What vehicles come stock with dana 44's..... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 8th, 2007, 04:58 PM   #1
STOGIE
Speed Limit -186,000 fps
STOGIE's Avatar
Default What vehicles come stock with dana 44's.....
I'm just trying to put together a list of cars, trucks, suv's to salvage from.....
Thanks!
STOGIE
STOGIE is offline   Reply With Quote
Old February 8th, 2007, 07:43 PM   #2
tcxtreme1000
Mud Slut-Hit Every Hole!!
tcxtreme1000's Avatar
what do you want to put them in?
tcxtreme1000 is offline   Reply With Quote
Old February 8th, 2007, 07:44 PM   #3
tcxtreme1000
and front or rear.
Old February 8th, 2007, 07:50 PM   #4
STOGIE
STOGIE's Avatar
Both Front and Rear...... okay here's my ignorance.... are there different types of D44's that fit different types of vehicles...... I assumed that a D44 was a D44.... If it came on a F250 and a Explorer....I thought they could be interchangable....... But I was only thinking!
1999 TJ.......
Old February 8th, 2007, 09:06 PM   #5
Rears:
Hmm,
SWB Jeeps from ~1950 up
Wagoneers and J-trucks
rare xjs/mjs
Scouts
Isuzus
Nissans
Corvettes
Vipers
etc
Fronts:
Dodge rams & ramchargers/traildusters
Ford F150s/250s/broncos
Chevy 1/2 tons
Rubi's
Scouts
Waggies/J-trucks
Propably lots more.
Old February 8th, 2007, 09:10 PM   #6
Blackjackbender
do you want full width? or do you want a stockish width axle?
if its for a TJ or a XJ swap look at early bronco 44's
Old February 11th, 2007, 10:37 PM   #7
PavementPounder
PavementPounder's Avatar
Yes.
Old February 12th, 2007, 09:54 AM   #8
STOGIE
STOGIE's Avatar
Originally Posted by PavementPounder View Post
Yes.
I think this is one of the most informative posts on this web site yet!
Are you really that arrogant or does it just come accross in your posts?
Old February 12th, 2007, 10:00 AM   #9
Monster4.0
Monster4.0's Avatar
Some TJ's have a rear 44, ZJ's Grand Cherokees have rear 44's not sure if all of them do or not?
Those would be the easiest for the rear swap. The Rubicons have 44's but there not "true" 44's they are a hi-bred 30/44 35/44
A late model wagoneer is probably the best donor vehicle but you will need to weld all of your parts on to it to make it work. Coil buckets,shock mounts, sway bar mounts, track bar.....
Personally I'd do a isuzu rear (6 lug disc brakes) and a Wagoneer front (6 lug disc brakes) the wagoneers are available in driver or passenger drop. You can get a 4.30somthing gear ratio which would be perfect for 33's.
Old February 12th, 2007, 10:14 AM   #10
PavementPounder
Just a reminder of how you prefaced your question:
You asked one question in the particular post I replied to. I posted a correct and valid answer to that question. if you don't like that, ask better questions next time.
Old February 12th, 2007, 10:42 AM   #11
cornfed
I have an avatar. Yippee.
cornfed's Avatar
Are you daft, or did you not read the freakin' stickied Dana info thread atop this forum?
Old February 12th, 2007, 11:49 AM   #12
That'd be too much work to actually open the thread thats sitting right in front of your face with the answers. Thats almost as had as google. I can't never figure out how google works.
Old February 12th, 2007, 11:50 AM   #13
PavementPounder
People don't bother with that in the Marketplace, so why bother anyplace else?
Old February 12th, 2007, 11:54 AM   #14
ZJs with V8s got Dana 44, usually with an aluminum center section and c-clip axles. Called a Dana 44a. There have been issues with case flex causing failures. Locker selection sucks for these.
WJs also got them, I believe.
Rubicons are still dana 44s. Any talk about what axkeshafts and tubes they got not making thme 'true' dana 44s is internet forum silliness. They are dana 44s. Its the differential which makes the axle what it is.
As you can see, Dana 44 is a pretty broad term, which encompases many different axleshaft types, sizes, spline counts, ring and pinion types, tube strengths, lengths, etc.
Old February 12th, 2007, 11:56 AM   #15
PavementPounder
hi-bred 30/44 35/44.
I know why people call the front's "hybrid 30/44's" due to the D30 outer hardware, but where'd you get the "35/44" from?
Old February 12th, 2007, 12:01 PM   #16
Monster4.0
Monster4.0's Avatar
I made that part up to fool the stogie.
You sir are correct.
Old February 12th, 2007, 12:06 PM   #17
STOGIE
STOGIE's Avatar
Post the link..... I can't seem to find it..... nobody has ever accused me of being too smart!
Old February 12th, 2007, 12:19 PM   #18
OMFG! Its the FIRST F'ING THREAD ON THE PAGE!!!!
Please turn in your interweb license, you are not qualified.
Old February 12th, 2007, 12:21 PM   #19
PavementPounder
Old February 12th, 2007, 12:26 PM   #20
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
I have heard that they use the 35 tubes which are thinner than say a scout/waggy/etc 44.
Page generated in 0.44377 seconds with 83 queries
