Pale horse; A TJ pile of parts - Page 20 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 28th, 2009, 07:23 PM   #381
Deaner
lost
Deaner's Avatar
Send a message via AIM to Deaner
Originally Posted by Skooter_Built View Post
I sold it and bought an aeroplane
Goin back in the garage for the final stage of this build by Friday, then will be comming back out by the end of the month fully operational. I need to get a run under its belt to make sure everything works right. After that its time for paint.
isnt it already a pretty brownish red color, why paint it?
Originally Posted by Toolmakerprevo View Post
Well at least I can screw comfortably in a bathtub!
Originally Posted by Nuggets View Post
Half you guys bitchin' about these women are probably dragging home snow cows and tundra pigs from the bar.
Deaner is offline   Reply With Quote
Old December 28th, 2009, 07:26 PM   #382
Clear over it and enter it as a "rat rod"
Old January 7th, 2010, 10:27 AM   #383
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
I finally got around and bought some parts for my Jeep this week, 4 used coilover springs and spacers, should be back in the garage by this weekend. Next is fuel tank mods and driveshafts, new fluids, build a center console & hook up the cable shifters, reinstall a few emision and engine parts, steering lines and its done before paint
I'm the man in White.
Old January 15th, 2010, 09:53 PM   #384
Skooter_Built
After about 2 months I actually did some work on my Jeep today
For the first time since June the Jeep is fully resting on its new suspension, I put the rear springs on the coilovers. In the front the flex in buck nutty, Im not even fully flexed out and have about 2.5" left of airbump travel. In the rear its pretty nice too, however I have a problem with my ass. Its to DAMN Narrow I think its about 59" wide, and if i remember right i have 1.5" spacers on bringing me out to 62". When I flex the front enough im hitting the rear springs. My rear set of airbumps will be comming soon so I can dial in the rear and at the same time Ill look into buying some 2" rear spacers and see what they will do.
I think Im seriously thinking about going full float on the rear so I can lengthen the tubes some. I think 63-65" will be good. Looking at either using Branik's conversion kit or spidertrax parts.
Here are some numbers, for now they are ok but rough, i can still lower the TJ a couple inch's. 22" to bottom of frame, 26" to the bottom of the rocker, 46" to the bottom of front tube fender and about 76" to the top of hardtop.
Top of that 40" tire is almost 5ft 7" high
High clearence rear fuel cell
Nice front approach
Nice rear approach, almost 90 degrees
Old January 16th, 2010, 07:55 AM   #385
Porter
Porter's Avatar
Default Hmmmmm
I like the orange paint Skoots!
Dirty Minds Jeep Club
DMJC WEBSITE
Originally Posted by Twilight View Post
so yeah what Ross said...
Porter is offline   Reply With Quote
Old January 16th, 2010, 07:58 AM   #386
MusKegon_ZJ_gurl
Extraordinarily Ordinary
MusKegon_ZJ_gurl's Avatar
Go Skooter Go!
Its looking good.
http://www.glfwda.org/
MusKegon_ZJ_gurl is offline   Reply With Quote
Old January 16th, 2010, 09:34 AM   #387
liv2mx
i like jungle gym's.
liv2mx's Avatar
nice rust!!!
Old January 16th, 2010, 10:58 AM   #388
twelve
twelve's Avatar
[Jealous tone] Damn you've got a lot of toys.
twelve is offline   Reply With Quote
Old January 16th, 2010, 11:09 AM   #389
Xj Wheeler
Lifted Silverado :)
Xj Wheeler's Avatar
Send a message via AIM to Xj Wheeler
lookin good skoot . I think a 2" spacer would help you out with hitting those rear springs. Get some paint down. I vote all white with black top.
Xj Wheeler is offline   Reply With Quote
Old January 16th, 2010, 11:10 AM   #390
Skooter_Built
nope, all white just like how it came from the factory.
Old January 16th, 2010, 11:52 AM   #391
pistol pete
I do vinyl stickers
pistol pete's Avatar
all white will look good, i want a set of those front tube fenders, they look good, nice rig
pistol pete is offline   Reply With Quote
Old January 17th, 2010, 09:58 AM   #392
Chiefwoohaw
Pokerob is my B*tch!
Chiefwoohaw's Avatar
Looking goood!
Old January 17th, 2010, 10:58 AM   #393
I'm amazed that after all the talk about stretched wheel base, D60 axles, 40" tires, etc that you elected to go with narrow axles. I also think you are sitting too high. For normal trail riding, you should be setting it up for around 4" of up travel. Any more than that & you're just raising your COG. So if you can drop it a couple inches, you should.
Other than that, it looks nice. BTW, since you don't need those stickies for mall crawlin, why don't you make the drive over here with them? I've got some mall approved tires I'll trade you.
Old January 17th, 2010, 11:14 AM   #394
Xj Wheeler
Lifted Silverado :)
Xj Wheeler's Avatar
Yeah all white will look good to. When are you going to build that front D60?
Old January 17th, 2010, 11:26 AM   #395
Skooter_Built
so negative If i were to do it over again Id probably go full width or 65" or more but I can work around with what I have for now. I havent fully set the suspension up but there is room to drop it 2-3". Ill gladly trade you my tires for $2000 Front 60 will start being built once I start collecting parts
Old January 17th, 2010, 01:14 PM   #396
Not negative at all. Just expressing my opinion. Make it wider and lower.
RE the tires, I'll take your tires AND wheels for $1500 and give you a set of rollers.
Old January 17th, 2010, 01:50 PM   #397
DocBrad
DocBrad's Avatar
looks good! Eventually I would like to see it in person
DocBrad is offline   Reply With Quote
Old January 17th, 2010, 01:58 PM   #398
Mclovin
"The Situation"
Mclovin's Avatar
needs more cowbell
Old January 17th, 2010, 01:58 PM   #399
Little birdie told me it's 54.25" from the stock frame to the top of the stock roll bar so providing you don't have a body lift on it you're measurement for height is very close Looking good
Old January 20th, 2010, 11:21 PM   #400
Stan
I got a gold chain
Stan's Avatar
Will look like a big piece of dried up white dog turd!
Stan is offline   Reply With Quote
Tags
fail horse, jpfab homerun, jpfab rocks!, lol--->, part out 2012, thanks mom, the scooter eats, white poop
Page generated in 0.99819 seconds with 84 queries
