93 Astro V8 powered with BB Chevy 462 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 3rd, 2007, 09:54 PM   #1
zook94
Resident Jerkoff
zook94's Avatar
Location: Saginaw, Michigan, USA, North America, Earth, Milky way
Default 93 Astro V8 powered with BB Chevy 462
1993 Astro EXT 2wd
TBI 305 runs and drives perfect, but throws a stupid ABS code. (brakes are all new, just the controller is dumb)
Rust free body, all front end components replaced @ 5k miles ago
New LeMans tires 235/70/15
The extras:
462 Big block Chevy engine from 79 Suburban (454 bored .040, double roller chain and gears approx. 10k on engine)
1993+ TBI intake for BB engine
TBICHIPS.COM custom burned chip for engine/transmission combo
Trans-go shift kit w/corvette servo
Summit K-1301 cam and lifters
Kwik performance bracket kit for factory bracket use
Airtek NEW reverse rotation water pump
Hooker long tube headers used, but mint.
Weld in bung for heated O2 sensor
Essentially all that needs done is bolt all the goodies to the big block and drop it in. The engine will fit without modification to the doghouse or floorboards.
Parts that are needed for big block finalization:
Morse engineering 53MM bored TBI unit (spoke with Roy, $195 shipped to perform on an original Astro TBI)
454 injectors
Heated O2 sensor
Tranny needs a front pump seal while things are apart, it drips a wee bit, right on the exhaust crossover, very annoying.
The van is located in Saginaw, and can be driven anywhere as is.
$3000. Sorry no trades, don't even ask.
zook94 is offline   Reply With Quote
Old February 4th, 2007, 03:53 PM   #2
thunderace31
Owner SuperbDecals.com
thunderace31's Avatar
Originally Posted by zook94 View Post
1993 Astro EXT 2wd
The extras:
454 injectors
Heated O2 sensor
Still have this and what if I dont want the BBC how much less that stuff ???
Is the 305 in good shape and how many miles are on the eng in the truck
Thanks
Derek
thunderace31 is offline   Reply With Quote
Old February 4th, 2007, 04:40 PM   #3
zook94
Resident Jerkoff
zook94's Avatar
The engine had around 70k on it when installed in the van. When it sits for long periods, it does the GM puff, but does not smoke. New style valve seals would fix that right up.
$1800 for the van by itself. Drive it home, or anywhere you desire.
Old February 4th, 2007, 06:00 PM   #4
351wstangglx
It does stuff...
Send a message via AIM to 351wstangglx Send a message via MSN to 351wstangglx
sleeper to the max
351wstangglx is offline   Reply With Quote
Old February 6th, 2007, 09:28 AM   #5
zook94
Resident Jerkoff
zook94's Avatar
This doesn't belong on page 3.
Page generated in 0.39212 seconds with 38 queries
