Pale horse; A TJ pile of parts - Page 7 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 13th, 2009, 08:44 AM   #121
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
Originally Posted by trogdor the burninator View Post
cant wait to see it dude, why did you decide on coilovers and not something like air shocks or emulsion?
i chose coilovers because this Jeep isnt on any diet, its a fat pig. Plus it will still see plenty of street time.
Originally Posted by VonDirt View Post
its looking good - nice work
on the 90 hoops; are your coils going to clear the frame ok when its flexed out ? i dig'em stealth - tucked inside like that
It appears that they will At this moment im more conserned about the steering hitting the frame.
Originally Posted by C.K. View Post
ghey
your bald
I'm the man in White.
Old June 13th, 2009, 09:00 AM   #122
Skooter_Built
its hard to notice but the tierod is sitting on the frame, ive used bolts for lower shock tabs and did everything real ghetto/slopply just to mock things up. Alot more work needs to be done today.
Old June 13th, 2009, 09:05 AM   #123
redmud
10 0011 10101
redmud's Avatar
ghey
X2
Also, I'm glad the kustom paint we did on your knuckles and steering held up and you took good care of it.
BDS Suspension
How can you land a space ship on the moon? How can a snake eat an aligator? how does the internet work? some questions are not meant to be answered by man alone.
redmud is offline   Reply With Quote
Old June 13th, 2009, 09:52 AM   #124
Skooter_Built
Originally Posted by redmud View Post
X2
ya, wtf did you tards use, cause it sucked!
Old June 13th, 2009, 03:59 PM   #125
Did you flex it out at all or just check it at ride ht?
Old June 13th, 2009, 04:19 PM   #126
Yep, like everyone says, really check the worst cases for clearance. Its a balancaning act of getting them not to hit the frame at droop or the tires at full stuff.
Old June 13th, 2009, 05:08 PM   #127
Skooter_Built
ya, itss gonna be a real tight fit, i did flex it but it hits the high steer tie rod real fast, so i have to modify the front frame section. I always knew this was going to be the trouble but i have seen a few solutions that others have done or i cut off the factory frame right after the motor mounts and build my own.
Old June 13th, 2009, 08:31 PM   #128
JeepMann
10 Years
JeepMann's Avatar
Send a message via AIM to JeepMann
If you are going to cut the frame its hard to do after the motor mounts because of the funky shape to the frame and the angles it comes out at. I planned on doing that but then decided doing the pie cuts to straighten the front out was going to be a better choice in the long run.
JeepMann is offline   Reply With Quote
Old June 14th, 2009, 10:19 AM   #129
Skooter_Built
ya, after looking it over i first will start by lowering my coilover hoops down 3" and then will pie cut the frame like you did.
Today im gonna strip down the rear axle, chop the rear frame off, and start mocking up the rear suspension & coilovers.
Old June 14th, 2009, 11:16 AM   #130
Heh, on my CJ, I ended up having to add 6" of width to my axles to get the shocks to clear. Its certainly a PITA to get it all t fit...
Old June 14th, 2009, 12:24 PM   #131
bbaXJ
Yooper In Training
bbaXJ's Avatar
Lookin good Andy.
Based on this picture I'd put money on the fact that your coilovers are gonna hit the frame and tires when flexed.
Looks like you just don't have enough space to clear no matter how you angle them. I have a narrowed frame and fullwidth axles and can still just barely kiss my coilovers on the frame and tire at worst-case....but I also have bigger coilovers. Between that and the steering I'd say you've got some frame mods in your future.
Old June 15th, 2009, 07:08 AM   #132
Skooter_Built
Originally Posted by bbaXJ View Post
Lookin good Andy.
ya i will have to take that into consideration. Since i have to lower the coilover hoops i will be angling them out, somewhere 5-20 degrees out. Plus i can always move up the axle mount.
I started stipping the rear axle yesterday, and all i have to say is DAMN! the brackets from Rock Crusher are thick. I have the same rear axle that Doc Brad has
Old June 15th, 2009, 01:52 PM   #133
Measurements I used for the frame notch here if it helps at all.
http://www.greatlakes4x4.com/showpos...&postcount=104
Loving those loovers, haven't figured out a way to make my own yet
Old June 15th, 2009, 02:01 PM   #134
Skooter_Built
Thanks, and just wait till you see what im having done to the hood.
Old June 15th, 2009, 03:48 PM   #135
nate4d
Gnarley Davidson
nate4d's Avatar
Send a message via AIM to nate4d
arent u replaceing that front axle anyway?
nate4d is offline   Reply With Quote
Old June 15th, 2009, 09:33 PM   #136
Skooter_Built
yes, next year/this winter. I could cut the brackets off of it but that would make it more difficult to sell later on. Its a complete bolt in unit right now, so i will work with its limits.
I almost finished stripping/grinding down the rear axle. GOT DAMN!!! Rockcrusher axle manufacturing sucked ass with welding, goober welds almost 3/4" thick for the fawking shock mounts, just plain sloppy welds. However a plasma torch and grinder takes care of everything. I placed the truss on the axle and only have some slight trimming to fit it perfectly.
Old June 15th, 2009, 10:11 PM   #137
bbaXJ
Yooper In Training
bbaXJ's Avatar
You're gonna angle the top of the coilovers out further? Am I reading that right? Besides the fact that they'll be operating at weird angles, especially under flex, the tires will crash into them BAD.
Old June 17th, 2009, 02:15 PM   #138
xj-james
Original Gangster
xj-james's Avatar
Very impressive I am inspired to say the least!
xj-james is offline   Reply With Quote
Old June 17th, 2009, 09:54 PM   #139
Skooter_Built
more work done today, rear axle is stripped clean. I have never seen such shitty welds on an "expensive" axle before. There were goober welds 3/4" wide, 3/4" thick holding on the shock mounts and a few other brackets.
I tacked the truss on to mock the rear suspension up. Im not 100% happy on how the rear truss is sitting, due to how the axle is cast. Im thinking of having the top milled/ground down so the truss sits flat and i could use the 4 mounting spots on top of the axle. I can only take 1/4" out of the back of the truss and that isnt enough.
I also cut off the rear suspension mounts off the frame. Just need to grind things down and fill in a few holes.
Old June 18th, 2009, 08:18 AM   #140
benny87
Young Gun..!
benny87's Avatar
Just wondering, why didnt you just make a truss that went and bolted to the 8 bolt on the houseing. Thats what they are there for..
benny87 is offline   Reply With Quote
Tags
fail horse, jpfab homerun, jpfab rocks!, lol--->, part out 2012, thanks mom, the scooter eats, white poop
Page generated in 0.67905 seconds with 84 queries
