Pale horse; A TJ pile of parts - Page 13 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 21st, 2009, 08:22 AM   #241
95geo
newbie
95geo's Avatar
Originally Posted by Skooter_Built View Post
I like "smooth" welds.
Most people who like "smooth" welds cant lay a "pretty" weld...
You'd better hurry up, I might just beat you!
Old July 21st, 2009, 09:01 AM   #242
scottie
Eye candy
scottie's Avatar
my camera is in my truck and thats in Rogers City
What are your parents doing in Rogers City
Old July 21st, 2009, 09:28 AM   #243
nate4d
Gnarley Davidson
nate4d's Avatar
Send a message via AIM to nate4d
You'd better hurry up, I will beat you!
fixxed
nate4d is offline   Reply With Quote
Old July 21st, 2009, 11:09 AM   #244
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
ummm cause thats where our familys 2nd home is at Plus you cannot haul 8 full sheets of plywood, a grill, and a tractor in the back of a Dodge Stratus
I'm the man in White.
Old July 22nd, 2009, 04:58 PM   #245
Skooter_Built
fork ya! my new tires just showed up. 8 new and 2 used. Im gonna run duals at each axle, once deflated i can drive on the water 5 really are Stans and the other 5 are mine.
Old July 23rd, 2009, 09:00 AM   #246
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
wat? I hauled 11 sheets of OSB with the PT Bruiser the other day
Old July 23rd, 2009, 09:09 AM   #247
Skooter_Built
cause your PT Bruiser is classified as a light truck
here is a quick pic of the new rubba
Old July 23rd, 2009, 11:32 AM   #248
Christmas Cookie
really? My title says pass vehical
Old July 23rd, 2009, 01:26 PM   #249
Skooter_Built
quoted via Wikipedia
"The PT Cruiser is a front-wheel drive 5-passenger vehicle, classified as a truck in the U.S. by the NHTSA for CAFE fuel economy calculations but as a car by most other metrics. Chrysler specifically designed the PT Cruiser to fit the NHTSA criteria for a light truck in order to bring the average fuel efficiency of the company's light truck fleet into compliance with CAFE standards."
Old July 31st, 2009, 08:45 AM   #250
muddyjeep9
muddyjeep9's Avatar
Progress? Pics anything.. Seems you've been slacking.
muddyjeep9 is offline   Reply With Quote
Old July 31st, 2009, 09:16 AM   #251
Skooter_Built
haha yes I have been slacking but im gonna hump on things this weekend. I need to clean out teh garage first and then i can work. I have to finish up the passenger side armor, tack on the front coilover mounts and get it sitting on the coilovers again, get 1 of my 40's mounted on my spare beadlock and use it as a cutting guide.
Then I need to get the skid plate bolted back on, cut out the floor for the cable shifters, build a center counsol, and finish up the rear suspension.
I still have a lot of work to finish up but hopefully she'll be a roll by next weekend.
Old July 31st, 2009, 10:17 AM   #252
KartRacer
Blowd up
KartRacer's Avatar
Pics of who you are going to hump on please.
Old July 31st, 2009, 11:24 AM   #253
Skooter_Built
no pics, but her name is Palmala
Old July 31st, 2009, 12:17 PM   #254
muddyjeep9
muddyjeep9's Avatar
If you need help building a cebter counsel let me know.
Old July 31st, 2009, 11:05 PM   #255
Skooter_Built
weeeee Im making progress
the front end is setting on the coil overs. I need to finalize all the mounts still, and probably drop the hoops down 1" for hood clearence. On the frame side of things Im going to clearance both sides of the frame for the highsteer with some big diameter DOM and then plate over things to gain me a few more inch's for up travel, If I didnt have highsteer i wouldnt have these issues but no big deal.
I got 1 of my 40's mounted up on a spare beadlock and jack cycled the front suspension, with the tierod kissing the frame I have 4.5" from the top of the tire to the bottom of the tube flare for if I can gain 3" on the frame and 1" on the hoops ill be golden.
1 question I need answered is on the amount of coilover shaft exposed. Right now it looks like I have about 8.5" on a 14" coilover, are my springs to heavy? I think i have a 300 over a 250 or 200. Do i need to get lighter springs.
Here be some pics:
Old August 1st, 2009, 12:27 PM   #256
95geo
newbie
95geo's Avatar
looks good.
dont touch the springs right now. it's not done and you have cantilevered weight over the back right now that is taking weight off the front. until it is sitting on all 4's and at full weight dont mess with the spring rates. in fact, take them out and dont put them back in until everything has been mounted and everything clears at full stuff and full flexed out. it's more important than people think.
once you are done I'd shoot for 6-7" of shock showing and it'll ride pretty good. give yourself about 2" of soft coil travel until your slider hits the stop and then have the last 3-4" of travel the stiff spring. make sure you have some sort of bump stop too, coilovers need something to take the load as they dont have a super progressive rate as they bottom...
Old August 1st, 2009, 01:18 PM   #257
Skooter_Built
looks good.
cool thanks for the advice, ya Ill be building bumpstops, Ill be getting some air bump cans and build some timbrin bumps to fit in them until I can buy some airbumps.
Old August 2nd, 2009, 07:51 PM   #258
bbaXJ
Yooper In Training
bbaXJ's Avatar
looks good.
Not to mention that changing the spring rates will change more than just the height, it'll change suspension frequency. Those rates should be pretty good for all around use, if you're not happy with the height(which looks good to me for what it's worth) then I'd change the coil lengths and/or adjustment collar location before I'd necessarily change rates. 200-250 over 350 should be pretty good for a TJ.
Old August 2nd, 2009, 10:55 PM   #259
KartRacer
Blowd up
KartRacer's Avatar
Is that stock?
Old August 18th, 2009, 11:35 AM   #260
muddyjeep9
muddyjeep9's Avatar
It seems like everytime I look at this build, there's never any progress to it... Get this thing done and over with already.
Tags
fail horse, jpfab homerun, jpfab rocks!, lol--->, part out 2012, thanks mom, the scooter eats, white poop
Page generated in 0.35493 seconds with 84 queries
