axle tech - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 8th, 2007, 10:34 PM   #1
Blackjackbender
Default axle tech
what would it take to make a wagoneer axle 5x5.5? Just a new hub assembly and bolt it up? or would I have to change the whole outter setup?
Old February 8th, 2007, 10:45 PM   #2
One Arm Steve
I was born in the desert
One Arm Steve's Avatar
I'm no expert but I would think the knuckle and everything outside of that to include rotors calipers, and outer shaft. Do a Google search. Or do I have to do it for ya??
http://www.omgili.com/preview/aHR0cD...hwP3Q9NzYyMzY5
One Arm Steve is offline   Reply With Quote
Old February 8th, 2007, 10:53 PM   #3
Blackjackbender
okay so everything needs to be switch eh?
isnt there just a 5x5.5 hub that will bolt up eh?
i did google search after u mentioned it i was just being lazy at first.
Old February 8th, 2007, 11:08 PM   #4
possumjeep
possumjeep's Avatar
Im assuming your talking about the Dana 44 front axle
This wont get you flat top knuckles but if thats not an issue
if so you need this
Ford F150 73- 83 Dana 44 Front axle
Inner bearing
Cup
LM603011
Cone
LM603049
Outer Bearing
Cup
Lm501310
Cone
LM501349
Jeep 1981 J 10 Dana 44 front axle
Inner Bearing
Cup
LM104910
Cone
LM104949
Outer Bearing
Cup
LM501310
Cone
LM501349
as you can see the outer bearings are the same but the inner ones have different bearings but the races is the same
these are the part numbers from Napaonline.com
and youll need the ford hub part number Hub UP85943
and the a brake roter from the same years truck your calipers and brake pads will work
hope this helps
possum
possumjeep is offline   Reply With Quote
Old February 8th, 2007, 11:10 PM   #5
BIGBEN
All out Idiot
BIGBEN's Avatar
you can swap the entire outer from either a ford or a dodge axle to get the 5 lug pattern. that is the somewhat easier option.
if you want to have flat-top knuckles and chevy calipers with a 5x5.5 pattern there is a way.
you start with either a chevy or jeep flat top knuckle from a pre 1976 dana 44. this should have a spindle diameter of 1.75". you will also use the caliper plate and caliper from this axle. you then use the hubs and rotors from a ford axle, around a 78.
you are unable to use the spindles from a 77 or later chevy/jeep axle because the spindle diameter is bigger and will not fit the ford hub.
also the ford axle uses a different bolt pattern to mount the spindle to hte knuckle so you can't mix the parts that way.
Originally Posted by Stan View Post
My hope is that one day all women will realize just how well they could have it if they just shut their big fucking whining mouths.
BIGBEN is offline   Reply With Quote
Old February 8th, 2007, 11:10 PM   #6
One Arm Steve
Warn might make something for around a thousand dollars. What a joke!
Old February 8th, 2007, 11:52 PM   #7
Blackjackbender
I have one in my jeep right now
this is info for my buddies build im going to help him with.
Old February 9th, 2007, 01:26 AM   #8
Ebs
Chevy/Jeep small bearing spindle and Ford hub/rotor.
Old February 9th, 2007, 08:58 AM   #9
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
X2
I am just using the inner axle shafts and putting them in a narrowed hp44
Page generated in 0.26816 seconds with 50 queries
