Adjustable Track Bars for a TJ - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 7th, 2005, 09:46 AM   #1
mschaffer66
mschaffer66's Avatar
Default Adjustable Track Bars for a TJ
We need some track bars for the Bubicon. I know jack about TJ suspensions so I need some info.
Whats out there and how much?
Thanks
Old November 7th, 2005, 09:56 AM   #2
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
Thanks
I Paid 105$ a piece for my Rubicon Express Adj. Trackbars..
nixxerRsixxer is offline   Reply With Quote
Old November 7th, 2005, 11:29 AM   #3
FrankNBrew
Me balls are huge
FrankNBrew's Avatar
I have Rusty's front track bar (TJ and XJ front track bars are the same), but it's not the best product out there. I've heard only good things about JKS stuff. Try dpgoffroad.com for a good price.
FrankNBrew is offline   Reply With Quote
Old November 7th, 2005, 11:43 AM   #4
mschaffer66
From who?
Old November 7th, 2005, 11:44 AM   #5
Sonicjay
The RE one sucks. It comes loose a lot. I don't know if that is characteristic of all adjustable bars, or just RE, but Rocky's did it too. Their heavy duty one is better, but requires at least 4.5-5 inches of lift. It will not collapse enough to fit less lift. I'm gonna try to double-nut the top mount to at least keep that end from falling off.
Sonicjay is offline   Reply With Quote
Old November 7th, 2005, 11:57 AM   #6
nixxerRsixxer
Homewrecker
i've had mine on for 2 years and never has come loose..
Old November 7th, 2005, 01:27 PM   #7
nixxerRsixxer
Homewrecker
btw ms. you got a pm..
Old November 7th, 2005, 03:17 PM   #8
lowlock
05 LJ in progress
lowlock's Avatar
i have a rear rubicon express trac bar with a axle bracket out of my tj
lowlock is offline   Reply With Quote
Old November 7th, 2005, 07:08 PM   #9
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
I have a RE adj on the front of my ZJ, and a JKS on the rear of my ZJ. The JKS unit is a much better built piece of equipement. I don't remember what I payed for them. Somewhere around $150 each give or take $10-15.
Old November 8th, 2005, 12:05 PM   #10
Tonka
Tonka's Avatar
I have had Excellent results with Rusy's Offroad H.D. trackbars and brackets
they have poly bushings, no superflex or johnnie joints to wear out at the sight of dirt/mud , but are still configured to give a ton of droop.
Old November 8th, 2005, 01:57 PM   #11
Spoiledbrat
I'm trying to care
Spoiledbrat's Avatar
Red face
Only prob I'v had with my--It hits the diff cover when the suspension compresses on the left. Seems to be a problem with RE or jks trac bars on Rubicons
Spoiledbrat is offline   Reply With Quote
Old November 8th, 2005, 02:57 PM   #12
C.K.
Dont Feed the Cyco
C.K.'s Avatar
I havent had a problem with mine yet. It might be a heavier one though.
C.K. is offline   Reply With Quote
Old November 9th, 2005, 09:48 AM   #13
Kodiak
Hardcore Poser
Kodiak's Avatar
I also run RE adjustable track bars front and rear. I had to re-tighten mine a few times after install, but now it's all good. Hasn't come loose in over a year.
I can't comment on other brands, but with the RE front, I had to drill out (ream) the frame mount hole to make room for the new bolt. Don't know if it's the same for other brands.
HTH, Good luck.
Kodiak is offline   Reply With Quote
Old November 9th, 2005, 11:23 AM   #14
mschaffer66
This might be a dumb response...but if you have to keep retightening...is loctite an option? Or is it not caused by vibration?
Old November 9th, 2005, 12:17 PM   #15
Kodiak
Hardcore Poser
Kodiak's Avatar
Good question.
I assume loctite could be used...at least, I don't see how it could hurt. It's not in the RE instructions (the RE instructions were worthless anyways). But in my case, after checking a few times, they are now solid. It's been about 2 years since I installed the lift. Mine came loose only after wheelin'. Both the jam nut and the nut on the frame mount.
Here is a picture of that end of the RE track bar. I'll also add that the jam nut on my RE control arms also had a tendency to loosen up, but again, after I tightened them a few times after runs, they never loosened up again.
Old November 9th, 2005, 03:57 PM   #16
mschaffer66
Ok, thought number 2 once you have it dialed in why not just tack weld the jam nut?
Old November 9th, 2005, 04:09 PM   #17
Tonka
Tonka's Avatar
because heims suck, and wear quick
Old November 9th, 2005, 04:22 PM   #18
nixxerRsixxer
Homewrecker
ive had mine on for 2 years.. hasnt loosened.. initially it wasnt tightened enough.. after i put it at like 150ftlbs seems to be great.. ideally the heim should be 90° to its current position.. so if you wanted to fab a bracket off the frame to hold the bolt in double sheer and 90° that would be best.. (after all the stock tb mount is fairly weak and has been known to rip completely from the frame with lots of wheeling..)
Page generated in 0.42573 seconds with 77 queries
