carb problems? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 2nd, 2007, 01:59 PM   #1
warhof
pope approved
warhof's Avatar
Default carb problems?
I know it is not a truck, but i have a question on my 1986 corolla. I can't get it to warm up right now, and it is burnig through gas. Tried changing the thermostat and of course cardboard in front of the radiator. Anything I can mess with to bring up the temp?
warhof is offline   Reply With Quote
Old February 2nd, 2007, 04:33 PM   #2
nmeinc
Parts Galore Spokesmodel
nmeinc's Avatar
can't get heat or won't get to operating temp?
nmeinc is offline   Reply With Quote
Old February 2nd, 2007, 04:41 PM   #3
deuce228
Redneck Poser
deuce228's Avatar
You know that even new thermostats are often faulty right? Have you checked your coolant mix ratio? Is the engine not heating up or could it just be a plugged/bad heater core?
Old February 2nd, 2007, 08:43 PM   #4
warhof
pope approved
warhof's Avatar
I can't get either, the car even on the highway will not warm up past an 1/8, and no heat. Coolant levels/mix are fine. It did a little better with part of the radiator blocked, but not enough that it merits any further exploration.
Old February 2nd, 2007, 09:14 PM   #5
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Check your t-stat by sticking it in boiling water to see if opens unrestricted.
Have you ever used stop-leak in your radiator? Could have a partially blocked heater core too.
@clarkstoncracker
Old February 3rd, 2007, 05:14 PM   #6
warhof
pope approved
warhof's Avatar
t-stat is good, both of them that i have tried, never used stop leak
Page generated in 0.17991 seconds with 41 queries
