Pale horse; A TJ pile of parts - Page 8 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 18th, 2009, 10:17 AM   #141
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
Originally Posted by benny87 View Post
Just wondering, why didnt you just make a truss that went and bolted to the 8 bolt on the houseing. Thats what they are there for..
Honestly I didnt like the look. Pure and simple.
I'm the man in White.
Old June 18th, 2009, 11:42 AM   #142
95geo
newbie
95geo's Avatar
Then you didnt put enough time into the design you can make them look seamless if you want. The poly truss does look pretty sweet though.
Scooter shoots from the hip!
I would tie that truss into the top of the housing though, it'll make a huge difference in strength. Most upper trusses that arent tied in to anything bend or fail wihin the first few trips until they are.
Progress looks good.
Old June 18th, 2009, 01:20 PM   #143
Skooter_Built
Yep, thats what i plan on doing. I need to spend time tonight deciding how i will do so. Tonight Ill be cleaning up the frame, trimming the body and building the new rear frame.
Old June 18th, 2009, 08:59 PM   #144
C.K.
Dont Feed the Cyco
C.K.'s Avatar
Did I mention ghey ?
J/K looks good Skoots
C.K. is offline   Reply With Quote
Old June 18th, 2009, 11:18 PM   #145
Skooter_Built
Today I got the rear frame all cleaned up and trimmed off the bottom of the tub.
Tomorrow I'll chop off the rear section of the frame and build a new one and then finish fitting the truss.
Old June 20th, 2009, 01:30 PM   #146
Skooter_Built
well last night before the power cut out, i cut off the rear frame, cut the rear cross member off the frame, and fitted the truss to the axle.
Old June 22nd, 2009, 11:19 PM   #147
Skooter_Built
more work was done today. I fitted the truss to the axle. A little grinder action and a BFH did the job good The rear frame is on its way to being finished. I cut the factory rear cross member off(need to clean it up) and started to create the new rear frame. By tomorrow night ill have the new frame tacked in. Gussets and rear coilovers mounts by Wensday
Old June 29th, 2009, 03:34 PM   #148
Skooter_Built
This weekend I got the largest piece of actual fab work done, I finished up the rear frame and burned it all in. It came out pretty nice and im happy with my work, ill throw up some pics later. I still need to add some plating but the hard work is done. Finally after what seems like forever all this will be in my possession tomorrow
This weeks goals: Mount the rear coilover mounts, redo the front coilover hoops, mock up the rear suspension & front steering and do some more trimming. I soon have to decide on what flavor of 39's-40's ill be running; Pitbull Rockers, Iroks, MTR''s, Creepy Crawlers... All depends on what I can afford
Old June 29th, 2009, 03:49 PM   #149
NitzPixs
It Lives once again!!!!
NitzPixs's Avatar
Sweet Cable shifter, that should make the install easy. My is the linkage type that came with the Stak t/case and was a big pain to setup...
NitzPixs is offline   Reply With Quote
Old June 29th, 2009, 04:06 PM   #150
Skooter_Built
Ya, i saw that. I now will have 5 sticks in my Jeep to play with; 3 for the t-case, 1 for the trans and the parking brake lever to lock up the rear output. Oh joy I need to build a new center counsole to make things fit.
Old June 29th, 2009, 04:29 PM   #151
NitzPixs
NitzPixs's Avatar
LMAO...yep same here. So why your at it build two center consoles. I would like mine to be able to hold my CB too....Let me know when it's ready...
Old June 29th, 2009, 04:42 PM   #152
Skooter_Built
ill be building them out of blingtanium so ill just send you the bill ok
Old June 29th, 2009, 06:34 PM   #153
95geo
newbie
95geo's Avatar
That 4 speed isnt that long, anyone know if you can turn a 2 speed into a 4 speed?
Looks good!
Old June 29th, 2009, 06:37 PM   #154
Tab
Tab's Avatar
the front of the case is machined differently than a 2sp but almost everything else is the same. maybe they will sell you a front case half and the reduction box.
Old June 29th, 2009, 06:52 PM   #155
Skooter_Built
you can always just run a Klune-V(1 on pirate right now) or a Northwestfab BlackBox to make a 4 speed.
if i remember right the 4 speed only adds on 6-7"
Old June 30th, 2009, 08:02 PM   #156
Skooter_Built
OH YA OH YA OH YA!!! 4 Speeds of fun and this dont require any batterys
Picking it up
At home
Stripped naked and very sexy
Old June 30th, 2009, 09:16 PM   #157
gmotox
gmotox's Avatar
looks like its coming along good!!!
Old June 30th, 2009, 09:49 PM   #158
Mclovin
"The Situation"
Mclovin's Avatar
whats with the trailer ?
Old June 30th, 2009, 10:25 PM   #159
Skooter_Built
i was waiting for someone to be inquisitive. I got a Super Duty front 60 in the bed, Im waiting on the "axle guru" to finish narrowing my new front 60 for my TJ. Its part of a trade deal.
Old July 1st, 2009, 09:00 AM   #160
BUTLER
Monkey Crawler
BUTLER's Avatar
Skoot, Everything looks good but I think you need some self etch / weld thru primer on off of that bare metal we talked about
and
I bet that trailer looks even better behind your truck when you wearing your pimp hat
BUTLER is offline   Reply With Quote
Tags
fail horse, jpfab homerun, jpfab rocks!, lol--->, part out 2012, thanks mom, the scooter eats, white poop
Page generated in 0.49067 seconds with 84 queries
