wanted cheap 5.9 diesel - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 27th, 2007, 09:01 PM   #1
RookieMT
Yes this is my truck!
RookieMT's Avatar
Default wanted cheap 5.9 diesel
I am looking for somthing cheap,a 5.9 cummins,for a dodge,want to start messing around witha diesel somthing that I wouldnt have mega tons of money wrapped up into!
Let me know if anyone has anything like that!
Thanks,Aaron 734 439 7177 leave message or asracing@dundee.net
RookieMT is offline
Old January 28th, 2007, 08:43 AM   #2
Bleay
sick of jackstand wheelin
Bleay's Avatar
http://www.pirate4x4.com/forum/showthread.php?t=543286
Bleay is offline
Old January 28th, 2007, 12:43 PM   #3
RookieMT
RookieMT's Avatar
Thanks,anything cheaper?
like under a grand?
RookieMT is offline
Old January 28th, 2007, 12:49 PM   #4
Dieselphreak2000
Somehow still alive..
Dieselphreak2000's Avatar
Best of luck on that. Cores are worth a grand.
Dieselphreak2000 is offline
Old January 28th, 2007, 02:27 PM   #5
RookieMT
RookieMT's Avatar
Thats what I`m looking for,I have no idea,need info!
Thanks!
RookieMT is offline
Old January 28th, 2007, 02:58 PM   #6
Dieselphreak2000
Check ebay, i scooped up a $1200 one last fall. It was a 180,000 mile engine, complete turbo to pan. It blew a month ago, so inspect them carefully...
Old January 28th, 2007, 04:04 PM   #7
RookieMT
RookieMT's Avatar
what did you do with it after it blew?
what did it do?
Thanks,Aaron
RookieMT is offline
Old January 28th, 2007, 04:21 PM   #8
Dieselphreak2000
Well, it's still in our F800. Once I find a new one, i'l probably junk it. It shot a rod thru the pan, so probably not worth messin with.
Old January 29th, 2007, 08:15 PM   #9
RookieMT
RookieMT's Avatar
they had a cummins in a f 800?
there is a 5.9 international for sale on the parts list!
RookieMT is offline
Old January 29th, 2007, 10:01 PM   #10
Grandman
do i look old !
Grandman's Avatar
Seems you want information heres some for ya .
The 5.9 cummins was put in a lot of medium duty trucks , for some reason they do not put the cold start system on them but other wise they are the same motor . Oddly enough they are detuned as well in the medium duty trucks .
Dodge ran the motor in 99 at 235 hp , but only 215 hp with the auto trans . Ford put it in a lot of medium duty trucks , Chevy used cats until they put the duramax in them . and international trucks run there own .
Dont bother with IHC motors if this is for a wheeler , they larger and heaver then you would want . If this is for some sort of tow rig then a IHC DT 466 is the best small diesel truck motor you can buy bar none .
For smaller like the 5.9 again best in its class .
Grandman is offline
Old January 30th, 2007, 09:33 AM   #11
Ebrown
Ebrown's Avatar
Wasn't the Chevy 6.2 and 6.5 made my Detroit Diesel not Cat?
Ebrown is offline
Old January 30th, 2007, 09:46 AM   #12
roll-bar Bob
roll-bar Bob's Avatar
CHEEP !!!!!
http://www.ttora.com/forum/showthread.php?t=56916
roll-bar Bob is offline
Old January 30th, 2007, 09:52 AM   #13
cracker$
cheese
cracker$'s Avatar
6.2 made by GM when they owned DDC.
6.5 made by GM after they sold DDC to Penske.
Does it have to be a Cummins 5.9? Theres Oldsmobile 350 diesels out there for dirt cheap.
cracker$ is offline
Old January 30th, 2007, 10:15 AM   #14
Dieselphreak2000
If you really want fun, go for a 4-71 Detroit Diesel. Cheaper, and sound like hell on earth at high rpm(2 Stroke Diesel's do).
Old January 30th, 2007, 01:51 PM   #15
Ebrown
Ebrown's Avatar
THe only thing the Oldsmobile 350 diesel is good for is a boat anchor.
You could use a cummins 4 BT
Ebrown is offline
Old January 30th, 2007, 05:25 PM   #16
RookieMT
RookieMT's Avatar
I`m a mopar person,been watching truck pull clips on you tube,and racing the quarter in 11 to 12 sec.
want to get one and start rebuilding/modifing ect....
and since I`m into monster trucks,maybe one day there will be a diesel monster truck running around! I`m sure there already is but.....
RookieMT is offline
Old February 1st, 2007, 02:35 PM   #17
RookieMT
RookieMT's Avatar
ttt
RookieMT is offline
Old February 1st, 2007, 03:16 PM   #18
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
If you can't afford $1K for a Cummins, I don't know how you will afford to run 11s with it. You're looking at around $1200-1500 for one with a rotary pump.
Cooter is offline
Old February 1st, 2007, 08:16 PM   #19
RookieMT
RookieMT's Avatar
I`m sorry my pockets arnt as full as yours,it is a project,not go out and buy some bodys truck thats already done,if I could do that I found one for $28,000 flame red 4x4 sharp truck 12.40`s quarter.sorry I`m not rich!
RookieMT is offline
Old February 1st, 2007, 10:32 PM   #20
merr6267
More boost than yours:)
merr6267's Avatar
I don't know how you blew up one of these things . . . Must have run low on oil at one point.
anyway, back to the thread...
You'll have a good amount wrapped up in one to make it go fast, but what you want is a 12 valve with the P-7100 injection pump. They look like a little mini 6 cyl engine hanging off the side, (kind of)
You'll be hard pressed to find one cheap though. Maybe in need of a rebuild. Usually a rebuild will only need pistons and bearings . . . maybe a re-bore depending on how hot the person got it/hot many miles are on it.
Good luck.
www.dieseltruckresource.com . . . Just start reading.
merr6267 is offline
Page generated in 0.38515 seconds with 83 queries
