Ironmans CJ - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 13th, 2006, 06:49 PM   #1
CreativeFab
used to be Ironman
CreativeFab's Avatar
Default Ironmans CJ
Here I am at the Badlands and in Canada
Old January 13th, 2006, 06:51 PM   #2
CreativeFab
used to be Ironman
Wow thats huge!
CC can you resize the damn thing?
Old January 14th, 2006, 12:46 AM   #3
Chop
Mischievous Badger
Chop's Avatar
nice cj pic is big but thats ok
Old January 14th, 2006, 01:40 AM   #4
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Here is another pic from last weekend.
Pat you want to share the details of your CJ with everyone? I know most of the info about it, but would probably leave something out.....so feel free to elaborate.
Old January 15th, 2006, 05:32 PM   #5
Cube
Captain of my pants
Cube's Avatar
snorkle on a CJ nice, whats under the hood?
Cube is offline   Reply With Quote
Old January 16th, 2006, 10:15 PM   #6
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Well he must of forgot about this post, I will list what I know about it.
AMC 304 w/Howel EFI, auto trans(th400?), d20 with tera 3.15:1 lowrange, D44's 4.56's, spool rear, ARB front, hi steer, spring over, 38.5" SX on Champion beadlocks, Warn 12k winch, dual optima yellow tops, premier power welder, ARB snorkel, fiberglass body, lots lots more.
Obviously with him owning Ironman Offroad this CJ has the best he can build.
Old January 17th, 2006, 12:36 AM   #7
JEEPGUY
JEEPGUY's Avatar
Hello, Ironman. I Met You Quite A Few Years Ago. Right After You Rolled Your Trailer With Your Jeep In It. I Came Over A Few Times With Greg Moore
Good To See You Still Have The Cj. Looks Good
JEEPGUY is offline   Reply With Quote
Old January 17th, 2006, 01:03 AM   #8
boggin-machine
boggin-machine's Avatar
thats badass
Old January 17th, 2006, 08:15 PM   #9
CreativeFab
used to be Ironman
Mike summed up most of it, thanks Mike!
I am getting ready to install my new Ultimate Air tank and I will be running my front ARB with it as well.
It also has the Centec wiring harness which is the nicest harness by far!
The FI 304 has roller rockers, Edelbrock intake and cam with MSD Pro Billet dist.and MSD 6AL ignition and high vibe MSD coil. It also has a one of a kind TLH/Ironman roll cage.
It will soon be on an Ironman frame with coil overs and alloy shafts in the axles.
And Hi Jeepguy, I remember you, I think Greg dated your sister?
Old January 23rd, 2006, 04:08 PM   #10
shawn
Resident HVAC/R Jambi
shawn's Avatar
Runor has it, you just did high-steer with PartsMike arms. What arms did you get (the standard ones or the taller heavy ones) and what springs are you sprung over with (how many leafs)? How much clearance do you have between the spring and the tierod?
Old January 24th, 2006, 08:06 AM   #11
CreativeFab
used to be Ironman
I used the standard parts mike arms and I am running the RE YJ spring over springs. I have a 1/2" of clearence between the spring and the tie rod, it seems to be working great!
The springs have 5 leaves and sit on a regular spring perch with a 1/2" thick bar stock welded to the top, this makes up for the height of the spring perch on the pass. side. With this set up your springs set a little higher then an axle that was set up for spring over from the fact.
So what I am saying is that I had enough space for the standard arms even though my springs are higher than they noramlly would be.
Old January 30th, 2006, 03:17 PM   #12
badazzamc
Get Some
badazzamc's Avatar
looks good.
Page generated in 0.31023 seconds with 59 queries
