Pale horse; A TJ pile of parts - Page 19 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 15th, 2009, 04:11 PM   #361
fabricator
throttle jockey
fabricator's Avatar
well i believe my part is done. these are the newest pics i have.
fabricator is offline   Reply With Quote
Old November 15th, 2009, 04:45 PM   #362
Looks nice.
Old November 15th, 2009, 05:27 PM   #363
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
Kevin the Jeep came out better then i could have imagined. Awesome job buddy
I'm the man in White.
Old November 15th, 2009, 10:31 PM   #364
tom77cj5
tom77cj5's Avatar
wow I'm jealous. looks bad ass dude come finish mine up, all the fab work is done just gotta get it all back together
Old November 16th, 2009, 12:05 PM   #365
Skooter_Built
Ill trade you a really clean 78 Cherokee Cheif for your TJ I will get my old TJ back from you 1 day
Old December 1st, 2009, 08:32 AM   #366
BUTLER
Monkey Crawler
BUTLER's Avatar
So how much rust has accumulated on this thing since it was picked up from Fabricator???
BUTLER is offline   Reply With Quote
Old December 1st, 2009, 09:27 AM   #367
Skooter_Built
Alot Its under a trap waiting on me to find the time to work on it. Im going to start back on working on it in about 2 weeks. Once its under its own power and driving again it will be stripped down and 100% media blasted & repainted. Time to pay the piper bitch!
Old December 1st, 2009, 09:54 AM   #368
Porter
Porter's Avatar
Default Hmmmmmmmmmmmm
Porter is offline   Reply With Quote
Old December 1st, 2009, 12:07 PM   #369
VonDirt
VonDirt's Avatar
its looking good - nice work fabricator
VonDirt is offline   Reply With Quote
Old December 2nd, 2009, 08:49 PM   #370
BigTony
Rock Rebel
BigTony's Avatar
Nice Job Coop.
BigTony is offline   Reply With Quote
Old December 4th, 2009, 09:53 PM   #371
Chrisholmz
ESTRADA
Chrisholmz's Avatar
Send a message via Yahoo to Chrisholmz
This is a damn nice build-up. I have a few questions on that 44/60 front axle that I couldn't seem to find in the posts. Is it running 35 spline shafts inner and outer with the D60 ujoints? Did you all the parts from Solid for the build (inner knuckle, outer knuckle, spindles, brakes, hubs)? Did the inner C already fit the tube? If not, what approach did you take?
It really wasn't clear, did you wheel this axle with the 36's? Break anything or did it work really well?
Chrisholmz is offline   Reply With Quote
Old December 5th, 2009, 08:57 AM   #372
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
That is one of my axle builds, I used a F-250 hp44 as it uses 3" tubes instead of 2 3/4" tube. Used stock ford 60 inner c's and made a sleeve to make up the 1/8" of difference. The outters were so he could run 5 lug, otherwise you can run stock ford outers if you want 8 lug. The short side is a stock ford 60 shaft and the long side is a cut down stock ford unit.
Old December 6th, 2009, 10:33 AM   #373
BUTLER
Monkey Crawler
BUTLER's Avatar
I thought Unlimited off road built that axle for him???
How it coming along Skoot, any updates or is it still under the tarp??
Old December 6th, 2009, 10:54 AM   #374
Jeepaholic
Jeepaholic's Avatar
They installed in the jeep and did some assembly (solid axle knuckles out) but the axle I did.
Old December 6th, 2009, 02:36 PM   #375
Chrisholmz
ESTRADA
Chrisholmz's Avatar
Did you make the sleeve by taking a 1/8" piece of mild sheet and wrap the tube with it? How wide did you make the sleeve? Just to fit in the knuckles or did it cover a little more of the axle tube?
The reasons for the questions is I have access to some D60 knuckles and have a D44R housing. I want to know if the build is going to handle 37's. The D44R I run now is always a crap shoot. Some days it is unbreakable, other days it spits out joints and shafts.
Old December 6th, 2009, 02:43 PM   #376
Jeepaholic
Jeepaholic's Avatar
Yes but you need 1/16" (16 gauge I think) sheet, 2" wide but you have to be careful to make sure the c is on correctly.
37's should be no problem. 39's if you r easy on the go pedel.
Only down fall is to run stock 60 shafts is an Arb is the only diff you can run.
Old December 6th, 2009, 02:47 PM   #377
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
for the amount of money he has in that axle he should have just built a 60. nothing like having you weak link be your ring and pinion
Old December 7th, 2009, 10:26 AM   #378
Skooter_Built
Yep I should have gone 60 in the first place but many parts on this axle will be reused on the front 60 I will be building soon. Jeep is still under a tarp, but only for a few more weeks till finals are over.
Old December 26th, 2009, 12:53 PM   #379
C.K.
Dont Feed the Cyco
C.K.'s Avatar
Is this Piece of crap painted and wheeling yet?
C.K. is offline   Reply With Quote
Old December 27th, 2009, 09:06 PM   #380
Skooter_Built
I sold it and bought an aeroplane
Goin back in the garage for the final stage of this build by Friday, then will be comming back out by the end of the month fully operational. I need to get a run under its belt to make sure everything works right. After that its time for paint.
Tags
fail horse, jpfab homerun, jpfab rocks!, lol--->, part out 2012, thanks mom, the scooter eats, white poop
Page generated in 0.45782 seconds with 84 queries
