How bad is running a lockrite locker in the front? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 10th, 2007, 12:08 AM   #1
disorder xj
Happy,happy,joy,joy
disorder xj's Avatar
Default How bad is running a lockrite locker in the front?
I would like to know how bad turning is going to be with a lockrite? I dont want to spend alot of money on axles I'm not going to keep for good. but i want lockers now.are they worth the money? this is a dana 30 in a xj
disorder xj is offline   Reply With Quote
Old February 10th, 2007, 01:05 AM   #2
One Arm Steve
I was born in the desert
One Arm Steve's Avatar
I put a Detroit in my 30. It takes a little getting use to. Turning at full lock (steering wheel left or right) is real rough on the u joints. The weak link will probably be the carrier. That's why I went with a Detroit it has a real solid case that should help things moving around in there to much. I know its still a turd though. Its going to have to do until I can go full width.
One Arm Steve is offline   Reply With Quote
Old February 10th, 2007, 06:44 AM   #3
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
It will be fine as long as you don't have a 242. If you do, you won't like driving it on the street in fulltime.
As far as the D30 being a "turd", I still haven't hurt a shaft or u-joint in 5 years of running one on 35" Boggers and Q78 Swampers. (I did bend a housing, but 3 turn barrelrolls are kinda tough on axlehousings) :tonka:
Old February 10th, 2007, 08:35 AM   #4
brimy311
Smells like a Fork Liftis
brimy311's Avatar
You definatly will not like using 4x4 on the street in the winter when you might need it. When you turn it will want to keep you going straight. I Image you could "get use to it", But it definatly is safer driving in 2wd in the snow/ice on the street then in 4x4 with a front locker. Thats My opinion on it.
JcrOffroad.com
Like us on Faceook!
Old February 10th, 2007, 03:58 PM   #5
disorder xj
Happy,happy,joy,joy
I dont drive in 4 wheel on the street alot . alot of the time I trail ride in2wd till I need 4wd. so it shouldn't be too much of problem.thanks guys
Old February 10th, 2007, 04:44 PM   #6
junk90xj
ALLPRO AUTO
junk90xj's Avatar
ive never had any problems with mine. on or off road.
well except for snow and ice
http://www.apalansing.com/
Old February 10th, 2007, 11:06 PM   #7
drummond
MTU 4x4
drummond's Avatar
I run a detroit in the front of my CJ (Dana 44) and I really like it. No switchs, lines or anything. A lock-rite is the same way. They are durable, inexpensive, and work well from what I have witnessed. They tend to have a distinctive clicking sound when turning, but it is something you will get used to. Turning will be fine. When I need to make really tight turns in my CJ, I just pop it out of 4WD, and then when I am done, throw in back in 4. Works fine
drummond is offline   Reply With Quote
Old February 10th, 2007, 11:17 PM   #8
slow96hater
rob
slow96hater's Avatar
this comin for a ford truck ttb front end guy, but i wouldnt do it. i had one for a while, but got sick of changeing axle shafts, and u joints. it may work better in a solid axle like your jeeps, but i'd stick to locked rear, and open front. most of the time, even in my big turd, my front hooks posi anyways, even tho its open, in the mud anyways. i dont do any sort of crawling. im strickly a mud guy.
rob.
slow96hater is offline   Reply With Quote
Old February 10th, 2007, 11:23 PM   #9
Cooter
Cooter's Avatar
So you are giving advice, even though you don't own a Jeep, know anything about them, or wheel anything but mud.
Just checking....
Old February 10th, 2007, 11:55 PM   #10
PavementPounder
PavementPounder's Avatar
Just checking....
Old February 21st, 2007, 04:16 AM   #11
jeeptjpaul
jeeptjpaul's Avatar
I have a Lock-rite in my D30. It is very tolerable to me. However, it does handle a bit differently on road. The biggest complaint is when one tire hits an ice patch during braking. My TJ does not have ABS, so that wheel tends to lock and drag the other with it. Besides that, I am going on 7 years with it installed and have never broken anything or had any problems with it.
jeeptjpaul is offline   Reply With Quote
Old February 22nd, 2007, 06:46 PM   #12
MB_Custom
Retro-Modder
MB_Custom's Avatar
I did it. I'll NEVER do it again. I bought a lock-right, cheap, threw it up front. Talk about an understeering beeatch. In deep snow or slick mud, the jeep went STRAIGHT, even with the wheel FULLY turned. I don't agree with the idea of popping it out of 4 to steer! Not an option on a snowy hill side with trees all around. From now on: Any locker in the rear is fine. Leave the front alone, or for serious wheeling get either a Truetrak or a selectable locker.
MB_Custom is offline   Reply With Quote
Old February 22nd, 2007, 09:25 PM   #13
Tonka
Tonka's Avatar
Gotta love that destructive sound when that happens!
Crrrrrrruuuunch!
I'm locked front and rear with Detroit E-Z Lockers.
Turning in 4wd on ice and snow takes throttle manipulation.
Like anything else. Once you learn how to drive it, and how it will handle, it's predictable enough to deal with. I've been just fine for the past 25,000+ miles.
Old February 22nd, 2007, 09:26 PM   #14
BMFmike
meh.
BMFmike's Avatar
It takes skill lol
Old February 24th, 2007, 03:40 PM   #15
Cooter
Cooter's Avatar
Did you only run a locker in the front? I have run them F&R, and have never needed to shift to 2wd to turn.
Ever.
Old February 24th, 2007, 03:52 PM   #16
tippy
SwampStomper
tippy's Avatar
i put a lock-rite in my wrangler and it is awesome with the exception of braking, it works like an open diff. except when one side spins it transfers power to the wheel with traction. based on the replies above the only one that i agree with is jeeptjpaul. it sounds like every one else is speeking of lockers where as a lock-rite is not truely a locker.
tippy is offline   Reply With Quote
Old February 24th, 2007, 04:15 PM   #17
Cooter
Cooter's Avatar
SPOBI
A Lock-Right IS a Locker
Old February 24th, 2007, 04:33 PM   #18
FlamesFearMe
Custom User Title
FlamesFearMe's Avatar
I had a lockright in my D30 and I drove that down the highway, for long distances to wheeling trips, and wheeled it at the Badlands, and never had a problem.
FlamesFearMe is offline   Reply With Quote
Old February 24th, 2007, 05:48 PM   #19
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
[QUOTE=Cooter;441358]Did you only run a locker in the front? I have run them F&R, and have never needed to shift to 2wd to turn.
Ever.[/QUOTE]
x2
Old February 25th, 2007, 09:42 AM   #20
Wehan
Wehan's Avatar
Why not just take it out in the winter and back in around spring?
Wehan is offline   Reply With Quote
Page generated in 0.71655 seconds with 83 queries
