Are alloy shafts really that much stronger? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 1st, 2007, 07:00 AM   #1
Cube
Captain of my pants
Cube's Avatar
Default Are alloy shafts really that much stronger?
I had them on my CJ and didnt break anything but are they really worth the money
Cube is offline   Reply With Quote
Old February 1st, 2007, 07:23 AM   #2
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
they say around 40% stronger in most applications.
Old February 1st, 2007, 08:16 AM   #3
The results from axle-breaking machines have backed up that claim, from what I've seen.
Old February 1st, 2007, 09:38 AM   #4
xj_man_646
Wheeler-less
xj_man_646's Avatar
Send a message via AIM to xj_man_646
yes. stock neckdown vs. alloy with no neckdown. look at them side by side, and you'll see why they are stronger.
xj_man_646 is offline   Reply With Quote
Old February 1st, 2007, 10:17 AM   #5
groundhog
groundhog's Avatar
D44 alloy axles vs Stck D60 axles who wins? Hypothetically speaking!!!! exp. Jeep with stk 350 chevy motor with 4.10 gears on 38.5 mudders, which breaks first, in this example? I know there are many varibles, keep it simple. Just wanted opinions.
groundhog is offline   Reply With Quote
Old February 1st, 2007, 10:18 AM   #6
junk90xj
ALLPRO AUTO
junk90xj's Avatar
yes
http://www.apalansing.com/
Old February 1st, 2007, 10:26 AM   #7
max5p33d
slack jawed faggot
max5p33d's Avatar
Send a message via ICQ to max5p33d Send a message via AIM to max5p33d Send a message via Yahoo to max5p33d
Originally Posted by junk90xj View Post
yes
x2!
max5p33d is offline   Reply With Quote
Old February 1st, 2007, 10:38 AM   #8
You answered your own question. Too Many Variables.
Dana 44 rears and Dana 60 FF rears both use the same shaft.
Dana 44 alloy fronts are still weaker than Dana 60 35 spline OEM fronts. The U-joints/ears are a weak point. Compare with Toyota alloys which don't use a U-joint which are stronger than a stock dana 60 front 35 spline (stock failure point is the u-joint/ears)
Old February 1st, 2007, 12:23 PM   #9
groundhog
groundhog's Avatar
Default .
I was mainly speaking about front axles, should of put that my BAD.
Old February 1st, 2007, 01:09 PM   #10
Even then, though, you have to know what you have.
A late model Dana ran Dana 60 front is still dana 44'ish sized axleshafts.
Generally, the data I've seen says a 35 spline dana 60 front is a little stronger than dana 44 alloy shafts. You'd need to also go to some high strength U-joints like longs or ctms to eliminate the weak link.
To give you an idea of what strength is there to be gained, a stock dana 44 shaft is around 5000 ft-lbs before it snaps. My toyota front shafts, which are also 1.31" 30 spline, snap at 9100 ft-lbs. There's no neck down on mine, and the longfield joints are stronger than the axleshaft itself, so you get the big gain.
Some of the gain is not in the ultimate breaking point, but the amount of elasticity in the shaft itself. Stock shafts fail usually after twisting 20-40 degrees, where many aftermarket shafts can go 90 degrees of twist before failure, especially stuff better than the usual 4340 chrom-moly.
Old February 13th, 2007, 12:18 PM   #11
ZOPILOTE
ZOPILOTE's Avatar
Time for the Dana 35 crowd to check in.
Should I go the cheap route (alloy axles @ $360/pair), or do the Super 35 upgrade ($1033) if I'm running 34" LTB's?
I'm currently running 33" mudders on a stock D35 without a problem, but I want more bite.
ZOPILOTE is offline   Reply With Quote
Old February 14th, 2007, 05:49 PM   #12
drummond
MTU 4x4
drummond's Avatar
would it more cost effective to swap to a dana 44 instead? stronger tubes as well
drummond is offline   Reply With Quote
Old February 14th, 2007, 07:09 PM   #13
cvwindows
I think I can make it!!!!
cvwindows's Avatar
It is real simple. Go Dana 60 with 35 spline alloy shafts.
cvwindows is offline   Reply With Quote
Old February 14th, 2007, 08:08 PM   #14
ZOPILOTE
ZOPILOTE's Avatar
I considered an 8.8, but if you add the cost of 4.88 gears, shock mounts, spring purches, and a locker, I find myself once again behind the financial 8-ball.
I consider myself the unluckiest person on Earth, whereas my friend is the luckiest. He's running a locked stock D35 with 36" swampers without a problem. I think I will go with the super 35 kit.
Old February 15th, 2007, 06:02 AM   #15
greenmeanie
greenmeanie's Avatar
i had 35X15.50 super swampers on my stock dana 35 w/ no problems. i got a dana 44 to build, just for some security.
it depends on how hard you bounce around and how much power output your engine has; you would be able to use the stock 35 if you took it easy
greenmeanie is offline   Reply With Quote
Old February 15th, 2007, 09:35 AM   #16
Grandman
do i look old !
Grandman's Avatar
Thats not luck , thats use of the gas pedal making the difference . I my self went from tech driver to throttle guy . Man that cost me
Old February 15th, 2007, 11:14 AM   #17
Noah's Ark
Noah's Ark's Avatar
Umm Yes!
If you are considering this, check out my for sale add for the axles. D30/8.8 combo w/arb's. The D30 has every upgrade available including alloy shafts and the lockout hubs. No vac dissconnect necessary. Geared 4.56 though.
http://www.greatlakes4x4.com/showthread.php?t=26682
end hijack!
Noah's Ark is offline   Reply With Quote
Page generated in 0.34671 seconds with 74 queries
