Axle Question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 8th, 2007, 10:30 PM   #1
NoShow
Mmmmm Beeeer...
NoShow's Avatar
Send a message via AIM to NoShow Send a message via Yahoo to NoShow
Default Axle Question
Just curious what axles are under a 2003 F-250 gas motor...
I know it has 3.73 gears...
NoShow is offline   Reply With Quote
Old February 9th, 2007, 07:49 AM   #2
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Sterling 10.25, I think.
@clarkstoncracker
Old February 9th, 2007, 09:35 AM   #3
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
should be Dana 50 front and Sterling 10.25 rear
edit: the 10.25 became the 10.5 around 1999
Old February 9th, 2007, 11:20 AM   #4
bender
Your daily fullsize fix.
bender's Avatar
Send a message via AIM to bender Send a message via MSN to bender Send a message via Yahoo to bender
by '03 they went to a D60 up front and either a sterling 10.25 or 10.5 rear.
bender is offline   Reply With Quote
Old February 9th, 2007, 11:30 AM   #5
NoShow
Mmmmm Beeeer...
NoShow's Avatar
Thanks for the info...
Anyone else have this 5.4l? I get some real bad gas mileage. Only getting like 9 miles to the gallon. I know its big but my chev 3/4 ton was gettin at least 12...
Old February 9th, 2007, 11:32 AM   #6
bender
bender's Avatar
i've been getting 9-10 since it's been cold. was at around 12 this fall.
Old February 9th, 2007, 09:52 PM   #7
groundhog
groundhog's Avatar
He is correct....
They went to Dana 60 up front with the Superduty models in 98' sterling 10.25 or 10.5 rear
groundhog is offline   Reply With Quote
Old February 10th, 2007, 11:01 AM   #8
Jeeperz Creeperz
GL 4x4 Vendors
Service manual shows Dana 50 or Dana 60 for the front
10.5" for the rear.
Old February 10th, 2007, 11:04 AM   #9
Jeeperz Creeperz
GL 4x4 Vendors
Originally Posted by groundhog View Post
He is correct....
As an option, maybe. Most of the F250's I've seen had the Dana 50 up until 2003.
Old February 11th, 2007, 05:16 AM   #10
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
correct, the first years of the Superduty were a D50. and it wasn't even an option to get a d60 in the first years all d50 until 2003
also whoever mentioned 98...there was no '98 as Super Dutys came out early in '98 but were a '99 model year.
Similar to '96 when the YJ faded out and the '97 TJ appeared.
Old February 12th, 2007, 09:57 PM   #11
groundhog
groundhog's Avatar
The D50 must have just came in the gas motor trucks. I have a 2000 F-250 with the 7.3 Diesel in it and it has a D60.
If this is true then its new to me!!
Old February 12th, 2007, 10:57 PM   #12
chris1044
chris1044's Avatar
I've seen the 50 under the V8 model trucks - can't speak for the 10 cyl motor....
The pinion nut on the 50 is like 1/8" smaller than the 60 if that helps you out any
Old February 13th, 2007, 09:52 AM   #13
Jeeperz Creeperz
GL 4x4 Vendors
Yes, they came on the V10's also.
Old February 15th, 2007, 01:07 PM   #14
NoShow
Mmmmm Beeeer...
NoShow's Avatar
Anyone know best place to get a set of warn hubs? Mine was giving me problems locking in yesterday an dwant to get em changed before they take a shit... I have manual (plastic) hubs...
Old February 15th, 2007, 01:33 PM   #15
groundhog
groundhog's Avatar
From Jeeper Creepers, I just bought a set for my 2000 F250. you get 10% discount if you mention this site. I think it was $188.
Old February 15th, 2007, 01:37 PM   #16
xj4life
xj4life's Avatar
Think again, I've got a D50 in my '99. I havent pulled the cover to verify but from everything i've seen the SD's came with D50's up until '03ish. D50's are easy to mistake for D60's. They look very similar on the outside but the D50 has a D44 carrier and D60 outers
Page generated in 0.37036 seconds with 71 queries
