coolant quick connecter - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 15th, 2006, 03:00 PM   #1
GMCsonoma94
1 wheel peel
GMCsonoma94's Avatar
Send a message via AIM to GMCsonoma94
Default coolant quick connecter
it corroded and broke, im freaking happy. i recomend replacing yours before this happens with a steel one if you got an older chevy.
GMCsonoma94 is offline   Reply With Quote
Old January 15th, 2006, 04:01 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
yep that is a real common problem, I have dug plenty of them out at the dealer.
Yetti
Old January 16th, 2006, 04:25 PM   #3
cracker$
cheese
cracker$'s Avatar
Yup, had to "easy out" mine after it busted apart in the manifold.
cracker$ is offline   Reply With Quote
Old January 16th, 2006, 10:23 PM   #4
Mclovin
"The Situation"
Mclovin's Avatar
i just replaced it with a barb typer fitting and made my own heater hoses..
but i also was putting a new manifold on the motor so i didnt give a shit that it broke off...
Old January 17th, 2006, 01:17 PM   #5
Strangler
Strangler's Avatar
Where does the return hose go to? I have a tbi chevy in my Jeep and I just used a brass plug to block off that hose port, but when I want to make my heater work again where do I hook the return to? There was only one port on the manifold....
Does it go to a different thermostat housing or right to the radiator?
Old January 18th, 2006, 09:11 AM   #6
Mclovin
"The Situation"
Mclovin's Avatar
Strangler: I think on my TBI motor there was one connected to the intake and one connected to the water pump..
Old January 18th, 2006, 11:24 AM   #7
Yetti
Yetti's Avatar
given the application the return from the heater can go into the radiator tank or in the water pump intake fitting. kind depends on the set up you have. you can't route out of the rear of the itake and then back in the front, it won't circulate.
Yetti
Page generated in 0.22965 seconds with 44 queries
