simple cheep tig rig you can make at home*now with pics* - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 21st, 2007, 01:05 PM   #1
sglide
co captain of cubes pants
sglide's Avatar
Default simple cheep tig rig you can make at home*now with pics*
this works with dc a powersorce(dc stick welder) for all steels and it works very well
heres how i did it=
used a standard air cooled tig torch screwed it onto 10' of 5/8s rubber coated ssbraided hose with standerd metal wrench type fitings at each end crimped on.
used a bernard flow meter to control argon pressure. meter set to about 25
hook ground lead to hose/meter fitting
hook hot lead to work piece (steel is run rev. pol.)
you have no remote (foot pedal) so you cant change you heat while you weld (you just start cold and build heat through your puddle)
and no high freak. so you have to mach start your ark (wont be able to pass x-ray w/it)
i used it fri night to reweld every weld on a 76 honda chopper frame and it worked great.
sglide is offline   Reply With Quote
Old January 21st, 2007, 06:32 PM   #2
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I am totally confused.
Old January 21st, 2007, 06:58 PM   #3
sglide
sglide's Avatar
wich part confuses you?
Old January 21st, 2007, 08:04 PM   #4
VonDirt
VonDirt's Avatar
schweet
thats a great low buck rig. a guy could put that together out of ebay and junk drawer parts for not much green.
VonDirt is offline   Reply With Quote
Old January 21st, 2007, 08:14 PM   #5
sglide
sglide's Avatar
Originally Posted by VonDirt View Post
schweet
exactly
my boss was impressed, the tig that is disigned by lincon for our truck mounted welders (pipeliner 200g) cost $1200
Old January 21st, 2007, 08:36 PM   #6
wjwerdna
Toy'ota
wjwerdna's Avatar
pics? would be AWESOME
wjwerdna is offline   Reply With Quote
Old January 21st, 2007, 08:40 PM   #7
sglide
sglide's Avatar
if i could get my computer to rec. my camera i would.
maby i can use the computer at work in the next couple of days and post them
Old January 21st, 2007, 09:07 PM   #8
Big Daddy Rubicon
There watching me! (.)(.)
Big Daddy Rubicon's Avatar
Well, the little guy came up with a great trick! Nice job little Sammy.
[QUOTE=a.j. hall;1528363]
[/QUOTE]
Old January 21st, 2007, 09:10 PM   #9
sglide
sglide's Avatar
thanks old timer
Old January 21st, 2007, 09:19 PM   #10
possumjeep
possumjeep's Avatar
would this be stron enoug to weld ...say idunno spring perches on for doing soa on a Jeep
possumjeep is offline   Reply With Quote
Old January 22nd, 2007, 06:48 PM   #11
sglide
sglide's Avatar
it would be plenty strong enuf, but take way longer than mig or stick and be atot more dificult
Old February 25th, 2007, 02:54 PM   #12
sglide
sglide's Avatar
Old February 25th, 2007, 04:55 PM   #13
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Pics of the welds?
Old February 26th, 2007, 07:46 PM   #14
sglide
sglide's Avatar
i hate my dial up con.
Old February 26th, 2007, 08:05 PM   #15
fittergirl
Bird is my bitch
fittergirl's Avatar
That setup is very common for pipewelding in the field. Used on alot of stainless and chrome piping. That is all I saw at the refinery which is 100% x-ray.
fittergirl is offline   Reply With Quote
Old February 26th, 2007, 08:15 PM   #16
sglide
sglide's Avatar
how did they beat the fish eye prob. due to not being able to dump feiq and maintain sheilding? or were they allowed minor defects per there code?
im certed up to 6" thick stainless pipe and it would not pass our process test
Old February 26th, 2007, 08:19 PM   #17
sglide
sglide's Avatar
one more= was it a full open root with back gassing? if it was how did they bead in with a mach strike without leaving an ark stike that will show on xray no matter how much you grind?
Old February 26th, 2007, 08:22 PM   #18
fittergirl
Bird is my bitch
fittergirl's Avatar
That I don't know, I just set everything up for the welder and fit the pipe for them. I have only played around with tig welding, was certed for stick a few years ago but was stupid and let them lapse.
Old February 26th, 2007, 08:24 PM   #19
fittergirl
Bird is my bitch
fittergirl's Avatar
They were running full purge on all the chromemolies, so that helped.
Old February 26th, 2007, 08:29 PM   #20
sglide
sglide's Avatar
did they have a 37 1/2 dig beval and a 1/8 to 3/16 gap between?
Page generated in 0.29162 seconds with 83 queries
