Ranger Spool?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 30th, 2007, 08:55 PM   #1
Weatherman
Mike Z
Weatherman's Avatar
Send a message via AIM to Weatherman
Default Ranger Spool??
Howdy,
I'm looking to put a spool in my 92' ranger 4x4 as well as some sort of locking or limited slip in the front. Not sure how to tell what rear end I have either. If anybody has information on where I can get a spool from as well as good diff lockers for the front as well as how to tell which rear end I have, that would be great.
"You ain't drivin' unless your driftn'."
Weatherman is offline   Reply With Quote
Old January 30th, 2007, 09:11 PM   #2
chris1044
chris1044's Avatar
What motor do you have???? that'll tell you what axles you have basically
typically a 4.0 = 8.8, and anything else = 7.5
As for the front axle ID- it's complicated, but the short of it is this:
If do have a 4.0 motor, you've more than likely have atleast a dana 35 housing in the front. The internals are iffy. Basically, ford decided it would be smart to use left over Dana 28 internals in some dana 35 housings - call it a "gay ass hybrid axle). It's easy to see if you've got one of those though - all you have to do is pull the front diff plug and look inside. If you see the carrier, it's a 35. If you see the main cap for the carrier bearing then it's a 28. Again, this will only apply if you've got a 4.0 motor....anything else and it's a 28.
If you've got a 7.5 and dana 28, I'd look for completly new axles....but it depends on what you want to do. If you plan on actually wheeling it hard, the 7.5 can usually handle the torque a small motor can make, but typically the D 28 will explode, especially when locked - the axle shafts/hubs/whole axle is week....
if you've got a true 35 up front, a jeep dana 35 carrier/lockrite style locker will work in it.
If you've got an 8.8 in the rear, it's only going to be a 28 spline model, and if you plan on running 33's or smaller it'll hold up fine with a locker....anything over 33's and you should consider an explorer rear axle as they're 31 spline.....
Old January 30th, 2007, 09:26 PM   #3
88mudder
In the band!
im guessing he has a d35 front and 7.5 rear.
Old January 30th, 2007, 09:35 PM   #4
chris1044
chris1044's Avatar
cant - if you've got a 35 you've got an 8.8 in the rear
the 7.5 and d28 were axle pairs
the 8.8 and 35 are axle pairs (but you can have the jive 35/28 hybrid - but still have to have the 8.8 in the rear)
Old January 30th, 2007, 09:43 PM   #5
88mudder
In the band!
im pretty sure it was the 93 and up Rangers with the d35 and 8.8 pair. Maybe im wrong..i heard that somewhere tho.
Old January 30th, 2007, 09:46 PM   #6
they stop putting the hybrid frts in after 91..........Ranger i wheel with has factory D35 frt and 7.5 out back.........
everything ranger related you could ask for
pretty sure most spools require a c-clip elimnator and i have heard ford axles with elimantor kits don't hold up well off road
Old January 30th, 2007, 09:58 PM   #7
frdtrckmnrich
FORD The Best Never Rest
frdtrckmnrich's Avatar
Nobody makes a c-clip eliminator for the truck 8.8's explorer's and rangers included. C-clip eliminators are required for a full spool. If it has the 4.0 (and it should) it should have a 8.8 and dana 35.
Old January 30th, 2007, 10:04 PM   #8
http://www.drivetrainspecialists.com/
Old January 31st, 2007, 06:36 AM   #9
Weatherman
Mike Z
Weatherman's Avatar
I have a 2.9 in it, the axle code on the door says 95 from which i have found on the net to be an open 8.8. not sure if thats entirely true but...
Old January 31st, 2007, 09:32 AM   #10
Weatherman
Mike Z
Weatherman's Avatar
I confirmed that my truck does have the 8.8 by identifying the differnces in bolt pattern from the 8.8 and 7.5.
Old January 31st, 2007, 09:34 AM   #11
Weatherman
Mike Z
Weatherman's Avatar
any body know anybody with a 1992 Ford Explorer 4x4 with a 4.0 engine and manual transmission that hopefully runs?? if not running i guess thats ok too.
Old January 31st, 2007, 09:40 AM   #12
day late and a dollar short............last week i finished a 91 explorer swap to a 90 ranger
We did a 2.9L removal and wirng harness and changed to a 91 4.0L and wiring harness
what tranny do you have in your ranger and do you know the gear ratio yet
Old January 31st, 2007, 10:29 AM   #13
Weatherman
Mike Z
Weatherman's Avatar
i have a 3.55 ratio
Old January 31st, 2007, 01:40 PM   #14
88mudder
In the band!
yeah i knew some rangers had the d35 and 7.5 combo.
Page generated in 0.26170 seconds with 65 queries
