drop pitman with 1-ton steering? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 12th, 2006, 07:15 PM   #1
87'YJ
Jeeps, Journey and Jesus
87'YJ's Avatar
Default drop pitman with 1-ton steering?
Quick question all. I have 1-ton steering. the stock pitman arm on my CJ has a much smaller hole than the bolt on the tie rod ends of my 1-ton steering have. How is this remedied? Can I just drill the hole out? or should I get some aftermarket steering arm that will fit the CJ steering box and a 1-ton tie rod end bolt?
Thanks!!
Dave
87'YJ is offline   Reply With Quote
Old January 12th, 2006, 07:25 PM   #2
brimy311
Smells like a Fork Liftis
brimy311's Avatar
you need to have your pitman arm reamed out. IT is a specific reamer. If you want to send it to us to have it reamed, let us know.
JcrOffroad.com
Like us on Faceook!
Old January 12th, 2006, 09:51 PM   #3
shawn
Resident HVAC/R Jambi
shawn's Avatar
I had JCR ream mine out. I ended up using a factory YJ arm, it had a little drop, was the same length (or real close) to the CJ arm, and was beefier than teh CJ arms. Hope that helps.
Old January 12th, 2006, 10:06 PM   #4
cornfed
I have an avatar. Yippee.
cornfed's Avatar
Get a factory YJ pitman arm and have JCR ream it. Yea, Brimy... reame it. reame it good. For some reason if you don't like putting money on JCR's plate, then contact http://www.partsmikeparts.com/pit_top.htm. For the tune of ~$80, he'll hook you up with a new pitman arm, ready to go for your CJ.
edit: are you keeping the conventional steering setup or are you converting to high steer?
Old January 12th, 2006, 11:39 PM   #5
87'YJ
87'YJ's Avatar
I am planning on doing a high steer (If I can get some knuckles).
We may leave it down below in the interest of finishing in a timely manner for now.
Page generated in 0.27617 seconds with 38 queries
