Need some info on chevy 3/4 ton hubs - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 9th, 2007, 10:06 PM   #1
sjhenderson18
MEMBER
sjhenderson18's Avatar
Default Need some info on chevy 3/4 ton hubs
I picked up some disk brakes, spindles, hubs, and outer axles from what I believe is a 73-77 chevy 3/4 ton axle. The hubs had dust caps on them instead of manual lock out hubs. I was wondering if they are automatic locking some how or full time four wheel? I havent had to much luck searching so I was hoping you guys could help me with some info. I included a couple pictures below.
Attachment 6815
Attachment 6816
sjhenderson18 is offline   Reply With Quote
Old February 9th, 2007, 10:09 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
solid caps are full time hubs. do they have big solid gears inside?
Yetti
Old February 9th, 2007, 10:13 PM   #3
Yetti
Yetti's Avatar
I just clicked the picture..what the hell are those off of ?
Yetti
Old February 9th, 2007, 10:31 PM   #4
sjhenderson18
MEMBER
ill have to open them back up again to check the inside. I remember two spindle nuts and thats about it. I think they are off of a chevy 3/4 ton. but i am not possitive. I just know they are 8 lugs and the axle was passenger drop and it had ten bolts on the diff cover. They also look like chevy rotors. I just figured it was a chevy 3/4 ton d44.
Old February 10th, 2007, 08:21 AM   #5
GetItOffroadGMC
GetItOffroadGMC's Avatar
Looks like the 1 1/4 ton stuff.
GetItOffroadGMC is offline   Reply With Quote
Old February 10th, 2007, 09:32 AM   #6
Duramax04
Duramax04's Avatar
If I remember right the little dust cap covers the outer axle shaft. The part that it covers is the drive gear. In short, yes, they are full time hubs.
Duramax04 is offline   Reply With Quote
Old February 10th, 2007, 04:55 PM   #7
sjhenderson18
MEMBER
i dunno. they came off a 1o bolt front. it looked like a d44 to me.
Old February 10th, 2007, 04:57 PM   #8
GetItOffroadGMC
not sure then.....
Page generated in 0.28125 seconds with 47 queries
