D44a Aussie - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 2nd, 2007, 02:30 PM   #1
Chinski
Default D44a Aussie
I've been thinking about getting the Aussie locker for my D44a. Its the only thing available besides a factory lsd. Anyone have one? What do you think of it?
Chinski is offline   Reply With Quote
Old February 2nd, 2007, 02:40 PM   #2
greenmeanie
greenmeanie's Avatar
there's tons of lockers availabe for the 44. i am going to get an aussie for mine though. they have better warranties than the other lunchbox style lockers; they are also the least expensive of them too.
greenmeanie is offline   Reply With Quote
Old February 2nd, 2007, 02:55 PM   #3
gotsand?
sie sehen mich rollin ...
gotsand?'s Avatar
Location: New Era, MI --- "We passed BFE 35 minutes ago."
Send a message via Yahoo to gotsand?
I have been doing a lot of research on lockers lately and I just ordered an Aussie for my D30 today...they are on backorder and wont ship for 2 weeks but after talking with few suppliers of multiple lockers it sounds like they are well worth the wait!
not to mention they have a 3 year unconditional warranty, no matter what size tire you run....lockrite has a 33" max tire size warranty...
click on the following for some pretty good write ups.....doesnt hurt they are easier on the pocket book than others, and by the sounds of it come with extremely detailed and easy to follow install instructions.
here and here and here
good luck!
gotsand? is offline   Reply With Quote
Old February 2nd, 2007, 03:20 PM   #4
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
Ignore GreenMeenie as he's obviously confused. I've been running the aussie in mine now for about 8 months....no problems. I'll be trussing my axle soon. I was gonna swap it for an 8.8 and decided it's not worth the trouble. You'll need to buy an open carrier too if you don't already have one. I'm running 5" lift and 33's
Old February 2nd, 2007, 03:29 PM   #5
Chinski
I think mine is open, it acts like it is. I can not find any tags on the diff and the build sheet does not says it has trac-loc, or whatever jeep called their lsd. I will have to open it up and make sure though.
How does it do in the snow? Would it negativly effect towing? I don't tow anything heavy or even that often, but I wouldn't want to loose the ability to do so.
Old February 2nd, 2007, 04:15 PM   #6
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
It won't affect your towing at all. Any locker on slippery road surfaces will make the rear want to fishtail when power is applied....because it's both tires spinning and not just one. As long as you drive like a human being you won't have any problems. I love mine. You just have to drive it like you know there's a locker back there.
Old February 20th, 2007, 09:04 AM   #7
BlaineWasHere
GVSU Jeeper
BlaineWasHere's Avatar
Send a message via AIM to BlaineWasHere
I am also going to add the aussie to my 44a. Lucky for me I have a WJ and my 44a is NOT c-cliped and much stronger. Becuase the WJ uses the rear axel for speedo it is really not worth it to swap for something else.
After I truss it, which bypasses the strees on the aluminum center section I don't forsee having any problems locked on 35's. Yukon makes alloly shafts for the WJ 44a now too...
BlaineWasHere is offline   Reply With Quote
Old March 24th, 2007, 07:59 PM   #8
Kane
Got Jeep?
Kane's Avatar
True. The Dana 44 has tons of options.
But the Dana 44A, as in aluminum housing, has only one, the Aussie.
Kane is offline   Reply With Quote
Old March 25th, 2007, 06:22 PM   #9
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
Get him KANE!!!!!!
As far as towing you will be fine as long as the circumference of the 2 rear tires are within a 1/4" of each other. And the fact that you have an auto trans will take a lot of torque steer out of the rear axle when on and off the gas.
Old March 25th, 2007, 07:54 PM   #10
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
I don't sense any torque steer at all as long as my tire pressure is the same.....if you ever start feeling it...that'll most likely be the issue
Page generated in 0.22923 seconds with 53 queries
