stripped trans mount bolt - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 14th, 2006, 10:45 PM   #1
scorpio_vette
scorpio_vette's Avatar
Send a message via MSN to scorpio_vette Send a message via Yahoo to scorpio_vette
Default stripped trans mount bolt
first off, what kinda bolts are those 2 on the top of the transmission where it mounts to the engine. i was trying to pull my tranny today to replace the clutch. i've never seen bolts like that (look like a reverse torx bit).
well anyways i got the first one out using a normal socket, but the other one completely rounded off and i only have a couple inches of room to work with. any ideas on how i can get that one out?
and can i replace them with normal style bolts as long as i get hardened grade 8 bolts?
thanks,
alex
scorpio_vette is offline   Reply With Quote
Old January 14th, 2006, 11:17 PM   #2
Hacksaw
WWSD - What would stan do
Hacksaw's Avatar
Yup, they are inverted torx bolts.. not sure on the size right off hand.
Yes, you can, and would be stupid not to, replace with with a regular bolt when you are done.
Old January 15th, 2006, 01:37 AM   #3
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
E14 I think.... they are just regular 7/16" bolts with an e-torx head. Replace them with a new bolt and washer :)
JcrOffroad
Zoom Zoom!
Old January 15th, 2006, 02:33 AM   #4
Chop
Mischievous Badger
Chop's Avatar
yup exactly right i just replaced mine with regular bolts
Old January 15th, 2006, 09:26 AM   #5
Blue XJ
The Green Machine
Blue XJ's Avatar
Send a message via AIM to Blue XJ
The E12 socket also fits ont hem, but it has to be lined up just perfect. The E14 fits with some slop, making it 10 times easier to get to them bolts. Harbor freight had a 8 socket set for external torx bolts for like $6 if you need some.
Blue XJ is offline   Reply With Quote
Old January 15th, 2006, 11:03 AM   #6
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Now that you have gone ahead and f-ed it all up by not using the correct tool, your options are grind the head off, pull the trans and then get the bolt out or try to pound a smaller inverted torx onto it...good luck with that. I say get the grinder out.
Just thought of this...You can also buy a set of extractor sockets...they are made to grip a rounded off bolt. I used one a couple of years ago and it worked ok. Most parts stores sell them as does sears. You usually have to buy them in a small set of 4 or 5 sockets.
They look like this:
This is the sears kit, it's 20 bucks:
Page generated in 0.15974 seconds with 41 queries
