More power little truck, Engine swap??? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 31st, 2007, 10:19 AM   #1
Pre4runner
Bike Dude
Pre4runner's Avatar
Question More power little truck, Engine swap???
Ok so I must have messed up something during my 22re rebuild, it just died last week. Im afraid its bad and would like to get more power anyways. So Im thinking of running a chevy 350 because of how cheap they are. Looked into a 4.3 but it just seems i might as well do the 350 if im going to spend the money.
One of my big things though is i want a manual still and know the stock 5 speed isn't going to take a V8 for long. What tranny should i be looking for, i'd prefere a 5 speed. It just seems almost every chevy 4x4 has an auto, I'd Like to just find a beater and swap it all over.
Or a ford 302
Jeep 4.0
Toyota inline 6.
Last edited by Pre4runner; January 31st, 2007 at 10:39 AM. Reason: I like to be different
Old January 31st, 2007, 12:23 PM   #2
hunter2005
no, no and yes ... the 302 its priceie...and the 4.0 i havent heard any on edoing that and the inline 6 use a 7mge motor its out of a supra...thats a big swap alot of people are doing... www.supracharged.com alot of info there....
hunter2005 is offline   Reply With Quote
Old January 31st, 2007, 12:59 PM   #3
Depends on what trans you want.
Automatic, go with a Chevy 4.3.
Stick, go with a 3RZ from a Tacoma.
The Supra motor is garbage. A 302 isn't a bad motor if you want V8 power, I'd still go chevy first.
A 302 is barely more power than a Vortec 4.3.
Fuel injected 4.3s, small blocks, and 302s would all be cheaper motors to find than a decent 7mge, especially in mid michigan.
Old January 31st, 2007, 03:44 PM   #4
roll-bar Bob
roll-bar Bob's Avatar
http://www.ttora.com/forum/showthread.php?t=57763
Old January 31st, 2007, 05:39 PM   #5
nmeinc
Parts Galore Spokesmodel
nmeinc's Avatar
for the effort of a 7mge you could do a 3rz and endup with less weight and same HP.
now a 7mgte is a different case, 290hp on a dependable turbo motor. and yes dependable and turbo motor do no tbelong in the same sentence.
the 22RE with an RV cam and ported head will put out around 140HP. a rebuild would be the cheapest.
Yota axles do not like the V8's and the added weight of one is huge in a light weight truck like a Yota.
nmeinc is offline   Reply With Quote
Old January 31st, 2007, 06:28 PM   #6
Pre4runner
Bike Dude
Pre4runner's Avatar
The 22re is ported and polished, pro comp cam, header and all gasket matched. Was pretty quick. I just don't feel like rebuilding the bottom end again.
If i do what do you think bumping the compression up to 10:1 and putting bigger valves in would add?
3rz's started in 88 right? And isn't there something you should check for in relation to the heads?
Old January 31st, 2007, 07:30 PM   #7
Mud'N'Truck
I'll Finsh One, One Day
Mud'N'Truck's Avatar
If you are still planning on turning it into a prerunner you dont what a v8 because of the weight. The horse power is full and all but not partical for a prerunner. If you really what to do a motor swap in the 88 put a supra motor in it. You can build tons of power with them. With that plan you would be best off buying a old beat supra with a descent engine and going from them. Then you know you have all the parts and after you can part it out and scarp it. I think your best route would be to build the 22re more and get a turbo kit for that and put some low gears in it. My cousins 2wd prerunner has 4.88s with only 30's with a cam and header and it is really fast. The 85-88 5 speed will take the power off a v8(mild v8 not driven recklessly). If you decide to go the v8 way get back to me and i can tell you were to get parts for it the cheapest since i am putting a built 350 in my 85.
Old January 31st, 2007, 07:33 PM   #8
Mclovin
"The Situation"
Mclovin's Avatar
Step up to the big boys
WHAT ! You said you wanted more power ? :tonka:
Old January 31st, 2007, 07:37 PM   #9
sam
sam's Avatar
hey my friend has a chevy 305 with 30,000 miles for 700
sam is offline   Reply With Quote
Old January 31st, 2007, 07:52 PM   #10
Mud'N'Truck
You could also look into doing a 20r head swap. Dont know much about it but Ive heard it makes alot more power. kinda hard to find details on though. Head swap+turbo+cam+header+porting= alot power out of a 22re
Old February 1st, 2007, 07:23 AM   #11
nmeinc
nmeinc's Avatar
once you get to silly with building a 22RE they get moody. very finickey.
nope they started in 96ish, these threads:
3rzfe history and specs
Quasimodo
Old February 1st, 2007, 07:45 AM   #12
roll-bar Bob
IN MY LITTLE BLACK BEAST I HAD A OLD STOCK 22RE. THAT HAD JUST SUCKED UP TO MUCH MUD OVER THE LAST 3 YEARS. GREG ( MY MOTOR MAN ) SAID THAT HE WOULD BE SURPRISED IF IT WAS KICKING OUT 65 HORSE WHEN I HAD HIM BUILD ME A HIGH COMPRESSION MOTOR. IT IS PORTED, POLISHED, 30 OVER DOME TOP PISTONS WITH 20 OFF THE DECK, CRANK, CAM AND MAFS TO ACCOMMODATE I LOVE IT I NEVER HAD IT ON THE DINO BUT GREG SAID IT WOULD BE SOME WHERE AROUND 135 HP TO 140 HP ONCE AGAIN "I LOVE IT " THE TRUCK IS DOWN RIGHT NOW DO TO I TWISTED THE REAR DRIVE SHAFT OUT OF IT AGAIN
Old February 1st, 2007, 08:57 AM   #13
Or for less you can have a 2RZ or 3RZ that makes more power stock(and way more torque) and responds great to mods.
Toyota driveshafts are made out of pepsi cans. There's no excuse running a stock driveshaft on any trail rig. 2-1/2" sch 40 is your friend, almost a perfect fit on the yokes.
Myself, I see no reason to stay toyota unless you want 4 cyl power, in which case the 3RZ is nice. 22REs are always said to be bombproof, btu around here, as old as they are, seem to always run like garbage, and break. I killed one last year(wrist pin) and my 22RE has taken lots of tuning to get rid of misfires and still isn't quite right.
Pretty much all other toyota motors have quality that last the big GM truck motors.
I thought about a 3RZ, but they are taller than a 22RE, I don't know if it would fit in my Jeep.. I need to find a new Vortec 2900 4 cyl... 2.9 liter 4 cyl, 185 hp, 190 ft-lbs, and I think bolts to the old 90* small block pattern.
Old February 1st, 2007, 09:38 AM   #14
roll-bar Bob
I PAYED $1,400 AND I COULD USE ALL MY STOCK GOODIES ( POWER STEERING PUMP, BRACKETS, ALTERNATOR, MOTOR MOUNTS, RADIATOR, HEADER "THAT I HAD" , COUMPUTER THERE WAS NO PROBLEMS WITH WIRING. ) IT NEVER WILL BE A MONSTER BUT IT IS FUN
Old February 1st, 2007, 10:13 AM   #15
again, for $1400, you can get a 3RZ installed there.
I rarely see stock engines fail no the trail. I see modified engines fail all the time off road, or at less run finicky, overheat, etc.
no quality like OEM quality.
Damn, now I'm thinking of going to find a Vortec 2.8 or 2.9, and ditch my TBI 4.3. Aluminum block 4 cyl, should be ~75 lbs lighter than the iron block V6.
Old February 1st, 2007, 10:23 AM   #16
Meh, the intake manifold wouldn't work with my hood design.
Old February 1st, 2007, 08:50 PM   #17
Pre4runner
Bike Dude
Pre4runner's Avatar
Yea my 22re was very finicky, but when she ran it was a dream.
the 3rz is looking good, but im still curious about the 7meg
And well maybe the 4.3 still, only if i can get the early 90's vortech.
What would be really cool is a turbo 3.8 or 4.3
Old February 1st, 2007, 10:00 PM   #18
The early 90s vortec was the CPI that had the crappy fuel pressure regulator. The later MPFIs were better. Or just get a TBI for like $200 complete.
Old February 2nd, 2007, 12:08 AM   #19
Pre4runner
Bike Dude
Pre4runner's Avatar
The cpi's made some good numbers though, plus they had the aluminum intake
Old February 2nd, 2007, 03:12 PM   #20
Rattler
Home Sweet Homicide
Rattler's Avatar
I would just stick with a mild 22re. Roadhouse can tell you that my wristpin slap in my old XtraCab got sooo loud but it never let go. I ran 31 x 11.5 Yokohama Muddiggers(terrible in sand, awesome in mud). It wouldn't shift the Earth off it's access but it wasn't bad. I never really did much to it other than a K&N. It really could have used some top end though. One of the guys we used to wheel with ran a 22RET in his 87 or 88 XtraCab. Right where mine fell off his turbo started working.
I have ridden in a 4.3 swap in a 85 4Runner too. It had enough power. I think the only thing I would have done different is stick with the Toy t-case. He used a noisey one that I don't remember what it was.
I know NWOR has a lot of Ford swap stuff.
Stick with the 22RE and gear it.
Page generated in 0.41557 seconds with 84 queries
