Painless torque converter lock up kit
AN fittings for fuel pump
8mm plug wires
Summit sfi 168 tooth flex plate
2300-2500 stall torque converter
Summit billet distributor, vacuum advance
Summit igntion box, with rev limiter
Summit 51,000 volt coil
Chrome carb brackets
8mm coil wire
Braided Stainless/Aluminum Transmission Dipstick
High flow short water pump
Billet alumin water pump pulley
Billet alumin crank pulley
3in single exhaust- all mandral bent with super 40 flowmaster(3in inlet, dual 2 1/2 outlets)
B&M shifter
Dual 10in electric fans
Adapters:
-Downey
Motor mounts( ended up making my own)
Transfercase adapter plate and output shaft
Transfercase cross member mount plate
Oil pressure sensor adapter fitting
Temp sensor adapter fitting
-Northwest off road
Toyota power steering pump mounting kit
Alternator wire adapter
-Advanced adapters
4 core raditor
Parts pictures:
Old July 19th, 2007, 01:54 AM   #29
boggin-machine
boggin-machine's Avatar
killer motor man
Old July 19th, 2007, 10:05 AM   #30
Dave Kerwin
web wheeling, hard.
Dave Kerwin's Avatar
fits pretty good, very bling
Old July 19th, 2007, 12:48 PM   #31
Mud'N'Truck
Thanks. Its almost ready to start up. I just need to put oil in it and then prime the whole motor for oil. Then i have to set the roller rockers, and get the disturbutor set up right. And a few more little things.
Dont know if i have the right flex plate though cuz when i have the starter on it looks like it wont even reach the flex plate to turn the motor over. I dont know, see what happens.
Getting close though to starting it up.
Old July 21st, 2007, 12:09 AM   #32
Mud'N'Truck
Very tight fit. Got it finally mounted were i want it. To change the front belt on the motor i have to pull out the raditor to change it. To change my plugs and wires i have to take the headers off. To take the driver side header off i have to unbolt the motor mount and lift up the motor to get the header out.
And it does not fit under the hood. The spin nob that holds the filter on hits the hood support.
Alot of little stupid things like that but its going to be sweet. Cant wait to drive it.
Old July 21st, 2007, 11:15 PM   #33
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Time for bigger axles now!!!!
Old July 21st, 2007, 11:44 PM   #34
Mud'N'Truck
Going to try and build them first. Longfeilds and shafts in the front. Disk brakes, chromly shafts, hardened ring and pinion out back. Fully trussing them both.
Longfeilds are just as strong as a 35 spline d60. Try that set up and see what happens.
If i end up building the motor more later ill probley have to go bigger but they should hold up after building them.
Found out that i dont have to pull the motor to do the header, plugs and wires. Have to set the header in first then put the plugs in and then the wires on, then bolt the header on. Lots of fun.
Also finaly got the adapter to bolt to the transfercase. Got the shifter forks cut down enough to clear the plate.
Old July 21st, 2007, 11:50 PM   #35
Mclovin
"The Situation"
Mclovin's Avatar
I broke my shit today.. i blame you ! You didnt show up.. so i had to wheel with a jeep.. jeeps get stuck i had t pull one out.. broke my shit pulling a jeep out.. AGAIN !!!! See if you were there i wouldnt have had to pull my wheeling buddy out and i'd be good still
Old July 24th, 2007, 01:08 PM   #36
Mud'N'Truck
Got more of my stuff yesterday.
Got my-
b&m megashifter
heat sleaves for my plug wires
lokar braided throttle cable
10in electric fan
Flexlite adjustable fan control
Going to try and get it all together today. Still have to go have my trans done but cant get any one to take me. Sucks not having somthing to drive. Once the trans is done i can probly get it done pretty quick.
Old July 24th, 2007, 01:11 PM   #37
Rattler
Home Sweet Homicide
Rattler's Avatar
Just remember the rule:
Jeeps can only pull out other Jeeps.
Old July 24th, 2007, 01:20 PM   #38
guest
Send a message via AIM to guest
American Muscle in a foreign truck.lol. Only time I like a foriegn truck is with american powerd.lol. Nice looking truck for a small budget and only three years. That things gonna be pretty dang fast with that motor. That truck pry only ways like 3700 pounds or so probably.
guest is offline   Reply With Quote
Old July 24th, 2007, 01:29 PM   #39
Mud'N'Truck
Thanks
Thats my guess on weight to. That comes out to about 1hp to about every 9 pounds. Thats only about 2 or 3 pounds per hp then the new corvettes and ford gt's. Going to be alot of fun to drive.
Old July 26th, 2007, 10:39 PM   #40
Mud'N'Truck
Went and dropped my trans off today to have the output shaft put in. Also got all the stuff i just ordered from summit.
Bigger sfi flex plate- other one was to small
4ft 3in exhaust
3in U bend
2x 2 1/2in U bends
3in inlet, dual 2 1/2 outlet 40's flowmaster + free t-shirt
Push button for starter
Got my oil pressure and water temp gauges mounted and wired. Mounted the shifter. Filled the power steering fluid, started filling the anti freeze but ran out. Drained the gas tank(cheap out, 94 going in). Sucks draining a full tank with out enough gas cans, started using milk jugs. Swapped flex plates. Hooked strobes back up. Put grill on. Bolted axle in. Ran trans cooler lines. Mounted fan and controler. Few more little things.
Going to go pick up the trans before work tomorrow. Put it in when i get home from work.
Page generated in 0.33835 seconds with 84 queries
