question about conrtol arm manufacturing? - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 25th, 2007, 10:09 AM   #21
95geo
newbie
95geo's Avatar
Originally Posted by rockrat View Post
nope 3/16 plate steel, as far as axles; I just picked up 3/4 ton 44 front and a 60 rear 4.56 gears for 175.00
thats good to hear, just remember; its only as strong as the weakest link
Old July 25th, 2007, 10:20 AM   #22
rockrat
rockrat's Avatar
Originally Posted by 95geo View Post
great! you spent more than what a dom would have cost! how strong are your link MOUNTS?
thats fantastic that you overbuilt the shit out of your lower control arms, now how about the rest of the truck?
balance and weight conservation are key
figure out the cost of DOM, plugs, brackets, coils, springs, shocks and brakes and let's see who's is more expensive. As far as I see it, most of you can talk alot of bull, but ther's a few who can back it up. My geometry is correct, as I'm the 3rd in my club that has this set up; I'm just cheaper and stout. With 1000.00 mortgage gotta do what cha gotta do.
The frame rails are boxed 3/16" upper arms 2" soild also with 2.5" johnny joints off old lift. The only concern is with the full time case-the next to go.
rockrat is offline   Reply With Quote
Old July 25th, 2007, 11:05 AM   #23
95geo
newbie
95geo's Avatar
the only price difference i see is the dom/tube adapters vs. solid/tapped (if you choose to use adapters) having already machined the links for the JJ's i dont think it would be that much work to make some tube adapters to weld in.
to each their own i guess, everyone has diferent build theories.
you are correct, I know nothing about design or material choice.
post some pics.
Old July 25th, 2007, 12:45 PM   #24
kickstand
circling the drain
kickstand's Avatar
95geo sucks at fab work.
I am assuming this is for a TJ? why do you need 11" of lift?
Old July 25th, 2007, 01:07 PM   #25
He's good at working on stock sami's.
Old July 25th, 2007, 01:27 PM   #26
Maybe they are 11" longer than stock? That was my thought.
Old July 25th, 2007, 01:36 PM   #27
kickstand
circling the drain
kickstand's Avatar
I could be persuaded to believe that.....so rockrat? what is it?
Old July 25th, 2007, 01:55 PM   #28
rockrat
rockrat's Avatar
No, it's for a '97 Grand Cherokee.
Old July 25th, 2007, 02:14 PM   #29
rockrat
rockrat's Avatar
I'll be able to clear 37" 's, but will be staying with 35's. My wife is 5'4" and she doesn't want to use a rope ladder to get in. A friend of ours has an XJ with a similar lift; but his is more centered(too flexy), he's the white XJ at the last Four Wheeler Top Truck Club challenge"team foster"
Old July 25th, 2007, 02:54 PM   #30
Bones
Bones's Avatar
Originally Posted by Cooter21 View Post
We build ours from .120 wall DOM and tig all connections. I have never seen anyone including Aaron Brown use solid steel for suspension.
My uppers are 1 1/2", 1/4" wall DOM
My lowers are 1 3/4, 3/8" wall DOM
I bent my lowers on the maiden voyage....
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old July 25th, 2007, 02:59 PM   #31
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
3/16 is sheet not plate
Did ya box the lca mounts in?
Old July 25th, 2007, 03:14 PM   #32
95geo
newbie
95geo's Avatar
how long are your lowers? this has a huge factor in it.
my uppers are .120 and my lowers are .25, nothing has bent.
i wouldnt go any lighter but also not much heavier. with that much material a fabricated 3/16-1/4" control arm would be the next step, that way you can design for the forces that it will be seing rather than having the same strength in every direction when it isnt needed.
Old July 25th, 2007, 03:30 PM   #33
rockrat
rockrat's Avatar
if you mean did I use a skid plate, then yes. Before the L.A. I ripped off the stock on some rocks; these went on and I hit the same trail with minor scratches evident.
Old July 25th, 2007, 03:36 PM   #34
Bones
Bones's Avatar
I think either 34 or 36"
I'm still running it as is...
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old July 25th, 2007, 03:45 PM   #35
Was it bent somewhat smoothly, or kinked/dented?
FYI, 2.0" x 0.25" is about 15% stronger than 1.75" x 0.375" wall, in a bending moment, and almost 1 lb lighter per foot. Diameter makes a HUGE different in bending moment.
Old July 25th, 2007, 03:57 PM   #36
95geo
newbie
95geo's Avatar
but has trade-offs because it is also easier to dent.
what is the ideal size to stength to weight tube for control arms?
7075 solid 2"?
Old July 25th, 2007, 04:08 PM   #37
Yeah, thats why I asked how they were damaged.
Old July 25th, 2007, 05:25 PM   #38
Bones
Bones's Avatar
smooth, not dented
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old July 26th, 2007, 11:10 AM   #39
rockrat
rockrat's Avatar
my bad, the mounts are 1/4" . Anyways, I have to redo my steering; binding up and giving me attitude. Since it's just for the trails, it will be pipe with rod ends and yes I'll measure everything twice first.
Old July 27th, 2007, 10:25 AM   #40
rockrat
rockrat's Avatar
I've got the rig back will post pics soon.
Page generated in 3.10375 seconds with 83 queries
