5.4L motor noise - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 23rd, 2007, 05:31 PM   #1
Snowman43
Snowman43's Avatar
Default 5.4L motor noise
I have an '05 F150 with the 3 valve 5.4. Seems to have a top end ticking noise than gets slightly louder after the engine is brought to operating temp.
Doesn't really seem like valvetrain to me (higher pitched than a normal lifter), is it possibly an injector?
Just wondering if anyone has ran into this problem before....
Thanks!
Brian
p.s. It is a fairly high mileage motor for the year, almost 87,000
Snowman43 is offline   Reply With Quote
Old January 23rd, 2007, 06:24 PM   #2
chris1044
chris1044's Avatar
First - what oil are you running? These motors are very sensitive to viscosity, and I've heard 5-30 oil make them sound like they have lifter ticks - changed for 5-20 the noise disappears.
Second - I've seen timing chains go on these motors at that mileage, though they dont really make that same noise and it tends to change with engine load. It's possible it's the injectors "clicking" - I know mine on my ranger are fairly loud and could be mistaken for top end noise if you didn't know what they sounded like. Also, dont know if these motors have spark plug issues - and if they do, don't know how this happens (meaning I dont know if they actually do come loose first or if the casting just sucks)...you may want to see if they're all tight as well.
Just some thoughts
Old January 23rd, 2007, 06:30 PM   #3
Snowman43
Snowman43's Avatar
Thanks for the reply, have been doing some searching and found a Ford TSB on these engines, apparently they have alot of noise issues. Possibly what they call the VCT phaser, somehow adjusts the valve timing to engine load.
heres a link to the bulletin if anyone else is having this problem.
http://www.ford-trucks.com/tsb/fullt...php?tsb=06-4-7
Does have a crankcase full of 5-20 by the way.
Thanks
Brian
Old January 23rd, 2007, 10:08 PM   #4
Bones
Bones's Avatar
unfourtunatly, its normal... a lot do it from the factory...
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old January 24th, 2007, 02:15 PM   #5
chris1044
chris1044's Avatar
If the VCT phaser is one that works off oil pressure, like the ones that the DOHC ZX2 motors have, then I've seen those go bad and make a lifter noise as well.....didn't know that those motors were variable timed (if you want to call it that - if it's like the escort motors it's really just another position for the exhaust cam only)
Page generated in 0.24276 seconds with 38 queries
