question about conrtol arm manufacturing? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 8th, 2007, 09:20 AM   #1
rockrat
rockrat's Avatar
Default question about conrtol arm manufacturing?
My wife is going to make our long arms, but asked if it would be better to make them out of solid bar steel (8320) vice outta DOM? Through her shop, she can get solids a hell of lot cheaper than DOM.
She'll drill and tap the threads at each end. She wants to expand her old man's business into her 4x4 habit.
What's the census here?
pics added to page 4
rockrat is offline   Reply With Quote
Old February 8th, 2007, 01:14 PM   #2
Blackjackbender
It can be done and would be around the same stregth with DOM being a little stronger (1.5"x.25" wall) from what I gathered. I know DOM is about 11 a foot where solid i want to say is 4 from when I was researching this.
Could consider 2x2x1/4" as an option. With the solid you are going to have to run a threaded joint on both ends. and If you use a threaded poly joint at one end and a johnny joint at the other you are looking at about 80+ bucks for joints for a lower control arm.
Old February 8th, 2007, 01:24 PM   #3
One Arm Steve
I was born in the desert
One Arm Steve's Avatar
How much would one long arm weigh?? 40lbs or more??
One Arm Steve is offline   Reply With Quote
Old February 8th, 2007, 03:32 PM   #4
95geo
newbie
95geo's Avatar
unless you have the steel laying there and your a cheap ass i wouldnt do solid steel ever.
1.75-2.0x.25-.5 for lowers 1.5-2.0x.12 wall for most uppers. if you want to be blingin go with 7075 solid aluminum tapped for the joints on the end.
square control arms usually look hillbilly.
Old February 8th, 2007, 03:58 PM   #5
Strangler
Strangler's Avatar
I run solid. Have on three rigs. I think it is cheap, strong and easy to drill/tap.
Old February 8th, 2007, 04:13 PM   #6
Cooter21
Im Rick James Bitch
Cooter21's Avatar
Control arms a very important structural member to the suspention. All after market lift kits come with a huge disclaimer because of the potential carnage and abuse. We build ours from .120 wall DOM and tig all connections. I have never seen anyone including Aaron Brown use solid steel for suspension.
Cooter21 is offline   Reply With Quote
Old February 8th, 2007, 04:14 PM   #7
If the steel material is the same, solid stock will be stronger. But heavier, too.
For example, for a 3 foot link with 2" diameter (typical lower link)..
2.0" x 0.25" wall x 36" = 14 lbs
2.0" solid x 36" = 32 lbs
Solid bar is about 40% higher bending moment, per given size.
For equal strength, 2.00" x 0.25" wall = 1.75" solid bar.
1.75" solid x 36" bar = 25 lbs.
So, there's what you get.
However, as noted, thats same materials. Since DOM generally work hardens the piece, its stronger, so there's even a bigger weight discrepancy.
Aluminum is done with solid links because of two reasons: One, you need every bit of strength you can get with aluminum, and two, the type of alloy used fo rlinks is more or less unweldable, so its much easier to drill and tap.
Old February 8th, 2007, 04:38 PM   #8
Kawierider
Kawierider's Avatar
hmmm aluminum....we just found some 74(?) series stuff. nearly as strong as steel, more brittle though.
I think it was just AL and zinc....nothing else.......me want. (maybe not for LA's but it's a cool material)
Old February 8th, 2007, 07:03 PM   #9
Blackjackbender
alluminum links should be made out of 7075 i do not think 6061 or 6063 would hold up to well.
Old February 9th, 2007, 05:59 PM   #10
rockrat
rockrat's Avatar
she's a machinist, in case you didn't catch on, her dad owns the shop anyways just looking for ideas, as the machining business is tappering off.
Old February 9th, 2007, 06:04 PM   #11
rockrat
rockrat's Avatar
she makes wheel spacers, coil spacers and is trying to get her dad to order the tooling to do axles.
Old February 14th, 2007, 09:24 AM   #12
JINX
[QUOTE=95geo;
square control arms usually look hillbilly.[/QUOTE]
You are that stupid!
JINX is offline   Reply With Quote
Old February 14th, 2007, 10:08 AM   #13
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Is this for jeep lower control arms? That's seems awfully thin.
Old February 14th, 2007, 12:19 PM   #14
95geo
newbie
95geo's Avatar
until you have an ounce of fabrication knowledge please STFU
Old July 24th, 2007, 06:07 PM   #15
rockrat
rockrat's Avatar
used 2" x 32" soild for both lower ends as well as the rear uppers. Heavy yes, but at 120.00 for the steel, 250.00 for (4) 8" coils, 125.00 (4) 14.5" travel shocks=$425.00 for a 11" Long Arm Lift==priceless.
Old July 24th, 2007, 06:56 PM   #16
nosilla
And knowing how to do Math is very priceless $495 is the total
nosilla is offline   Reply With Quote
Old July 24th, 2007, 09:17 PM   #17
95geo
newbie
95geo's Avatar
great! you spent more than what a dom would have cost! how strong are your link MOUNTS?
thats fantastic that you overbuilt the shit out of your lower control arms, now how about the rest of the truck?
balance and weight conservation are key
Old July 24th, 2007, 10:18 PM   #18
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
My guess is stock POS TJ axle brackets.
Old July 25th, 2007, 11:07 AM   #19
rockrat
rockrat's Avatar
still alot less than than claytons,RE,kevin's and others.
Old July 25th, 2007, 11:08 AM   #20
rockrat
rockrat's Avatar
nope 3/16 plate steel, as far as axles; I just picked up 3/4 ton 44 front and a 60 rear 4.56 gears for 175.00
Page generated in 0.58908 seconds with 83 queries
