1.3 carb to 1.6 efi or tbi swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 2nd, 2007, 10:48 AM   #1
swampjeep
Swamp Stomper
swampjeep's Avatar
Default 1.3 carb to 1.6 efi or tbi swap
OK, I hav e been on a couple of the big zuk boards, but I can't seem to find a single thread that covers this swap totally, detailing all the options, and what's needed, anyone know of one, or any?
thanks...
swampjeep is offline   Reply With Quote
Old February 2nd, 2007, 02:44 PM   #2
scottie
Eye candy
scottie's Avatar
talk to ZOOK94, he'll know
Old February 2nd, 2007, 09:03 PM   #3
hman1991
hman1991's Avatar
Send a message via AIM to hman1991
here you go. what you need off the donor tracker is.
-motor complete with manifold and all.
-complete wiring harness
-computer
-fuelpump out of tank (unless you use a inline 1) i used stock sending unit, just cut hole in tank.
-fuelsupply line from intake to tank (or you can make your own)
-guage cluster ( you only need the vss out of it though )
now what you need to buy is the adapter plate with bolts, mount and mount spacer. and the optional dodge 318 motor mounts.
now for the harness you can either send out, or go here to do it yourself.
http://www.yankeetoys.org/mini4x/efiswap/efiswap.htm
this is the site we used to do ours. i am hopin to get mine fired up real soon. if you want that tranny and t-case you can come check out the swap while u r here.
hman1991 is offline   Reply With Quote
Old February 3rd, 2007, 10:19 AM   #4
swampjeep
Swamp Stomper
swampjeep's Avatar
-computer
what year and type of dodge 318 motor mount?
what trans? auto or stick?
Old February 3rd, 2007, 02:25 PM   #5
hman1991
hman1991's Avatar
the 2 engine mounts for any 318. if u go to autozone just pick like a 85 dodge pickup with 318 and auto. but they r all the same. all these do is lower you engine down so u can close hood without a bodylift at all. also gives y room between fan and top radiator hose. if you donot use mounts they recomend a 1 inch body lift in front. also i ran a electric fan.
Old February 5th, 2007, 08:16 AM   #6
jimmyroyse
webwheeler
jimmyroyse's Avatar
are you looking to swap the whole motor or just the intakes?
jimmyroyse is offline   Reply With Quote
Old February 5th, 2007, 12:30 PM   #7
swampjeep
Swamp Stomper
swampjeep's Avatar
swaping complete motor, 1.6 out of tracker, into 87 sami
I may use hte 1.3 carb at first, then add the fuel injection, but I'd rather do the fuel injection right from the start...
Old February 5th, 2007, 12:56 PM   #8
jimmyroyse
webwheeler
jimmyroyse's Avatar
maybe these will help;
http://www.nitromax.nl/SAMENGINESWAP.HTM
http://www.off-road.com/suzuki/tech/...ns.%20benefits
yahoo group;
http://autos.groups.yahoo.com/group/...s/How%20To%2C/
Page generated in 0.36591 seconds with 47 queries
