Pale horse; A TJ pile of parts - Page 35 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 17th, 2010, 10:19 AM   #681
Unsubscribed, I'll tune back in for the part out.
Old December 17th, 2010, 10:23 AM   #682
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Originally Posted by Skooter_Built View Post
just pulling your chain. I got them just lying around
I like you. You can come over to my house and fukc my sister.
@clarkstoncracker
Old December 17th, 2010, 10:45 AM   #683
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
Never going to happen, tube for the front links and steering is getting bought Monday.
Don't shit me man!
I wouldn't shit you, you're my favorite turd!
I'm the man in White.
Old January 5th, 2011, 10:49 AM   #684
Skooter_Built
Ive been slowly working away for the last couple weeks and have gotten some good work done. Ive got the steering built, Im using 1-3/8" .120 wall DOM for the tierod, trac bar and draglink. Im waiting on a longer passenger side steering arm and need to drill out my pitman arm for a bigger bolt. As of right now everything looks like it will fit, very tight but it should be good.
Today Im picking up my tube so I build my 3 link tonight. The 3 link brackets are set in place and the frame is prepped so building things should be pretty easy. Once I get the front suspension set I can bolt on the coilovers and see if I have to modify the mounts.
Little shit that Ive done is put together my Yukon Chromo shafts & Longfield u-joints, buy conversion brake brackets for the front so I can run Chevy style calipers; Ill be using dual piston aluminum calipers front and rear, mock up my front sway bar... I need to finish cleaning up the front end parts but its close to being finished.
Old January 5th, 2011, 10:54 AM   #685
bigbchevy
missmrgreenagain
bigbchevy's Avatar
looking good!
H.o.r.e
Old January 5th, 2011, 02:25 PM   #686
Strangler
Strangler's Avatar
Done yet?
Tell your landlord to clean the shop.
Old January 5th, 2011, 02:33 PM   #687
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Originally Posted by Strangler View Post
Done yet?
i cleaned it last
H.o.r.e
Old January 5th, 2011, 03:04 PM   #688
Strangler
Strangler's Avatar
Im just tired of being the mop every time i'm over there.
Old January 6th, 2011, 11:07 AM   #689
Skooter_Built
I got more work done last night; I built the lower links, got the 3 link brackets tacked on and tacked on the axle lca bracket. Tonight Ill build the upper link, tack on the truss mount and then mount the coilovers.
I need to get the longer passenger high steer arm mounted before I can finish weld everything, to make sure the steering clears. As of right now Im very close to having everything almost perfect, Im less then a 1/2" off and thats with using undersized bolts
Old January 19th, 2011, 10:41 AM   #690
Strangler
Strangler's Avatar
Default Silly question.....
Why use high $$$ high steer if its the first thing to contact your frame, and limit uptravel?
Name:	Jeep Parts 070.jpg
Old January 19th, 2011, 11:10 AM   #691
Skooter_Built
Cause that is the point of its function.
Old January 19th, 2011, 11:15 AM   #692
Strangler
Strangler's Avatar
Oh boy.
Just finish it so I can pick on it.
Old January 19th, 2011, 11:19 AM   #693
Skooter_Built
Oh boy.
We are both guilty of doing stupid things no one is innocent. Ill be working more on this Saturday and Sunday.
Old January 19th, 2011, 11:22 AM   #694
bigbchevy
missmrgreenagain
bigbchevy's Avatar
ill believe it when i see it! hahahaha
H.o.r.e
Old January 19th, 2011, 11:55 AM   #695
Skooter_Built
Sure thing Dennis Anderson
Old January 19th, 2011, 07:47 PM   #696
bbaXJ
Yooper In Training
bbaXJ's Avatar
If mine is done before yours I reserve the right to park on your shines white hood
Old January 19th, 2011, 07:57 PM   #697
bigbchevy
missmrgreenagain
bigbchevy's Avatar
wanna race!
H.o.r.e
Old January 20th, 2011, 09:43 AM   #698
Skooter_Built
wanna race!
How bout we have a tow off
I got another pile of brackets last night, I'm gonna try to get the front suspension & steering buttoned up this weekend. I also wanna try reassembling 1 side of the axle so I can get a tire on it to check for clearances.
I wish I had more time to work on this damn Jeep, stupid education keeps getting in the way
Old January 20th, 2011, 09:51 AM   #699
Probably a bad time to tell you this but once your "learning" is done, the real learning begins and you'll have even less time
Old January 20th, 2011, 10:04 AM   #700
Skooter_Built
Well when is learning ever done? At least when college is over I can stop my 14hour days
Tags
fail horse, jpfab homerun, jpfab rocks!, lol--->, part out 2012, thanks mom, the scooter eats, white poop
Page generated in 0.31956 seconds with 84 queries
