traction bar 101 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 14th, 2006, 09:23 AM   #1
Bones
Bones's Avatar
Default traction bar 101
I have been reading POR about traction bars/ladder bars for a long time. About every year a new idea comes across. Here are links to different ideas.
This first one is the tried and true single ladder bar mounted a shackle.... looks like this
link 1 http://www.pirate4x4.com/forum/showt...=anti-wrap+bar
cliff notes are the link bar should be close to the same angle as your driveshaft. Only one bar is needed. Closer to center is ideal. Once you move away from center, there is a chance of limiting travel or "cork-screwing" your axle". Shackle can be mounted pointing up or down.
The next desing is somewhat considered new school, but some people say they ahve been doing ti for years. This one still has doubts in my mind.
Basically is mounts a hard bar on your spring U-bolt pad, and another end on the frame inline with your leave spring. Both ends are bushings, but fixed mounted (unlike the shackle system above). Most eveyone run it with a hard bar, but some run it with a chain or cable setting.
looks like this
Everyone claims it will limit travel (me included), but the people who have done it swear by it (including the imfamous Chris Durham.
here is the cable version
Here is antoher person's setup
and his proof that is doesn't limit travel
link 1 (doesn't get good to page 3) http://www.pirate4x4.com/forum/showt...=anti-wrap+bar
I'll add more links as I find them.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old January 14th, 2006, 06:55 PM   #2
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
The first is the only way to do it.
Any single bar setup (like #2 or the Bambar) force the spring itself to be the lower link of the traction bar. While those methods may LIMIT axle wrap, they won't remove it... and they put different stresses on the springs.
The ladder bar on my YJ does not limit flex, and does not allow any wrap or wheel hop whatsoever.... you will also notice that it's super easy to burn the rear tires after the install.....
JcrOffroad
Zoom Zoom!
Old January 16th, 2006, 03:12 PM   #3
shawn
Resident HVAC/R Jambi
shawn's Avatar
Darryl, does JCR make ladder bars?
Old January 16th, 2006, 08:56 PM   #4
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
We can make almost anything
It's not part of our regular catalouge, but I would have no problem building one and sending it off, or building and installing one.
JcrOffroad
Zoom Zoom!
Old January 17th, 2006, 08:51 AM   #5
Lothos
KD8GKB
Lothos's Avatar
Is the premise behind the devices to prevent the axle from traveling leterally backwards from the transmission thus dropping the driveshaft?
Old January 17th, 2006, 09:10 AM   #6
Bones
Bones's Avatar
no, it is to stop axle rotation, which stesses the springs, drops the pinion to make a higher pinion angle, and causes the axle to "hop" when it grains/loses/regains traction.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old January 17th, 2006, 10:28 AM   #7
sodapop
Support the Sport!
sodapop's Avatar
Option 2 might limit wrap but it looks like you'd be putting lots of stress on the main leaf which could cause it to break. Seems like that is part of the point of adding a antiwrap bar well that and the whole pinion angle thing. Bones have you check the bambar write-up on jeepaholics? I'm still not sure about that one either. When I go SOA, I'm just going to go with old faithful and use a normal ladder bar style.
Old January 17th, 2006, 11:59 AM   #8
Bones
Bones's Avatar
do you have a link to the bambam bar? I'll add it to the top post.
I ended up just building the normal shackle style ladder bar. Haven't tried it yet though.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old January 17th, 2006, 02:36 PM   #9
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Raises the pinion.
JcrOffroad
Zoom Zoom!
Old January 17th, 2006, 03:16 PM   #10
shawn
shawn's Avatar
Originally Posted by monkeyevil
Raises the pinion.
Or, lowers it (on teh front). I get bad wrap on the front springs, but not much I can do about that.
Old January 17th, 2006, 09:35 PM   #11
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
The bar thing seems like it would not allow the spring pearch/plate to move rearward under compression without basicly wrapping the axle and pointing the pinion down. The spring gets longer as it compresses, shorter as it unloads. The pearch has to move forward and rearward a bit...more or less depening on your spring style.
Notice no pics of the compressed side.
Old January 17th, 2006, 09:44 PM   #12
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
You can add a front traction bar... since the front axle rarely has as much rotational torque acting on it as the rear, a single bar setup may be just fine for your needs.
JcrOffroad
Zoom Zoom!
Old January 18th, 2006, 03:22 AM   #13
Bones
Bones's Avatar
I'm not sure exactly what you are saying, as the lenth of a leaf spring never really changes
Here is the compressed side... looks like it compresses pretty well
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old January 18th, 2006, 09:03 AM   #14
brimy311
Smells like a Fork Liftis
brimy311's Avatar
I would say the best way would be the first option, single ladder bar. I used on my TPI YJ and it worked great. I had not problems with "limited flex".
I have since gone to 4link rears. Then you don't have to worry about spring wrap :)
JcrOffroad.com
Like us on Faceook!
Page generated in 0.45089 seconds with 65 queries
