90 k2500 oil adapter - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 19th, 2007, 12:55 AM   #1
carguy64744
Default 90 k2500 oil adapter
well my oil adapter got broke when i threw a rod threw the pan broke one of the fittings off so i threaded it and put a plug in it it leaks anyone got any ideas is there a short enough oil filter so i don need to use this or an alternative
carguy64744 is offline   Reply With Quote
Old January 19th, 2007, 11:19 AM   #2
KaiserJeep
boogidy boogidy boo
KaiserJeep's Avatar
I would not skimp on an oil filter, if you go with a short one your going to have a lot less flow through it and a much lower filtration rate... plus its going to plug up faster, then all the oil will go through the bypass and your engine will get phucked again...
KaiserJeep is offline   Reply With Quote
Page generated in 0.47475 seconds with 29 queries
