got a 2000 ford ranger with 4.0 i wana soild axle it up front need some help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 29th, 2007, 12:48 PM   #1
snocross2xtremes
snocross2xtremes's Avatar
Default got a 2000 ford ranger with 4.0 i wana soild axle it up front need some help
it acutally my buddy doing it he has straight axled few full size chevys so we kinda now what where doing..
question one what kind tcase do i need to look for? and do i need differnt tail shaft and such?
Old January 29th, 2007, 12:54 PM   #2
Bones
Bones's Avatar
www.rrorc.com
www.explorer4x4.com
the people on those sites are very knowledgable in those areas...
why do you want to swap tcases? Is it 2WD right now or something?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old January 29th, 2007, 01:28 PM   #3
chris1044
chris1044's Avatar
X2 - try therangerstation.com as well
If the ranger is currently 4x4, then it should have a bw1354 case in it - which is plenty strong unless you want to use something like a doubler/atlas.....but IMO I would leave it alone.
As for axles, common axles used are XJ D30s' (IIRC 96+ has the stouter shafts/U joints - they use these because width is the same as the 8.8 in the rear and bolt patterns will match), the D44/9" from the old bronco's - but IMO those are way to expensive for what they're worth, a 44 or 60 from the 78/79 fords, you can cut/narrow them or leave full width, but then you've got to do the back as well if you go full width. Also, waggoneer axles work up front if I'm not mistaken, thought I can't remember what years work (or what years had D side drop)
First thing you need to do is decide what type of suspension you want - leaf/coil. If you go coil do you want to do a early bronco C-wedge type axle, make your own links, etc......
You can try pirate as well - alot of know how is overthere (especially mr. N)
Old January 29th, 2007, 08:14 PM   #4
snocross2xtremes
axles will probley be 44 9 inch combo with coils front leafs rear.. but it two wheel drive so we need a tcase
Old January 29th, 2007, 09:53 PM   #5
chris1044
chris1044's Avatar
Not only will you need a T-case, you'll also need a new transmission.
The trans in the truck will not work with any T case without swaping both the tail shaft housing and the output shaft - the 2wd and 4wd version transmission do infact have different output shafts, so it's not a wham bam thing (unless you go custom with something like an atlas....I'm sure it could be made, but thats going to be mega bucks). Additionally, the trans will have to be totally torn down to swap the output shaft....
The next issue is the vehicles computer. While ford did offer some level II rangers with the lever operated transfer cases, other models are electric shift - and given that those lever operated T-cases are fairly new they're going to be expensive as well. Another option would be the older (80's - early 90's) lever operated T-cases, though I'm not sure on their input shafts and the compatibility with a new 4x4 trans. So, if you're going to go electronic shift you'd have to wire all the stuff up for that - including the 4x4 module.
So now you're thinking "I just want to use a damn NP205" right? Wrong - can't be done without a fancy adapter to the 2wd trans. You could swap the whole transmission for something else that's not found in an RBV (ranger/bronco vehicle), but the only way you'll get it to bolt up to the 4.0 is with a fancy adapter....if you check out myers machine over at RRORC I think that he's still making custom mounting plates to adapt any trans to a 4.0 - though I think they only work on OHV 4.0's.....if you're buddy's got an 00' ranger I dont think it's an OHV motor (thought they went out of production in 98, could be wrong though).
So, now you've got to do some research on that issue....do you put a new motor/trans/t-case in it, swap to a 4wd ranger trans/t-case and electrics, or have some fancy adapter made for the trans. Also, keep in mind if this vehicle ever has to be legal/plated in another state that does emissions testing the power train you swap in has to be 2000 or newer (year of the truck and newer).....I'm not sure how those laws apply to transmission swaps, but I'd check into it if he plans to keep it and move out of state.
While it could be done - converting this 2wd to 4wd, it will be very time consuming and could be very expensive. Personally, if it were me I'd start with a 4x4 to begin with, but to each his own.
On to the suspension: If you're running a 9" out back you can chose to run leafs or do a 4 link. But with the front, if you're going to run the 44 with coil springs the easiest set up is to find a C-wedge style axle and use the EB radius arms. Wrist one of them to allow maximum flex. You'll need custom coil buckets, which pottsy over at RRORC makes (guy does awsome fab work - would recommend everything he does). Also, you'll have to consider the track bar/track bar mount. I know with earlier ranger (that have TTB suspension under them) the engine cross member must be modified for clearance - I'm not sure how far the one on the new SLA trucks hangs down, but I'm guessing it's going to have to be modded as well.
If theres one thing I would stress its the fact that you should do lots of research on this before you start if you want to have a nicely built streetable truck. Theres a big difference from doing 10mph on the trail and 80 mph on the highway
Old February 26th, 2007, 01:27 PM   #6
Blackjackbender
Old February 27th, 2007, 08:33 AM   #7
frdtrckmnrich
FORD The Best Never Rest
frdtrckmnrich's Avatar
Not to mention that the rear axle should have a sensor in it that controls the transmission shifts.
Old February 27th, 2007, 08:37 AM   #8
frdtrckmnrich
Your best bet is to probably go with an 8.8 out of a fullsize along with a dana 44 front. That way you would have the same bolt pattern and still have the abs sensor in the rear. Alot of guys are then running newer dodge 16" wheels to tuck the tires back in a little.
Page generated in 0.24468 seconds with 47 queries
