chysler 8.25 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 5th, 2007, 06:51 AM   #1
yogi
swampstomper & old fart
yogi's Avatar
Default chysler 8.25
Whats the good and the bad on these axles
yogi is offline   Reply With Quote
Old February 5th, 2007, 08:05 AM   #2
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
97 and newer - 29 spline. Older ones are 27. People compare their strength to a D44.
If you have a 29 spline, only lunchbox locker available is a powertrax no-slip. Cheapest price is at rocky road.
I wheeled my XJ fairly hard for 2 years and never had an axle problem, but I never ran tires bigger than 32's.
Silly rubber plug on diff cover.
@clarkstoncracker
Old February 5th, 2007, 04:10 PM   #3
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
You can replace the cover with an earlier on with a fill plug- Chrysler has made the 8 1/4 since the early 70s.
Old February 5th, 2007, 04:30 PM   #4
Blackjackbender
I believe you can get ARB lockers now actually.
I think cherokee666 has one in the rear of his jeep.
Old February 5th, 2007, 07:48 PM   #5
yogi
yogi's Avatar
thanks i got a 92 so its probably a 27 spline
Old February 5th, 2007, 07:52 PM   #6
disorder xj
Happy,happy,joy,joy
disorder xj's Avatar
Its the only part that hasn't broke on my 99
disorder xj is offline   Reply With Quote
Old February 16th, 2007, 02:37 PM   #7
h8pvmnt
Swamp Stomper
h8pvmnt's Avatar
I bought a steal pipe reducer from Home Depot and welded it on to the cover and then just used a pipe plug, that I also bought from H.D.
h8pvmnt is offline   Reply With Quote
Old February 16th, 2007, 02:39 PM   #8
h8pvmnt
Swamp Stomper
h8pvmnt's Avatar
They have quite a few XJ's at parts galore over by my house Yogi. I can see if they have some 29 spline's there.
Old February 17th, 2007, 12:06 AM   #9
nick_n_ii
nick_n_ii's Avatar
Send a message via Yahoo to nick_n_ii
The 8.25 houseing is stronger than a Dana 44, Tubes are thicker also...
nick_n_ii is offline   Reply With Quote
Old February 17th, 2007, 12:18 AM   #10
One Arm Steve
I was born in the desert
One Arm Steve's Avatar
I have the 29 spline with a Detroit and the cheap 99.00 Alloy axles. Run 35's and have had 0 problems.
One Arm Steve is offline   Reply With Quote
Old February 17th, 2007, 01:41 PM   #11
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
I'd have to argue that one.....
Jeeperz Creeperz, Inc.
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
www.jeeperz-creeperz.com
Old February 20th, 2007, 08:44 AM   #12
yogi
yogi's Avatar
cool let me know
Old February 20th, 2007, 09:43 AM   #13
PavementPounder
PavementPounder's Avatar
Just buy this MJ D44.
http://www.greatlakes4x4.com/showthread.php?t=36451
You have to put perches on it anyway, so you can set the pinion angle to exactly what you want at the same time.
Old February 27th, 2007, 12:21 PM   #14
Hubbler
Hubbler's Avatar
I like the 8.25 I have. I've got the 27 spline and run 33" locked and have no troubles. The shafts end up neckin down to smaller than a D44 shaft but I havent broken one yet. Plus the axle is easy to build cause there are no carrier shims. Just a large screw over the bearing to set your backlash.
Hubbler is offline   Reply With Quote
Page generated in 0.34210 seconds with 65 queries
