Looking for a Dana 35 axle and leaf spring for cheap!!!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 25th, 2007, 06:39 PM   #1
jkjeeps
Send a message via AIM to jkjeeps
Default Looking for a Dana 35 axle and leaf spring for cheap!!!!
I have an 89 Jeep Comanchee and I blow out the rear axle and now I am looking for either a whole new axle of if someone is parting axles then I need the spyder gears and the housing if at all possible.
Dana 35 ratio 3.55 27 spline
I am also looking for a new leaf spring for the drivers side. If anyone could help that would be wonderful!!
jkjeeps is offline
Old January 25th, 2007, 09:40 PM   #2
Jeepin35
out west hunter
pm fullthrottle he might have a couple D35's also just to let you know replace leaf springs as a set not just one. your vechicle will sit uneven. just giving you some heads up.
Jeepin35 is offline
Old January 25th, 2007, 10:22 PM   #3
silverxj
Recovering XJ owner
silverxj's Avatar
http://www.greatlakes4x4.com/showthread.php?t=14010
first come, first serve.
silverxj is offline
Old January 25th, 2007, 10:36 PM   #4
dmcjeep
dmcjeep's Avatar
I am parting out an 89 cherokee. Do you know if the rears are the same? If so mine is for sale. $125 complete $150 with the springs if I can get them off. Or I have a complete 88 cherokee that youcan buy for $250 and use whatever you need.
dmcjeep is offline
Old January 25th, 2007, 10:38 PM   #5
sam
sam's Avatar
i have a set of rear leafs for 75
sam is offline
Old January 25th, 2007, 10:52 PM   #6
General
General's Avatar
I have a dana 35 for sale 60 dollor its yours out of a 1989 cherokee might need brake shoes 3.55 gears let me know
General is offline
Old January 26th, 2007, 09:16 AM   #7
greenmeanie
greenmeanie's Avatar
http://www.greatlakes4x4.com/showthread.php?t=29540
just the axles for $150
greenmeanie is offline
Old January 26th, 2007, 01:46 PM   #8
natep1
I have an 8.25 froma 98 Cherokee, 3.55's, complete drum to drum with some extra brake parts for $100.
Located in Rochester.
natep1 is offline
Old January 26th, 2007, 04:38 PM   #9
jkjeeps
DMCJeeps::: How are the gears inside that axle? Just wondering.. and it will be $150 for the whole axle and both leaf springs? I am very interested in buying these but I just need to know if the gears are in good condition.
And Jeepin35 thansk for the heards up on that leaf spring situation. I was just going to replace one of them but now that you have said that I will make sure that I replace both them at the same time...
jkjeeps is offline
Old January 26th, 2007, 05:25 PM   #10
Bleay
sick of jackstand wheelin
Bleay's Avatar
http://www.greatlakes4x4.com/showthread.php?t=19156
Bleay is offline
Old January 26th, 2007, 05:49 PM   #11
silverxj
Recovering XJ owner
silverxj's Avatar
So I take it free isn't good enough?
silverxj is offline
Old January 27th, 2007, 12:22 AM   #12
bud442
bud442's Avatar
I have a dana 44 out of a mj, that I bought. It seems complete. I bought it for a cherokee, but since I have found a dana 44 out of a cherokee and no longer need this axle.
It has 3:55 gearing. but I would check everything out before installing.
I paid $200 and thats what I want out of it!
If interested, let me know
bud442 is offline
Old January 27th, 2007, 12:25 AM   #13
dmcjeep
dmcjeep's Avatar
Sorry mine is now sold. Sold it as a complete jeep.
dmcjeep is offline
Old January 27th, 2007, 09:57 AM   #14
jkjeeps
SilverXJ: I would really like to come out and look at your axle and it's gears. Just to make sure that the gears are in good working condition. Also would you happen to know if your upper and lower control arms would fit my jeep?
Budd442: Thanks anyway but I would like to try and get a leaf spring at the same time.. but if I am not able to find that deal. Would you be willing to let me cone out and see it?
Sam: Are you leaf springs still availble? Like I told Budd I would like to try and find an axle and leaf spring set together but if I do not find that deal would you be willing to let me come out and take a look at them?
jkjeeps is offline
Old January 27th, 2007, 10:25 AM   #15
bud442
bud442's Avatar
Yep not a problem.
bud442 is offline
Old February 1st, 2007, 05:32 PM   #16
General
General's Avatar
pm replied to.
General is offline
Old February 1st, 2007, 05:42 PM   #17
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
The Comanche and Cherokee don't use the same rear axle, or the same rear leaf springs. You will need to reweld perches on an XJ rear to fit it to an MJ, and the XJ springs are way too short to fit.
Cooter is offline
Old February 2nd, 2007, 09:03 AM   #18
jkjeeps
Well if they have the same gear ratio and the same gear spline wouldn't that be okay? I personally don't see why not?
jkjeeps is offline
Old February 2nd, 2007, 09:28 AM   #19
PavementPounder
PavementPounder's Avatar
The frame doesn't care what the gear ratio or splines are. It cares where the spring perches are, as Cooter mentioned. If you can move the perches and get the right spring, you'll be fine.
PavementPounder is offline
Old February 6th, 2007, 09:49 AM   #20
Pickpocket
DGAF
Pickpocket's Avatar
i got an 8.25 out of an xj 3.55 gears brakes are good complete drum to drum alot stronger than the 35 100$
Pickpocket is offline
Page generated in 0.31578 seconds with 83 queries
