Dana 60 hubs? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 2nd, 2007, 09:57 AM   #1
frdtrckmnrich
FORD The Best Never Rest
frdtrckmnrich's Avatar
Default Dana 60 hubs?
Does anyone know if chevy dually dana 60 hubs will interchange with ford single wheel hubs?
Old February 2nd, 2007, 10:23 AM   #2
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
ford and chevy spindles are different i dont remeber which way it was but you can machine one to fit the other but not the other way around.
Old February 2nd, 2007, 03:50 PM   #3
frdtrckmnrich
Can you just use different bearings to make it work?
Old February 2nd, 2007, 04:01 PM   #4
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
The spindle is longer on the chevy than the ford. You might be able to put a spacer between the inner part of the outer wheel bearing and the spindle where it usually sits againist?
Old February 2nd, 2007, 10:56 PM   #5
frdtrckmnrich
What about switching spindles as well. I have never had one of these apart. A freind has a dually dana 60 chevy and wants single. I am looking for a dana 60 for a ford and thought if a got a single that maybe we could trade.
Old February 2nd, 2007, 11:04 PM   #6
Jeepaholic
Jeepaholic's Avatar
If they are both kingpin axles you can switch them but you will have to switch from the knuckles out. Ford uses 5 studs for the spindle and chevy uses 6. A benfit to run the the chevy stuff is being able to run the 35 spline spicer outers
Page generated in 0.18952 seconds with 41 queries
