4 link calculator - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 14th, 2006, 09:40 AM   #1
Bones
Bones's Avatar
Default 4 link calculator
Stolen from POR
http://highvibesoffroad.com/drawings/4BarLinkV3.0a.zip.
Here are the directions
http://www.pirate4x4.com/forum/showp...3&postcount=21
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old January 14th, 2006, 09:45 AM   #2
clarkstoncracker
lol
clarkstoncracker's Avatar
Bad ass!! Thanks bones
Old January 14th, 2006, 10:46 AM   #3
Yup, I've been using this for about 6 months as I plan out the rear suspension for the Yota..
Old January 14th, 2006, 10:53 AM   #4
The tricky part is knowing what to set all your variables to. I.E. what you are really looking for.
Some rough things to shoot for, for the average person:
Vertical separation of the links at the axle should be about 25% of the tire diameter (So for a 36" tire, have 9" of vertical distance between uppers and lowers)
Vertical separation of the links at the frame end about 75% of the separation at the axle end.
Roll axis to be close to zero, or roll understeer, I think. I'm shooting to get close to zero. Using a double triangulated setup for the links helps for this.
Anti squat I think something less than 100%, maybe 50-70%, so that even under hill climb conditions you don't get past 100%. This helps hill climbing traction.
Well, those are some real basic numbers. Everyone has different ideas what will work. I think this summer I'm going to try doing a rear 4 link on the back of the Toyota..
Old January 14th, 2006, 07:52 PM   #5
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Here is the problem... unless you weigh everything going into your rig your just guessing at it's weight and center of gravity... so a lot of those calculations are going to be completely off.
I'll be linking the YJ rear soon... I'm probably going to design it the moment I start cutting tube :D
JcrOffroad
Zoom Zoom!
Page generated in 0.24237 seconds with 38 queries
